Reload this Page >
Saab Draken expert needed
Old 05-13-2012, 04:02 PM
A343
A343's Avatar
Default RE: Saab Draken expert needed
För all del!
I don't have the number, but I know Lasse Palm does.
Thomas
Old 05-14-2012, 04:50 AM
at-6 texan
can you speak at he for take information on J-35 F Draken?
or can you write me an E-mail address. so i can send an E-mail with Drawing Cad for show something at he?
Old 05-15-2012, 10:00 PM
at-6 texan
up!
Old 05-15-2012, 10:19 PM
Henke Torphammar
Henke Torphammar's Avatar
ORIGINAL: at-6 texan
Vad exakt är det du söker? Kontaktinfo till Einar eller bara info/ritningar på J35F?
Old 05-16-2012, 09:35 AM
at-6 texan
hej Henke tack for hjälpa! men du måste skriva Engelska!.
I'm still looking reliable designs where are all present the frames of the fuselage. i have something but this is not designed correct.
can you help me?
Old 05-16-2012, 10:42 AM
  #31
F86_SABRE
AT-6,
Try here:
http://www.airwar.ru/other/draw/j35drakenpkl.html
http://www.airwar.ru/other/draw/saabj35draken.html
http://www.airwar.ru/other/draw/j35.html
http://www.airwar.ru/other/draw/j35draken.html
Old 05-16-2012, 02:38 PM
  #32
Frank Alvarez
Hey John,
The Draken has been flown with the Nexus with great results. The thrust to weight is almost an exact match when compared with the full scale jet. Even during its best of days in the late 70's the D-model maitained a thrust/weight advantage over others with a .7 to 1 ratio. Not bad for an early attempt at high speed intercecptor/fighter design!
My Draken is normally flown with about 45-60 percent thrust angle on the stick, with the need for full thrust during the verticals.
If you are in the area, I will be present at the "First in flight",NC event with the Draken. There you may personally observe the large jet for your note taking.
Take care for now,
Frank.
Old 05-16-2012, 09:21 PM
  #33
at-6 texan
ok guys to understand what I need to think it is better to post a dwg file As you can see I brought all (36?) the ordinates of the fuselage. but what I need are the frames in proportion to the Top View. I did a little of comparisons and it seems that the frames are not mirrored to the side and top views. in addition it must be said that shows only the main frames but those of the tail and those of the "nozzle" terminal are not present. (I need to find those too!).
Old 05-16-2012, 09:56 PM
  #34
at-6 texan
sorry guys but the forum not be able to load Cad file![]
Old 05-16-2012, 11:20 PM
  #35
F86_SABRE
Print screen shots or convert your existing file to pdf/jpg/tiff
Old 05-17-2012, 04:08 AM
  #36
-JC-
My Feedback: (26)
-JC-'s Avatar
Frank,
I was thinking about making the trek to NC. If I can find someone to share the drive from FL then I'll be there for sure. Would be fun to see your Draken "live" .
Btw, thanks y'all for the help with the insignia. I found what I was looking for. Decals and paint masks has been ordered...
Old 05-17-2012, 06:16 AM
  #37
George
My Feedback: (57)
ORIGINAL: -JC-
Frank,
I was thinking about making the trek to NC. If I can find someone to share the drive from FL then I'll be there for sure. Would be fun to see your Draken ''live'' .
John,
Swing by and grab Todd and come on up!!!!
Old 05-17-2012, 07:34 AM
  #38
-JC-
My Feedback: (26)
-JC-'s Avatar
If he wants to go, I'm game
ORIGINAL: George
ORIGINAL: -JC-
Frank,
John,
