Ali loses a turbine at about 200 mph
RE: Ali loses a turbine at about 200 mph
ORIGINAL: ddlstang
I want one !!
I want one !!
the turbine is not a experimental unit it is made by a very talented guy in the uk it's called a sprite more power than jet cat just needs a stronger mount
200mph or all those G's is nothing for an opus. Go see what the DS boys do with them[X(]
Bad luck Ali, not the way you want to see a turbine go!
dave
dave
Nope, that one is well and truly lost. I still can't get over how much faster it is that the P20 version, which seemed quick after the first year of Lambert power.
ORIGINAL: Airplanes400
The technical term would probably be, ''the engine separated itself from the jet.''
I guess the engine mount should have been G-load tested too!
