Reload this Page >
jetcat p20se experience
Old 07-05-2012, 07:40 AM
SniperWj
Default jetcat p20se experience
did any one here experience jetcat p20se trowing blue flame while advance throttle?
i had good luck on my first p20se but with bad luck on 2nd unit.
the 2nd one do not start easy as the first one it will flame out during start sequence,even you get it start it will not run smooth..
on the bench or on the airframe it will give you loud bogging sounds and blue flame when you advance throttle,from there you lost throttle control,have to back off stick to idle
for about 10-12 secs then the turbine will back to idle.
yes i did send it back to jetcat but come back with the same problem.
hope anyone here care to share their experience with this kind of problem.
[youtube]http://www.youtube.com/watch?v=BM1GerLY5vE&list=UUYAPd7gI4op0X8nQVYuiCzA&index=6&feature=plcp[/youtube]
Yiming
Old 07-05-2012, 10:17 AM
Dave Wilshere
Default RE: jetcat p20se experience
You have the correct length of fuel tube between the turbine and valve?
You sent the turbine/ECU and pump back? With the latest Bus type turbines you must send all three back as electronic updates can be in all three units.
Dave
Old 07-05-2012, 10:26 AM
Vincent
My Feedback: (61)
Vincent's Avatar
lower the unaccel 1 down a few clicks and try it. I had a finnicky starting P-20 and what i did was lower the unaccel down until it would not start at all and then go up one click at a time until i got ignition and a clean start. That was all it needed it and now starts and runs smooth every time.
Vin...
Old 07-05-2012, 10:56 AM
SniperWj
Dave
yes
I did all you mention
no
it don't work for me after spending those time and money.
yiming
Old 07-05-2012, 11:06 AM
SniperWj
vincent
I did saw this word in the gsu but I hv no ideal how to adjust correctly.
I see click in your reply do you mean the trim on the throttle side?
advance the trim untill the first click you get the 3 blinking light I'm i correct?
yiming
ORIGINAL: Vincent
Vin...
Old 07-05-2012, 09:32 PM
Henke Torphammar
Henke Torphammar's Avatar
With the nifty yellow socket you could easily switch engine too se if it's in the engine or the FADEC system.
Old 07-05-2012, 10:36 PM
SniperWj
henke
that said I can trouble shoot with component from kingtech k80f?
yiming
Old 07-05-2012, 10:56 PM
smitty1001
My Feedback: (29)
smitty1001's Avatar
yiming,
I would think that is NOT what Henke was saying! I'm sure he meant - maybe try your ECU from your correctly running P20 (which you mentioned in your first post) with this one to see if you have the same problems. The gaspar xicoy has far different connections than the Jetcat and I'm sure neither company would fancy you mating those two systems up!
Also, the uaccel1 setting Vincent is talking about is not related to the throttle trim at all - by "clicks," he meant the +/- on the GSU... you access the setting by powering on with a certain button held down I believe (been awhile since my purple days )
Just an observation from a browser - good luck.
Smitty
Old 07-05-2012, 11:37 PM
SniperWj
snotty
I did swapping the ecu still giving same problem!
we unable to changing those setting on v10 ecu
yiming
I
Old 07-06-2012, 05:48 AM
Vincent
My Feedback: (61)
Vincent's Avatar
Yiming,
To adjust the unaccel 1 you need to plug in the gsu and turn on the rx switch.
push the limits key first then the plus key and release. this will bring up the unaccel 1 screen. there will be a 3 diget number posted to the right.
hold down the change/select key and you will see an arrow pointing at the 3 digit number.
use the minus arrow key to lower that number. try two clicks and try a start. if it works then leave the setting there, if not keep adjusting that number down until it either starts smooth or it wont start at all.if it wont start at all then gradually move the number back up.
you can exit this screen by either cycling power or holding down the select key and use the arrow to get back the run screen.
note: remember the starting number (setting) from the factory so you can have a reference point.
Vin...
Old 07-06-2012, 07:17 AM
SniperWj
vincent
ok,got that value lower by two click!
will try later in the morning! can't wait!!!
ps:for my case to enter u-accerlr1 I need to hold dwn "limits" then press - once then press + to call up that screen
by doing that bring back my good old day memory playing nitendo game searching special weapon
yiming
Old 07-06-2012, 01:34 PM
kimhey
ORIGINAL: SniperWj
I need to hold dwn ''limits'' then press - once then press + to call up that screen
yiming
Remember it like it was yesterday
Kim
Old 07-11-2012, 09:33 AM
SniperWj
im here to thanks vincent on his help. the p20se made her successfull first flight during the weekend!
yes, i did what vincent say go to unaccel 1 and give two click - and im done!
perfect start as well as perfect runnng !!! happy!
Yiming
Old 07-11-2012, 09:37 AM
Vincent
My Feedback: (61)
Vincent's Avatar
good news Yiming!! enjoy the P-20 they are little gems
Vin...
Old 07-11-2012, 09:48 AM
drdoom
My Feedback: (9)
Mine has alway started very well. But shut off mid flight. I lengthened the fuel line and Things were better I bought a new Trap tank, and it worked well. I do get poping and blue flames on start. The last time I flew it, it quit on the runway taxiing out to take off, relit flew, landed and it quit when I made the turn around to taxi back. It gave a "LOW PUMP Voltage" for the reason it quit.
Old 07-12-2012, 05:11 AM
Vincent
My Feedback: (61)
Vincent's Avatar
ORIGINAL: drdoom
Mine has alway started very well. But shut off mid flight. I lengthened the fuel line and Things were better I bought a new Trap tank, and it worked well. I do get poping and blue flames on start. The last time I flew it, it quit on the runway taxiing out to take off, relit flew, landed and it quit when I made the turn around to taxi back. It gave a ''LOW PUMP Voltage'' for the reason it quit.
I assume you have about 1meter of fuel line from the pump to the motor. It sounds like you have a sticky fuel pump but you can try bumping up the min rpm by 5k and see if that corrects the problem.
Vin...
Old 07-12-2012, 06:12 AM
drdoom
My Feedback: (9)
Yes Just a bit over 1 meter. Scott at Jetcat USA also suggested that the pump could be tight and Just needed to be run.
I just love this little turbine. It is Great..
