If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 21 of 21
  1. #1
    DelGatoGrande's Avatar
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    totally enclosed linkages..looking for troubles
    ..ok here it goes ..i try to hide my rudder servo..
    what option we have for a totally enclosed linkage setup?
    Im not interesting in a torque tube solution (torque tube= extended rod on the hinge line in the fuse)
    or for "flap" setup with one side to be the hinge.
    Im looking for center hinge set up for simetrical move with the servo in the fin.
    How about the swingees ? Have try them on a small glow but for jet use is there any heavy duty edition out there im not aware of? ...or im looking flatter troubles here cause might grow a slop?
    How the full scale set up theres?
    Thanx for your time and the info in advance gents.
    Best Regards George
    www.rcjet.gr \"props are for boats\"
  2. #2
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: totally enclosed linkages..looking for troubles
    A full scale king air uses a torque rod setup that goes into the tailcone. Which then bolts to a control arm that has 2 cables on it and a spring on either side.
    Thomas W.
    Scratch built: 1/7 F-14D Tomcat, 1/4 TA152H, 1/6 EA6B Prowler up next?
  3. #3
    wojtek's Avatar
    Join Date
    Dec 2001
    nj, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The BVM Rafale used a 1/4" metal rod up through the hinge pivot center line up into the rudder, and is bent back around 1". The rudder has a 1/4" groove carved in a hardwood block as a receptacle for the rod. On the inside, the rod has a bellcrank with pull pull arms to the servo horn. The inner ailevators are engaged in a similar way. No external linkage. I'm not sure if my description makes sense .. maybe someone could post pics of the setup ?
    ~V~
  4. #4
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thank you wojtek and Thomas.. im aware of BVMs Rafale setup, but in my case i have no space left to go in the fuse for a torque tube ,thats why its out of the equation[&o]
    Best Regards George
  5. #5
    smchale's Avatar
    Join Date
    Jun 2002
    Philadelphia PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I agree that swingees wouldn't be strong enough. Have you looked at the Rotary drive systems (RDS)?
    http://www.irfmachineworks.com/rds/
    Sean McHale - Philadelphia, PA
    "Strive for simplicity. You never have to repair what you leave out." - Bill Lear
    Dream. Build. Fly. SCALE. - www.strictlyscale.com
    Kingtech Turbines - www.kingtechturbines.com
  6. #6
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi there Sean,
    im aware of RDS but dont know how slop free they can be.
    They require a wide gap to work and dont know how tight the clearance will be after a number of flights or get bigger and cause flatter when centre..
    plus i feel that RDS kills servos torque .. and im in a need to use a 25kg of torque servo and hoping to set it 100% travel each way
    thank you
    Best Regards George
  7. #7
    Join Date
    Jul 2006
    Norfolk , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    George
    On my Boulton Paul I have a servo below the rudder with the servo centre in line with the hinge of the rudder. The servo arm has a pin at the end of it that engages with a small slot in the rudder.
    John
    John Wright
  8. #8
    Nick Yuhasz's Avatar
    Join Date
    Dec 2001
    Amherst, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used the RDS system on both my Skymaster F-18 and F-5 for years with no problem. I just don't like seeing external linkages on rudders.
    Nick
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1792705   Click image for larger version.
ID:	1792706   Click image for larger version.
ID:	1792707   Click image for larger version.
ID:	1792708   Click image for larger version.
    Nick Yuhasz
    Amherst, Ohio
  9. #9
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi there John
    i have no space left below the rudder [&o]
    If i had i would go the way you described or with torque tube.
    By the way servo center dont have to be inline with rudders hinge ,the further aft servo is placed the more throw is used and less stress.
    Cheers mate
    Best Regards George
  10. #10
    tahfiet's Avatar
    Join Date
    Mar 2002
    RaesfeldNRW, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi George!
    Just get some decent RDS linkages. Graupner has them for standard servos and I am using them in a Jetco XL on the rudders. The linkage is as slopfree as you get ist with regular linkages and once aou understand how it works and how to mount it right, you will not loose any torque.
    Best regards,
    David
    Spitfire brotherhood #103
  11. #11
    Boomerang1's Avatar
    Join Date
    Jun 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have only used Swingee's once on the rudder of a 40 size model.
    It was slop free for a while until I bumped the rudder getting it into
    the car. It then had miles of slop & being buried in the fin I made a
    real mess removing it.
