Painting a Hot section how to
Reply
Old 06-04-2012, 04:08 PM
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Painting a Hot section how to
Hey guys,
I took these pictures a few weeks ago while doing this with the intent of doing a how to on this subject but forgot all about it, so here it is. Simply put, it's how I do a hot section on exhaust nozzles, I love the way it looks and it's easy to do.
What you'll need:
Aluminum Ducting tape (I prefer this over flite metal for this application as it is stickier, a little thicker, and allows some harsher sanding)
Xacto Knife
Masking tape
Airbrush (I used an Iwata HP-CR for this exerciese)
Mr Clean Magic Eraser
Paint colors - Black, Pthalo Blue Candy, Root Beer Candy
320 grit sand paper
Patience
Since RCU is acting lame and I can't upload pictures, I had to use photo bucket, that's alright though, it'll work fine
Step 1.
Here is the aluminum ducting tape I use, it's 2" wide which is plenty wide for doing nozzles and hot sections. Notice there is already a "grain" to the tape, I try to apply it so the grain is already going the direction I want.
Step 2.
Begin by taping off with masking tape the area's you don't want the aluminum tape to stick to. Once this stuff sticks, there is no getting it off. Use the masking tape so that you can remove the excess!!!!
Step 3.
Start placing the tape where it needs to be, cut the excess off with a sharp exacto blade and just use your thumb to press it all down. Don't get to hell bent on burnishing it down like flite metal, you'll just put marks in it, it's thicker and softer than flite metal.
Step 4.
Using a hex head driver I pressed in fastener shapes where they needed to be on the nozzles
Step 5.
Hex heads in the nozzle
Step 6.
Here is the metal section on the fuselage. Don't worry about there being bumps, wrinkles, etc, that will all go away in the next steps.
Step 7.
Next mask off one panel at a time in preparation for sanding
Step 8.
Sand in the direction of the metal grain. This particular jet is a Mig 29 and after looking at multiple images of the nozzles I wanted to keep it pretty rough looking. I started with 320 grit to knock down the bumps and scrapes, then went to 400 grit just to smooth it off a bit. Continue with progressively finer grits of paper if you want to have a smoother look.
Step 9.
If all of your sanding will be in the same direction, you don't need to mask off the adjacent panels, just be careful not to sand through any corners.
LGM Graphix is online now
Old 06-04-2012, 04:20 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Painting a Hot section how to
Ok, now for the fun part.
Break out your airbrush. All of your paint for this will be over reduced, we want to use it more as a wash than an actual pigmented paint. The black in particular. I am using PPG black in this case and SEM Candy's. The SEM Candy Concentrates are mixed with a PPG mixing base and reduced. You can use DBC500 or any of the clear carriers designed for Candy's.
Step 1.
Start airbrushing your black on the sanded aluminum. Spray in the direction of the grain, but don't worry about even coverage. We don't want that, concentrate the black heavier where the nozzle would be dirtier from soot and crap in real life, along seams, in rivets, etc.
Step 2.
Take your Mr Clean Magic Eraser and start rubbing down the part, again, always in the direction of the grain. This will remove most of the black leaving deposits in the sanding scratches, valley's, rivets, grooves etc.
Step 3.
Now take your Pthalo blue candy, over-reduced as well and spray the area's where the blue should be, look at reference photo's to determine where the metal will blue the most.
Step 4.
Rub down the blue with the magic eraser now.
Old 06-04-2012, 04:25 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Step 5.
Now take your over reduced root beer candy and airbrush around the blue, let the root beer go well into the blue to help pull back the blue color around the edges, this will let the root beer blend better in with the blue.
Step 6.
Again, rub it down with the magic eraser
Step 7.
Spray some black back in so that there is a "soot" over some of the color again, this will actually richen the color a little and add some depth to it.
Step 8.
Clear coat with a satin clear (not flat, not gloss) and sit back and enjoy your efforts
Old 06-04-2012, 04:29 PM
FenderBean
FenderBean's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice, I like your style thanks for sharing!
FenderBean is offline
Old 06-04-2012, 04:42 PM
readyturn
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeremy,
Great info as usual.
