Home made UAT tank
RE: Home made UAT tank
Hi Marcelo, presuming you want to make your own bubble trap tank with a fuel filter a la BVM , you can read some information here:
http://www.rcuniverse.com/forum/m_41...tm.htm#4195561
http://www.rcuniverse.com/forum/m_10...m.htm#10644178
I personally use and prefer the center pickup system, also known as header tank. Pretty simple and effective IMO.
Best regards, Enrique.
I have been looking for someone to show this myself, guess I will just make one myself and see how it goes. I bought the same paper filters that my MAP hi flow UAT has from Autozone. I have read the small baby bottles are what people use or you can get the small plastic bottles from mcmasters
ORIGINAL: FenderBean
The filter is an automotive fuel filter, with the rubber gasket on the end removed and a washer (with a brass tube soldered to it) is JBWelded to it.
The cap /brass tube need to be aligned, since the holes are not in the center.
Two additional brass tubes are fitted, flush with the bottom of the rubber stopper - #1 for filling and # 2 for vent.
Simple, inexpensive and most importantly ... they work!
Greg
I consider myself an expert in UAT types tanks. Here is one I'm working on, there''s a little way to go until it's looks ok but I think it shows the amount of R&D I have already put in. What do you think?
Thats awesome
ORIGINAL: jason
