JET LEGEND VIPER BUILD THREAD
Reply
Old 10-09-2012, 03:54 AM
  #176
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JET LEGEND VIPER BUILD THREAD
Hi William,
Looks like a good holiday!! I hope to get mine up again very shortly, Haven't had time recently to do much flying
Jeremy_D is offline
Old 10-09-2012, 03:55 AM
  #177
madmodelman
madmodelman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
William, you are quite mad!
I've had 24 flights now, unlike you I went the safer route, over the moon!
Regards,
Gary.
madmodelman is offline
Old 10-09-2012, 03:57 AM
  #178
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great photo!! I'm only up to 12 flights on mine so far
Jeremy_D is offline
Old 10-09-2012, 04:31 AM
  #179
keweiliang
keweiliang's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary,
Your photo is very great.
William
keweiliang is offline
Old 10-09-2012, 04:34 AM
  #180
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks William, not quite as great as your flying though!
Old 10-09-2012, 05:02 AM
  #181
steve2972
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gary,
I thought your flying was pretty sweet last Saturday
Steve
steve2972 is offline
Old 10-09-2012, 05:41 AM
  #182
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Steve, and thanks for your help keeping an eye open for me.
How's your Reaction coming on?
Old 10-09-2012, 05:54 AM
  #183
steve2972
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dinged it whilst all the messing about on Saturday trying to sort the crappy ashlock connectors[>:].Its a fair old lump and is awkward to manoever.I`m going to repair tonight/tomorrow and then test fly it with a friend on Saturday at our local club.
Old 10-09-2012, 07:19 AM
  #184
sidajili
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
William, this is crazy!!!... but then that's the fun of RC... really pushing to the limit and beyond boundaries... no pilot gets to die... pockets only get burned. ha ha.. Am surprised the airframe handled that 'kiss-and-go'
sidajili is offline
Old 10-09-2012, 11:13 AM
  #185
essyou35
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, can someone answer these for me?
I have a Kingtech K80, good match for this jet?
I have a modellbau f-86D with a K80, will the viper jet be faster with the same turbine?
Finally, I fly my f-86D on grass all the tiem with no issues at all, can I expect the same from the viper or will it not do good on grass?
What about the intakes, will they be sucking up all kinds off dead grass and junk?
Thanks!
essyou35 is offline
Old 10-09-2012, 12:28 PM
  #186
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It'll be ok in the air with that engine but may struggle a bit for grass take off.
It will be faster than an F86 when it gets wound up.
The landing gear will handle grass ok.
Get a fod guard.
Old 10-10-2012, 05:52 AM
  #187
essyou35
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info. I am curious why it would struggle on grass? the f-86D I have takes off like a bullet on grass. The wet weight is about 22-23 lbs. Does it have smaller tires or something?
essyou35 is offline
Old 10-10-2012, 06:34 AM
  #188
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, if you are flying off really smooth short grass you'll have no issues, I'm probably biased on that point as the grass strip I first flew jets on was very rough.
Old 10-10-2012, 07:42 AM
  #189
kasi122
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
Hi, I have both planes, the F86-D and the viper from jl.
The thing why the F86-D starts easy from gras is, because the position of the main-gear ist behind the cg and will roll much better.
F86-D (Modellbauusa) owners know, tha the planes lifts up the nose very easy and the jl viper doesnt. You need much more power to get the jl viper rolling. I have the cg on the viper 30mm behind the factory setting and with a 9kg thrust turbine i still need about 70 meters to lift off.
The F86-D lifts off after 50 meters.
best regards
Andi
kasi122 is offline
Old 10-10-2012, 07:51 AM
  #190
ceffi
ceffi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
the grass should not be so long. A short cut is okay for using a KingTech 80.
I messured mine last weekend.
With the Merlin 100 max speed 135kts.
CG 35mm behind the original.
Cuted out the airintake and I use an other tank.
3mm down elevator by flaps in landing position (60mm).
Christian
ceffi is offline
Old 10-10-2012, 09:03 AM
  #191
kasi122
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi ceffi,
Ich have the same setup and i use a pahl power turbine with a real thrust of 9,5kg.
Measured max. speed with the futaba gps: 299km/h -> 186miles/h -> 162 kts
Andi
kasi122 is offline
Old 10-11-2012, 06:52 AM
  #192
essyou35
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is there someone that can give me some measurments for the retracts and struts? I have some springair trailling link on my f-86D I am curious if they will fit this or not.
Need to know the retract base dimensions, and how long the struts are.
essyou35 is offline
Old 10-13-2012, 10:59 PM
  #193
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another Viper in the Canadian scheme took to the air today. This one had a VT 80 in it and it flew great and looked fantastic in the air.
One quick question, I want to increase the travel / strength in the main struts. I put the air nipple in to pump more air and what I can only assume was shock oil started to come out so I stopped. Has anyone tried to adjust the main struts with air?
Jeremy
Jeremy_D is offline
Old 10-14-2012, 12:13 AM
  #194
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, I had to do mine as it sat on full mains leg deflection when fuelled for the maiden.
Pumped up in 3 second blasts until I got the correct ride height/stiffness. Didn't see any oil leaking though. I have noticed over time that there are signs of some lubrication on the oleo,s so there must have been some oil in them from the factory.
Did you overpressure them and blow the oil out ?
Gary.
Old 10-14-2012, 12:21 AM
  #195
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No it came out when I put the nipple on. I might just leave it, it sits lowish on the back but there is still travel for shock absorbing on landings
Jeremy_D is offline
Old 10-14-2012, 12:27 AM
  #196
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats a bit strange as there is a one way valve behind the nipple obviously to keep the air in. You should be ok as long as they don't bottom out too much on landing.
Old 10-14-2012, 12:32 AM
  #197
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just out of interest when you put the nipple in did you do it all the way in? I think that might be my problem, I threaded it all the way in and as I did the last turn, thats when the oil came out, maybe I need to go almost in and the air will push the valve open?
Jeremy_D is offline
Old 10-14-2012, 12:49 AM
  #198
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you opened the valve then, just two or three threads from memory did the trick, if some a little air escapes it won't hurt.
Just use short pulses because if you over inflate it's a wheel apart job!
Old 10-14-2012, 12:51 AM
  #199
Jeremy_D
Jeremy_D's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Gary,
I think that's what happened which is why some oil got out. I just tried it screwed in a few turns and gave a few second bursts of air and it feels much better.
Cheers
Jeremy
Jeremy_D is offline
Old 10-14-2012, 10:28 AM
  #200
madmodelman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're welcome, sorry about late reply, been flying! (And watching Felix!)
Reply
Display Modes
