BVM Air Fill Valve- How do u get air in them?
AE, US MINOR OUTLYING ISLANDS
I never had any of these on previous jets. I thought I'd splurge a little and get some fancy high buck valves. So what's the trick to get air in them. I've tried everything in my shop.
http://shopbvmjets.com/zencart/index...o51531obu0cd54
RE: BVM Air Fill Valve- How do u get air in them?
You can use this:
or a 'normal' car tyre pump fitting should work, or you can get some airline and push it in the hole in the top (ignoring the threaded bit).
Bvm does sale the screw on attachment but I just a piece of air line and insert it into the hole. It works best that way, specially if u have more than on fill valve.
FL
ORIGINAL: FenderBean
Fender is pretty close....inserting it is easier of you cut a bevel on the end of the pump airline.
Shown in the photos are two methods....one involving the screw on Air Fill Chuck BVM #2192, and an alternate with the beveled air line.
Also shown is a football inflation needle screwed into the Air Fill Chuck. Cut the end off the needle and deburr it before inserting it into the air line.
The BVM valve comes with some white tube that's the correct size to insert into the valve for filling, well it does in the UK.
Mike
Mike
OPPS! Thanks anyway guys, Stupid me!, I finally figured out that I had a fitting downstream in the system leaking. Fixed the leak and everything works fine now with my trusty old mini 12v portable compressor from wallmart and the stock nozzle.
you are correct sir same in states
ORIGINAL: BaldEagel
Mike
Mike
tapered air line works the best.. just cut it to a taper like show in Harley's post, and taper it a tiny bit w sandpaper.. no need for a bit....
FL
ORIGINAL: carbunkle
For those wanting to use a chuck, I like this one from BVM because of the swivel feature. Dreamworks sell it too
http://shopbvmjets.com/zencart/index...jmvfb4jribu640
Here's my idea that many are using. Football inflating needle cut off to 3/4 inch. Then slide 1 inch piece of air line on it. Just push in and seals at end of needle. Alittle thin CA will keep tubing from coming off after many uses. I'll try to get a pic out soon. Scott
FL
ORIGINAL: highhorse
My Feedback: (9)
My valve started leaking air without using it.
Building a jet and last time that presurized the sistem to 100psi it was all ok. Now a few month later the valve leaks air instantly. Any sugestion?
Tried some car dashboard silicon to moisten the inside but did not worked, tried vaseline and did not worked.
Not happy having a expensive feed valve that ruined by itself.
Cheers
Juan
I've seen them ruined by pushing the tube in too far! They can leak after one insertion like that... If that method is used a sleeve should be added to stop the tube being inserted too far. It not good when they are returned as faulty because of this...[:@] I've been had!
Dave
Dave
My Feedback: (67)
ORIGINAL: Harley Condra
Insert the airline JUST deep enough to clear the beveled end to avoid damaging the internal check valve.
I just learned the approach from this thread; rather than screwing a fitting onto the external threads to fill. Just insert the tube (hold in place with light pressure - only insert a short distance) and fill. Yes, the bevel at the end helps. This works perfectly for me. Now I appreciate the short length of white tubing that comes with the valve. This is sooooo easy. BVM Air Fill Valve is even nicer than I previously thought!
