JET LEGEND VIPER BUILD THREAD
#130
RE: JET LEGEND VIPER BUILD THREAD
On my version there is no fill valve on the nose gear, only on the mains have it however the nose strut feels quite strong, I'm wondering if they may have changed it with recent batches.
#131
I doubt it Jeremy, it will show up when you fill with fuel, I would drop an email to Jet Legend if you are certain there is no threaded hole.
You can quickly pull the leg out and check to see if there is a spring fitted of course.
#132
My grub screws that hold the leg on are also facing back and not on the side like your images. I'll take some photos when I get home tonight
#136
Just checked it, Mines got a spring.
The mains have the air fill slot and I even got a nipple with some black airline on it to fill them with but the nose is definitely a spring. (sorry for the poor pics)
#138
Hi all,
Share the latest flight video.My JL viper jet this time would be some differences,
Cg was settled at 35mm behind spar as per yours. Former is at the wing tube.
Now i find that it can be flew very slowly with take off flap down.It was very stable
in theslow flight, Manipulability great, not easy to stall.By the way,power by JL T12.
flight video http://www.tudou.com/programs/view/YOrRGfBSnk4/
Best Regards
William
Best Regards
William
#139
Hi guys,
Good news!
August 16,2012,Jetlegend electric version viper finish test.We called it "Jetlegend E Viper".
Factory will release soon.
Iwas very happy to help test flight, the feeling is very great.E viper size is exactly the same
with thejet version,Just in the fuselage there a little different.
Equipment as follows:
power by RClander 120mm metal EDF
LiPo 6S 5000mAh 35C 2pcs in series
160A ESC
all High voltage servos
Futaba T12FG+R6014HS
Total weight(include all battery): 9Kg
CG was settled atthe wing tube.
Maiden flight video: http://www.tudou.com/programs/view/xDqlPw4N1DA/
Regards
William
Good news!
160A ESC
Regards
William
#140
Hi,
Continue to share my JL viper jet flight video.This time funny flight in zhuhai heliport china.
http://www.tudou.com/programs/view/gMyC_jKCOfc/
My good friend Simon To with his P38: http://www.tudou.com/programs/view/Qtj1CL_hIoA/
Regards
William
Regards
William
#141
Balancing mine today, hope to maiden in the next week or so. As per everyone else at 35mm back, which seems to be right on the front opening of the main hatch before it goes up and forward. My ECU battery is going to have to go in the trubine bay. Will weigh it later today as well and post back my AUW,
#142
AUW = 10.5kgs with the header tank full.
Balanced at approximately 35mm behind factory C.G / wing spar centre.
I also modified my flap and installed a horn in line with the servo cutout.
I'm going to use 2mm down elevator for take off flap and 4mm down for landing flap, can anyone confirm these setting should be okay? Flaps are 25mm take off and 55mm landing
Some pics of my fit out, just need to add some velcro ties to my ecu pack in the engine bay and my RX packs and run my RX antenna's.
Jeremy
Jeremy
#144
Spot on John
Going to talk to Phil and see if I can have a visit to do the maiden, I would rather have some flights under my belt before Temora otherwise I'll just maiden it on the Friday.
#148
It's got a P80se in it. Should be a good combo I think
ORIGINAL: mtnitro
Hi Jeremy
Look's good, what size Jet Cat do you have in there?
Hi Jeremy
#149
Hi all
I was asked a question today via emailregarding the flap mod i made to my Viper and thought it might be usefully to others
Question
I''m maidening my Viper Jet next Sat and was wondering if you could tell me what amount of down trim you have for your take off and landing flap.
Also I did the mod to flap horn like you did, do you find it has a bit of play upwards when set level to the wing?
Reply
Measured at the inboard of the elevator I have 3mm of down elevator for take off and a further 1mm for landing.
Ihave 6mm up aileron or "crow" with landing flap, thishelps negate large amounts ofelevator trim.
I dont have any "crow for take off flap.The flapsare set to 32mm for take off and 50mm for landing.
Its also got a 4 sec slow down set on the flapto smooth every thing out.
Backlash on flap
I do get a bit of up play when the flaps are neutral and was a bit worried at first but its been clocked on my GPS at over 230 mph and has not fluttered yet.
I think perhaps I put the flap horn a little too rearward and its a little short but it dose give good leverageevery were but at neutral.
I gave it some thoughttodayand think I have cured the upward backlashcompletely by glueing a wedge under the linkage, see the pics it works a treat!
Regards Mark
#150
The only other mod ive made to my Viper is to place wedges between the carbon plates and the UC to splay the legs outward a bit.
I thought they looked a bit odd when straight, allmostas if they were splaying inward as std when it sat on the ground.
I also poped a wedge behind the nose wheel retract unit to lean it forward a bit.
When retracted the joint on the nose wheels trailing link is now only just inside the wheel well.
Its only 2-3deg and prob only makes a small differance but i got board one evernig so tinkerd
They handel wellon the ground anyway I think it just looksa littelbetter?
