WANTED bobcat flex plates (bvm 5567)
Cleverly broke my flex plates taking off (rough beach!) and Al's hobbies cant get them in anymore.
They arent just for the bobcat, also fitting the Electra/F-16/F-80/T-33/AggIII/Viper/Mav/ Bandit/BobCat XL
Anyone have any lying around? Bit stuck
Thanks in advance,
Martyn
Thanks in advance,
Martyn
RE: WANTED bobcat flex plates (bvm 5567)
I believe dreamworks has them.
http://dreamworksrc.com/catalog/bobc...te-p-1210.html
http://dreamworksrc.com/catalog/bobc...te-p-1211.html
FL
Another thought...
You can also use the aluminum flex plates instead of the injection molded 5567's.
http://shopbvmjets.com/zencart/index...num+flex+arms+
Thanks for the replies, sorry i forgot to state it is the original bobcat not the composite one, and its the nose flex plate.
Harley, its really similar to that one you linked but has a little bobble on the end (would be on the right hand side in your pic) where it is secured at the front.
I could try BVM but they take ages and costs alot to ship to UK
FL
The aluminum ones I referred you to are a drop in replacement for the injection molded ones you are seeking.
The aluminum flex plates do not require the front screw lug. They are cantilevered from the aft mount position.
If you can locate and install a set, you will never need to replace them.
