skymaster a10 gear
1 Post
RE: skymaster a10 gear
when all air is out of oleo ,keepfilling with oil work the strut up and down, or in and out ,holding up right, ,on the final fill of oil push the strut, oleo all the way in, then put the air valve/oil fill plug back in, then charge to the correct pressure, I use 110 psi and they sit nice, it depends on weight of model.
regards, Mark Hinton.