Rick
readyturn is offline
Old 06-04-2012, 05:11 PM
hooker53
My Feedback: (106)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeremy. That's the best one I've seen yet. Thanks for posting this. I wish we had a Sp sticky for tips like this.
hooker53 is offline
Old 06-04-2012, 05:15 PM
invertmast
My Feedback: (22)
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Damn jeremy, those look fantastic! If you want another pair of nozzles to practice on, ill send you some F14 ones. Lol
invertmast is offline
Old 06-04-2012, 05:23 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Thomas,
I don't think I need them to practice on, but I'd be happy to do a set for ya for a small fee haha
Old 06-04-2012, 05:41 PM
kev-o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks awesome J as usual
kev-o is offline
Old 06-04-2012, 05:43 PM
Greg Wright
Greg Wright's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeremy those look very cool. If you ever want to give it a go with the real titanium i used on my F-100 here is the web site to order it from. Titaniumgoat.com
ID:	1769214   Click image for larger version
ID:	1769215   Click image for larger version
Greg Wright is offline
Old 06-04-2012, 06:10 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Greg,
I still say that yours is the BEST looking F100 hot section I have ever seen, brilliant my friend!
Old 06-04-2012, 06:11 PM
invertmast
My Feedback: (22)
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: LGM Graphix
Hey Thomas,
I will definitely take you up on that offer once I have a need for them to be painted!
Old 06-04-2012, 07:03 PM
Ron101
My Feedback: (22)
Ron101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow!! that looks great
thanks for the tips
Ron101 is offline
Old 06-04-2012, 07:48 PM
sideshow
sideshow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those look like *****!
Awesome! They definitely have that Russian abused look to them.
btw...I like the photo bucket pics better than uploading, they're all full size already.
Thanks!
sideshow is online now
Old 06-05-2012, 06:53 AM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sideshow
Thanks!
Hey Bob,
I had to read that first line a few times haha. I hope by "those look like *****" you mean the good kind of *****, lol. Even when I found pictures of a near factory fresh Mig, they look old and abused haha. Love it though, makes for a much more interesting model I think.
Old 06-05-2012, 07:11 AM
pbusa1400
pbusa1400's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow!!! That looks great.
Pablo
pbusa1400 is offline
Old 06-05-2012, 07:47 AM
basimpsn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow Im jealous..Very nice work
basimpsn is offline
Old 06-05-2012, 10:48 AM
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hooker53
All you have to do is subscribe to the thread and it will be stored in your fourm settings
Awesome work as usual, I subscribed for future reference!
RCISFUN is offline
Old 06-05-2012, 11:27 AM
JeffH
My Feedback: (43)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While the real titanium is perfect, your paint is the best I have ever seen. If you look at the way the titanium turned colors, yours duplicated it perfectlly. I bet from 5 feet, you can't tell that yours isnt real titanium.
JeffH is offline
Old 06-05-2012, 12:30 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
on my 1/5 Miraze 2000 i sprayed direct full coats and the i was sanding down to get the color change.
First coat primer, then thick coat of silver,then metal blue ,then one we call bronz (like gold)
ID:	1769437   Click image for larger version
ID:	1769438   Click image for larger version
ID:	1769439   Click image for larger version
ID:	1769440   Click image for larger version
ID:	1769441   Click image for larger version
ID:	1769442   Click image for larger version
DelGatoGrande is offline
Old 06-05-2012, 12:34 PM
DelGatoGrande
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...after the careful sanding has finished, i mix of black and brown oil paint makes it more real.
photos don't give justice of the final result..
http://www.rcuniverse.com/forum/m_10...m.htm#10807259
ID:	1769444   Click image for larger version
ID:	1769445   Click image for larger version
Old 06-05-2012, 03:54 PM
dbsonic
dbsonic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darn. I just painted my tail cone flat blk. Had I seen this I would have gone this way. Nice work guys. thanks for sharing.
dbsonic is offline
Old 06-05-2012, 05:00 PM
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops, found one more picture of the nozzle from underneath with the rest of the hot section, this is probably my favorite part actually!
Old 06-06-2012, 01:18 PM
RalleKnalle
RalleKnalle's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice....
Jeremy, that´s a great idea.....going to use that tape too. will try...
George, nice job...you haven´t sent me that pictures!!!
have tried a new procedure to paint nozzles...will be published in the new issure of the JP magazin. I guess it does work fine on that bare metal tape too.
RalleKnalle is offline
Old 06-06-2012, 07:45 PM
sideshow
sideshow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great and I really like the big photo bucket pics...
