If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2002
    Port Rowan, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Turbine Exhaust Pipe Clearance and Temps
    Hello I am working on a new project and have some questions regarding exhaust pipe installations. My current jet is a twin boom so this is new to me. I am planning on a glass fuse with wood or composite formers a dual wall pipe and no bypass. Are there any guide lines as to how close the pipe can be to the fuse formers? How much clearance is required between the outer wall of the pipe and the inner diameter of the fiberglass exhaust nozzle of the fuse? I assume there needs to be adequate space to allow enough air to flow around the outside of the pipe and out the back? What is the safe temp range around the pipe inside the fuse and temperature of the fuse from the radiant heat?
    I have a chart from Jetcat that states a pipe of 85mm od for P70-P160 turbines. Would a fuse with an exhaust nozzle of 100-110mm allow enough airflow arround the pipe to keep the temps safe?
    Geoff
  2. #2
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Turbine Exhaust Pipe Clearance and Temps
    A safe bet would be to contact Tams, he makes pipes for everything and I would assume he could answer any questions you may have.
    Keith who?
    Xtreme ARF Rep
    Contest Director AMA # 8394
    FAA Registration # FA3W99AXCX
    https://www.youtube.com/channel/UCE_...BAxA8bHVCw3VQQ
    https://www.facebook.com/FenderbeanRCBuilds
  3. #3
    Join Date
    Jul 2006
    Norfolk , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Colin Straus has done some proper testing for RCJI and the results are in the new supplementary issue with the latest engine tests.
    John
    John Wright
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
