BAE Hawk @SVF Phoenix Az
My Feedback: (95)
RE: BAE Hawk @SVF Phoenix Az
Great looking bird. I have my SM Hawk 100 coming in next week. Let me ask you....did you have any issues with the main gear retracting? I know in the past it seemed that the cylinders had some trouble lifting the legs up. Are you running about 100psi?
Joe
Joe
#31
My Feedback: (198)
Thanks Paul
Joe, No problem with the gear going up. I use 100 psi and 2 large tanks. With one tank I was loosing too much air per cycle. The main stick a little coming down. It takes about 60 psi to unlock them. If I am inverted they unlock easy. I hope the gear wear in. This kit was purchased 2 years ago. So if there was an update, it isnt in this version.
#32
My Feedback: (52)
Tony:
My T45 was a bit smaller but I had to go to 2 air tanks when I added the gear doors. A lot going on on each cycle. On T45 inside main doors and forward nose gear door close after LG extend. The problem I had was gear goin up, required constant maintenance of cylinder orings to make sure no leaks.
Paul S
Paul S
