F104g 1:4 scale
Reply
Old 08-08-2017, 12:55 AM
  #201
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Damo260 View Post
I'm about to start finishing off sheeting the center section just a couple of questions fuel tanks and were are we going to put them I'm think of get a custom set made from CMJets tanks and next how are we going to secure the wings
Damo
I guess you missed it in my earlier posts, but you can see my wing attachment screws in the pictures I posted.
On the wing side, I glued some 1/4" ply out at the end of the aluminum spar, drilled and tapped it for a set screw. I will keep the spars in the wings because they are small enough for me to transport and keep in the shop.
Next I added 1/4" ply to the fuselage (see pictures) and drilled and tapped for screws. Ideally I would like the screws more towards the ends of the spars, but it was the only place to put them on the fuselage.
Right now I have a 1 gallon tank just in between the split of the intakes. I will also add 2 additional tanks where the stock landing gear were located.
Right now I'm building another Skymaster F-4, this one is for me, but I will get the 104 glassed before the summer is out. I plan to maiden the 104 early next year.
ID:	2227321   Click image for larger version
ID:	2227322   Click image for larger version
dionysusbacchus is offline
Old 08-12-2017, 11:51 AM
  #202
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Luke
Sorry for the late reply been flat out with work and family not much building going on. I thought it would be something like that for the secure of the wings but I've also been thinking of leaving the aluminum spar in the fuselage I'll have a play around with that and let you know how it go's. I'll send a email to CMJets tanks and see what he has got. Love the F-4s but already pick up a side project a ESM PC-21 I'm going to convert to a turbo prop and repaint in the Australian colour scheme and I'll need Mirce to me a scale detail set for it . Maybe next year for a F-4.
Damo
Damo260 is offline
Old 08-12-2017, 12:58 PM
  #203
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No problem, I'll made all sets you need...
Mirce
mirce is offline
Old 08-12-2017, 01:14 PM
  #204
madmodelman
madmodelman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have an F4!
ID:	2227740   Click image for larger version
madmodelman is offline
Old 08-12-2017, 01:41 PM
  #205
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mirce
Thanks Mirce I'll find some good drawings and I'll get them to you
Damo
Damo260 is offline
Old 08-12-2017, 01:45 PM
  #206
Damo260
Damo260's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by madmodelman View Post
I have an F4!
Nice I like twin
Damo260 is offline
Old 08-17-2017, 08:30 AM
  #207
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do get some time to work on the 104, got the last of the servo installation figured out, the elevator. Early in the project I was just going to use the external linkage, I would prefer to have it internal, but that ship has sailed. This will make disassembly and maintenance/inspection much easier. Plus painting all the linkage with the plane makes it almost completely disappear from a short distance away.
The attachment point with PC board material may be a bit overkill, but it will almost always be pulling (up elevator) so I wanted piece of mind. I figured that the best point for the arm was right over the front spar on the stab, 100 percent throw will give me some extra if I need it, but for the stock recommended throw the servo will only need about 70 percent travel.
The sheeting will be glued back on and the end capped and sanded for a good fit on the vertical.
ID:	2228277   Click image for larger version
ID:	2228278   Click image for larger version
Old 09-10-2017, 03:28 AM
  #208
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Few photos of my F 104 Starfighter.
Wooden kits and all other parts are always available - Damiano F 104 - NS Modelers
Mirce
mirce is offline
Old 11-10-2017, 02:46 PM
  #209
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Few months ago...
and now...
Mirce
mirce is offline
Old 11-12-2017, 11:01 AM
  #210
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All together...
Best regards
Mirce
mirce is offline
  #211
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All together...
Best regards
Mirce
mirce is offline
Old 11-12-2017, 01:29 PM
  #212
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mirce, you inspire me! I set mine aside to finish two other jets (ARF's), but I will be back soon.
Good work my friend and thanks for sticking with this project and showing us how it is done!
Luke
Old 11-15-2017, 08:47 AM
  #213
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys. Great job on the build. Hopefully I can join in soon :-)
Checklist so far:
1, Order kit from Mirce check
2, Order heaps of balsawood sheets check
3, Order glue, tools and supplies check
4, Buy scale model to help the build process check
5 wait for everything to show up. standby :-)
Have you guys had a chance to weigh yours yet ?
How large a servo is reccomended on the elevator ?
I really dont like the looks with the external servos on the outside of the elevators, and will be doing mine internally.
Hopefully a single servo, if the torque can be met with a single servo.?
SJN is offline
Old 11-18-2017, 06:54 AM
  #214
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still waiting for miy kit.
​​​​​​Tried out Alclad II on my plastic model, and it turned out ok. Anyone used this finish on an rc plane. Is it durable?
ID:	2245464   Click image for larger version
ID:	2245465   Click image for larger version
ID:	2245466   Click image for larger version
ID:	2245467   Click image for larger version
ID:	2245468   Click image for larger version
SJN is offline
Old 11-27-2017, 10:27 AM
  #215
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brown box showed up today...... This will be fun
ID:	2246330   Click image for larger version
ID:	2246331   Click image for larger version
SJN is offline
Old 11-27-2017, 02:04 PM
  #216
erbroens
erbroens's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
eye candy!!!!
erbroens is offline
Old 11-27-2017, 02:41 PM
  #217
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great that "brown box" arrived, that was pretty fast.
