Wanted, nose pin
My Feedback: (32)
RE: Wanted, nose pin
Check with BVM. They have a pin upgrade for the nose gear of the Skymaster L-39. Not sure of the size though.
http://shopbvmjets.com/zencart/index...roducts_id=549
Kirk
Kirk
My Feedback: (13)
Pete,
I had the same pin bend rather than break on mine. What I did was to buy some 6mm drill stock at a local supplier. I then cut it and milled a groove for the e-clip with a dremel and a cut-off wheel. Problem solved! That was a cheap and easy solution
Dave
Dave
Funny that,
I've just made some 7mm pins for someone who has gone through same thing!a
Since increasing the diameter, there has been no more problems.
Obviously you have to open up the bush hole or remake it.
JT
JT
My Feedback: (251)
HI all, thanks for your replies, just bought some pins and mini gages from Mc Master Carr.
Rcpete
http://www.mcmaster.com/#atmospheric...gauges/=irlhsf
http://www.mcmaster.com/#headed-precision-pins/=irlilx
Rcpete