    My BVM Sabre uses a torque rod with a metal arm on the end. Cables
    then to a servo mounted forward. Doesn't take up much room & being
    all metal would be heat resistant. It's not real solid though & feels a bit
    springy. Room for that set up? John.
  12. #12
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi there David,
    this heavy duty RDS looks better...my rudders is tall so i might use two RDS servos in it and mach them from my powerbox !
    ..is there a place to find this in stock? Graupner says in a year time http://www.graupner.de/en/products/3928/product.aspx
    lindinger and schweighofer have them out of stock too[&o]
    danke
    ...John no room at all mate [&o]
    thanx
    Best Regards George
  13. #13
    mr_matt's Avatar
    Join Date
    Dec 2001
    Oak Park, CA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi guys,
    Sorry to dig up a (relatively) old thread but this is what my search turned up.
    I am looking for these same internal linkages. I saw what Dave Platt had on his hunter (swingees) and I was not impressed with those (although a local super builder used them for years on DF speed planes).
    As for RDS, Nick how fast would you say you had that F5 up to? It seems to have the advantage of a relatively short rudder. I am interested in how hard (fast) people have pushed these RDS systems.
    I looked at them several years ago, and to me the only relative disadvantage was the potential for slop in that pocket. The fit between the rod and the pocket is critical. What do you say Nick, any more details you can share?
    Matt
  14. #14
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I end up going with torque tube and like it a lot.
    Made some test with RDS and didnt like them .One weak spot is that RDS trying to split/open the fin side at the rod exit hole.
    Another down side is that connection direct on servo gear kills resolution big time since you reduse alot the end points.
    RDS not for jet use..at least for me
    my 2c
    Best Regards George
  15. #15
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you have to reduce the end points to much in a RDS system, you can always go with a different bend angle in the rod, as the rod bemd angle dictates the surflace deflection angle
    Thomas W.
  16. #16
    mr_matt's Avatar
    Join Date
    Dec 2001
    Oak Park, CA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thomas you beat me to it. My question is, does the reduced bend angle increase the affect of slop in the linkage pocket?
    Matt
  17. #17
    invertmast's Avatar
    Join Date
    Dec 2003
    North Port, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Matt,
    The pockets are normally made from a very stronf but smooth material (g10 or formica). I buy the premade pockets from irf machine works and they are a snug but smooth fit in the wires. As long as the wire is a good tight fit with no slop and the servo and surface is hinged securely there should be minimal to no slop in the system.
    The way the bent wire was described to me, was comparing it to a conventional control horn. A 45* bend was like a 1" horn, 22.5* like a 2" horn, etc. the bend angle dictates deflection angle.
    Thomas
    Thomas W.
  18. #18
    Eddie P's Avatar
    Join Date
    Feb 2003
    Reno, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Could someone post a picture of the BVM torque tube linkage? I'm in the same predicament right now and I'm trying to find a functional, reliable and relatively simple solution. I do have a lot of room below the rudder and to the side of the elevators so the torque tube linkage might be really perfect. I know... I want it all - easy, fast and cheap. Well I know it won't be cheap it never is cheap with jets.
    Flying is Freedom
  19. #19
    Join Date
    Dec 2001
    Amherst, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mr_matt
    Hi guys,
    Matt:
    I would say that my SM F-18 was flying no faster than about 150 mph, but the top speed for my SM F-5 was about 170mph. As Thomas stated, I always purchased the pre-built pockets (very strong and I embedded them in aeropoxy) plus the "Heavy Duty - 1/8in" version torque rods from IRF Machine and used digital "wing servos". There was absolutely no slop in that original version from IRF Machine.
    Nick
    Nick Yuhasz
    Amherst, Ohio
  20. #20
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Eddie P
    thats a SkyMaster torque tube(rod) i use
    Best Regards George
  21. #21
    Eddie P's Avatar
    Join Date
    Feb 2003
    Reno, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks DGG. There is also another method of using a pin mounted to a servo arm where the servo is mounted in the fuse below the rudder - and there is a groove int he rudder base that accepts the arc movement of the servo pin. Another direct connection method with no linkage visible. I'm sure you mentioned however that you might not have the room for this? I was looking into one of these setups in a scratch build for elevator and rudder. I have a ton of room in the empennage area by the stabs and flight controls in my build. Any known disadvantage to this type of setup that you know of for elevator as well as rudder?
    Flying is Freedom
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