Today another one "landed" in workshop of my friend Carlos in Spain.
Next year will be "Mirce models" F 104 all around the world.
Thank you for choosing my products - NS Modelers
Best regards
Mirce
mirce is offline
Old 12-16-2017, 05:46 PM
  #218
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Mirce models" offer from December 20. - January 10.
- 20% "Christmas discount" on all wooden kits & details / finish sets!!!
Mary Christmas and Happy New Year to all my customers, friends and modelers around the world.
Best regards
Mirce
mirce is offline
Old 01-29-2018, 04:03 PM
  #219
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thread is a little slow, but that is to be expected with a project of this magnitude! I finished 2 Skymaster F-4's and am now back on the Starfighter, but I will still be working on other projects as I go, just have too many irons in the fire!
I am tightening up my gaps and getting ready to glass. I will be making a fiberglass mold of the canopy, it will be a fiberglass hatch. I have some other really cool stuff I'm doing that I will show later! I was really cold here for a while, another reason I stopped working.
I have one more cross brace to add to the landing gear system, so the retract air cylinders don't flex the keel when the mains bounce around on landing, just as on the Airworld 104.
I weighed the plane, with all servo's, all air system components, some radio gear, fuel tanks, it came to 40lbs. I have to add the finish, turbine, tailpipe and batteries and any ballast that may be needed. The prototype weighed 68lbs ready to fly, figure 10lbs of fuel, leaves me 18lbs for the turbine, batteries, finish and tailpipe. I've never built a plane of this size, so I don't know, Mirce, how much does yours weigh?
I plan on saving weight with the finish, only one thin coat of resin and 3/4 oz glass cloth. I will fill the weave of the cloth with spot putty thinned with acetone. It sands really easy and is much lighter than another coat of resin. I will then use a good epoxy primer.
I made the nose cone twist off as per the Airworld version, that is where all my fill valves and Powerbox radio monitor will be located.
When I have more to show, I'll post.
ID:	2252748   Click image for larger version
ID:	2252749   Click image for larger version
Old 02-04-2018, 04:10 PM
  #220
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the tail and exhaust to my liking. I wanted the F-104G look, forgot what engine, but here is what I came up with. I cut the last former off and left about an inch of skin sticking out past the next former in. I then made my pipe support and epoxied it in, the exhaust is held on by 4 screws. I have some detail to add after I sand it, then I'll paint it up real nice!
This mod has the advantage of a shorter exhaust pipe and less weight and cost. Not to mention it helps in the looks department in my opinion.
I will glass soon, the weather is getting nicer already, about 75 degrees today. I have just been real picky about the details and how I want it to look, but it will pay off... I hope!
ID:	2253487   Click image for larger version
ID:	2253488   Click image for larger version
ID:	2253489   Click image for larger version
ID:	2253490   Click image for larger version
Old 02-04-2018, 04:31 PM
  #221
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice job Luke!
Mirce
mirce is offline
Old 02-04-2018, 11:08 PM
  #222
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great, but isn`t that a F-104S with 3 ventral fins :-)
SJN is offline
Old 02-05-2018, 04:29 AM
  #223
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are correct about the picture, it was just the best picture I could find of the exhaust. I will be doing the Italian version, but not all of them had the 3 fins, I'm just lazy really and don't want have to make more stuff!
I like the yellow and camo version, also the large white numbers.
Old 02-06-2018, 10:47 AM
  #224
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Mirce! Looking forward to more progress on your 104. Damo has been very quiet, hope his project is going well.
I got to paint something! Just the exhaust, but at least it's a start. I used Model Master, you know $5.00 for five drops of paint! I used the light brown for a rust effect.
Old 02-10-2018, 06:49 AM
  #225
dionysusbacchus
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've attached the fin on the bottom of the fuselage, I used the same technique as was used on the nose cone. Two cap screws and some 3/16" ply on the bottom of the fuselage. It works extremely well and is easy to attach and remove, this is critical because I will be removing the tail section for transport, it bridges the center and tail section.
Next the retract compartment got the final touches (except for the inner gear door detail). The keel is constructed like an I-beam, and it needed a brace behind the air cylinders. I used a cheap can of flat black to shadow out all of the clutter and wood look of the massive hole in the bottom of the fuselage, it helps to clean it up and just looks neater.
This plane was not designed for scale gear, so fuel tank placement becomes a problem. I managed to get two Du-bro 50 oz tanks on the CG, just in front of the forward wing tube. I have a one gallon tank that sits between the split in the ducting, I want to have that tank drain first because it is ahead of the CG, then use the saddle tanks as my reserve. Even with the K310, 228 oz of fuel is good for almost 7.5 min at full throttle.
ID:	2254055   Click image for larger version
ID:	2254056   Click image for larger version
ID:	2254057   Click image for larger version
ID:	2254058   Click image for larger version
Contact Us Archive Advertising Cookie Policy
