Lipo Fire in Garage
Lipo Fire in Garage
I couldn't tell if the charger went first or the lipo. Really doesn't matter. This incident just causes me two solid days of grief. I had to completely gut my shop, and hand clean ever single item, scrub the walls and floor and all tables, because of the thick black soot covering EVERTHING!. We are fortunate this didn't end up like several others whos houses burned down.
This should serve to others as a wake up call to make sure that you NEVER leave a charger on all night and NEVER charge your lipos in the jet.
Andy
Andy
RE: Lipo Fire in Garage
ORIGINAL: hooker53
Andy. Sorry about the fire but like you said, glad you caught it early. What rate were you charging at?
I had a Lipo fire in the van while charging. Rather than topping of the packs, the less intelligent chrager recognized the pack as a depleted pack with an extra cell voltage. I grew too comfortable with the charger, and failed to double check manually, don't plan to make that same mistake.
What kind of charger were you using Andy? Btw, glad all else is ok!
Barry
Barry
My Feedback: (21)
WOW!!!! damn your lucky lil fella. glad to hear it didn't burn the whole house down!
ORIGINAL: AndyAndrews
I couldn't tell if the charger went first or the lipo. Really doesn't matter. This incident just causes me two solid days of grief. I had to completely gut my shop, and hand lean ever single item, scrub the walls and floor and all tables, because of the thick black soot covering EVERTHING!. We are fortuneaute this didn't end up like several others whos houses burned down.
This should serve to others as a wake up call to make sure that you NEVER charge your lipos in the jet.
Andy
Andy
Hi Andy
Glad it didn't got into big damage. I always take my lipos out of the plane to charge, but many times there are other flamable objects arround.
From the pics, seems that you did't have the balance plug connected. I always balance lipos during charging so that the balancer can detect peak voltage per cell.
I was planning in buying one of these 4 pack charger at 1 time, but now it seems that those cannot beat my old reliable Orbit charger. Still prefer to wait 3 hours to charge 3 packs
Good luck in the next charge
regards
Nuno
regards
Nuno
I only charge lipos when I am actually in the workshop, if I am packing up I will take them off the charge and put them back in the ammo box I store my lipos in.
I even got out of my bed once as I remembered there was a lipo with a new turbine still in the cardboard box that arrived that day, thought afterwards I was mad, but have since heard many stories of lipo's going on fire for no reason and reading what happened to you, I dont think you can be careful enough.
The Ammo box full of lipos is now going to the shed and out of the workshop!
Andy, glad to hear it wasn't more than a scare... It could have been a lot worse.
Now, what I find really interesting is that with all the info available, people are still charging in their planes. Check this thread from a few days ago http://www.rcuniverse.com/forum/m_11124688/tm.htm
As I mention in my post towards the end: it is not even about being there. Once it starts it can be pretty incontrollable. It is about having a plan, charging on something like concrete like Andy's for example.
My Feedback: (21)
FL
Sorry to hear about your very close call! Glad you are OK and the house! Never ever ever leave your lipos to charge unattended without the casual stroll by and overnight while sleeping is a big ABSOLUTE no no!
Is that one of the chargers that Hobbyking sells? It appears to be.
More info. It was a Turnigy charger. Nope I wasn't using the balance port.. (I know.. ) and the battery was a Sky Lipo 1000 mah, 30c continuous, 60c burst.
I was charging all four batteries at once at 1 amp. There is no reason you shouldn't be able to charge all four at once with this charger. Also note that I kept them separated but I guess I got the one to close to the charger..
The other pick is of the other charger which was charging some Nimh batteries (in the jet) and I was charging a Nimh battery in my fueler along with another lipo which was in a clay pot. I don't think I will ever trust charging anything on a table even if its not a lipo seeing that charger burned up like that.
My Feedback: (9)
Always use the balance port and check the IR on each cell after each charge. I do charge my ECU lipo in the plane but I check the IR on each cell and balance it everycharge. A bad cell will show it self before it lets go with an increase in IR.
Glad no one was hurt and the damage was small.
AR
I have been using a charger like that for 3 years and it is the best $100 I have ever spent. The charger is not necessarily the problem here. Could have been the batt, a damaged cell in the batt, ect. All batts and components from any manufacture are capable of a malfunction. The only problem I have ever had was with Fromeco ions with a fromeco charger for those specific batts. No way to screw it up, not way to adust the current, just plug it in. When i tell you they exploded, I thought a tree had fallen on the house. THey were outside being charged and this was the ONLY time I had ever removed them from the jet to charge them. I thought it was relatively safe to charge those in the airplane. Had I not taken them out, the front end of my Flash would be gone!
Since that, I will not charge any batt in a jet or a foamy , not to mention the garage or in the house.
Cody
Cody
ORIGINAL: rpm303
Thanks for the post Andy. Was thinking of buying that charger, now I think not !!!!
Glad no one was hurt.
