If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    May 2003
    rochester, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JMP Accumulator - tips?
    Finished installing my JMP accumulator for the 200SX in the UB after leaking UAT (air and fuel leak not responsive ot PTFE wrapping etc..)
    Was wonderinf if those WHO USE THIS have tips for getting this thing running perfectly? Tom told me to place the "in" from the tanks at the highest point and I have done this -it is mounted 45degrees which he states is fine.
    I was going to do my usual fill, maybe "drain" a few second off the fill line and then cap. Then start and observe
    Should be that simple right? I have never had one where I couldnt see inside. The rest of my install to the tanks is solid, safety wired and not leaking with pressure tests.
    Thanks for any thoughts,
    Dave
  2. #2
    Join Date
    Apr 2002
    SANTA ANA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: JMP Accumulator - tips?
    Dave,
    That little part about draining "a few seconds off the fill line" is the key! The Accumulator needs to be purged of all air and that is exactly how it is done. Make sure that the Accumulator actually gets the "final fill" from the onboard tank backflow and it'll work great.
    David S
  3. #3
    Join Date
    May 2003
    rochester, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the reply!
    Dave
  4. #4
    CraigG's Avatar
    Join Date
    Jan 2002
    Sautee Nacoochee, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just fueled up all the tanks through the Accumulator the first time, making sure not to get any air in through the fill line when I capped it off, checked for leaks and eventually flew it. No problems ever since. Mine is mounted vertically.
    Craig
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #5
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine is mounted vertically in a skygate hawk.  Yesterday I noticed bubbles going into the pump when I throttled UP.  There was not a single bubble coming INTO the ACCU from the on board fuel tanks, but several bubbles going up into the pump from the center feed line of the ACCU.
    I have not followed the above mentioned purging procedure.  I simply fueled up using the fuel line and started.  If we drain out a bit from the "fill lines" wont air go into the ACCU when you remove the tube to cap it off?  I dont understand why this is a must as other bubble busters dont need this method of purging.  Is the ACCU designed differently that it needs a reverse flow through the main tanks and the fill line?  Is it mentioned in the instruction sheet?
    Anurag
  6. #6
    Join Date
    May 2003
    rochester, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I pinch the line afte reversing flow (draining to purge) to cap it without air going back in the line.
  7. #7
    Ragz's Avatar
    Join Date
    Dec 2001
    Nagpur, INDIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK i understand this.  Do you do this "pinch" with other bubble traps as well?  Is this a must with all air traps?  Or only the accu.
    Anurag
  8. #8
    Join Date
    May 2003
    rochester, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I do. I just bend the tubing and place the stopper in.
  9. #9
    ww2birds's Avatar
    Join Date
    Feb 2003
    Katonah, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I installed a little jetcat valve inline with the drain line between the accumulator and the plug, originally as a "belt and suspenders" strategy in case the plug on the fill line leaks (which is a fatal issue...since the bubble trap .. anyone's .. will empty first), but find it very useful to make sure NO air ever gets into the line .. just shut off the fuel can pump when tanks full, then shut the jetcat valve, then plug the fill line at your leisure :-)
    Did it on one of my more expensive planes, and have been replicating across the others since it works so nicely.
    Agree 100% that the JMP accumulators are nice and 100% trouble free. BV states correctly that you don't get the diagnostic value of seeing a UAT collapse to show fuel plumbing impedance issues, and you don't see air over the fuel at the end of the flight .. but you CAN watch how long it takes for the line from the JMP to the last main tank to flow liquid after starting the fuel fill .. which tells you how much air was in there, if any.
    Dave
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
