If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 51 to 75 of 208
  1. #51
    Pinnacle Aviation's Avatar
    Join Date
    Feb 2004
    herts, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Making an Ultra Flash into an F-20UF
    Hi Greg,
    I always put the oil paint straight onto the paint without any clear coat, I put the clear on after the weathering and decals have been applied. The paint I use is either cellelous or acrylic basecoat.
    The panel lines are made from vinyl sheet which is cut into 0.8mm wide strips, this is applied onto the model the a coat of primer applied, the primer is then rubbed back until the vinyl appears and then they vinyl is removed to give you a simulated panel line.
    Phil Noel
    Pinnacle Aviation (Professional model builder and painter)
  2. #52
    Scott Geller's Avatar
    Join Date
    Nov 2007
    Andover, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very cool! Nice job.
    Scott
  3. #53
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rich
    Jeti USA Flight Team - DS-16, Xtreme Arf, Fei Bao Jets, Jet Central: SE Rhino 200, Cheetah, & Super Eagle owner
  4. #54
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Putting some decals on to finish it off before I grease her up and clear cot her.
    Phil Noel
  5. #55
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Some more shots
    Phil Noel
  6. #56
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A shot of some grease and dirt on the underside
    Phil Noel
  7. #57
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Pinnacle Aviation
    That is some serious nice work there!
    Aw heck, my Flash looks like that and I didn't even have to work at it... LOL
    Oh yea... I even added some deep scratches (read: nose wheel failure to extend) for more of an extra used effect
    Rich
  8. #58
    vease's Avatar
    Join Date
    Feb 2003
    swanley, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vease
    One question. Do you apply the oils directly over the paint or have you put a seal on first?
    Thanks for the reply Phil but I lied.....2 more questions.
    Do you put the oils on neat or mixed with something?
    and what liquid do you use to wipe off the unwanted?
    I used oils on my P47 that you may have seen this year, but not sure I used it correctly?
    Maybe see you Sunday at Baldock?
    Gregg
    UK Meister field rep - TJD Display team - BickleyMFC.co.uk
  9. #59
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Gregg,
    Cheeky another two questions, ok, I put the oil paints on straight out of the tube when the temperature is below 21 degrees, over that I add a very small amount white spirit.
    I wipe it off dry, nothing on the cloth, if I select an area that I don't want much weathering then I put a drop of white spirit on the cloth and remove the oil paint, you have to be careful if you put to much white spirit on the cloth it will remove all of the weathering, if that happens you will need to leave it at least 4 hours so the white spirit totally evaporates otherwise it will affect the oils paints and not give you the weathering results you will need.
    I hope this is helpful, if its not raining to much on Sunday I will pop up in the afternoon and see you there Gregg.
    BTW, love the T'bolt, looks really good mate.
    Phil Noel
  10. #60
    vease's Avatar
    Join Date
    Feb 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks once again for the reply and explanation. The P47 turned out OK but was not easy and I new I was not doing it right. You have just confirmed that!
    I have a very yellow Bearcat nearing completion which needs details showing up so want to do it right this time.
    Thank you!!
  11. #61
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you seen Ali's bearcat I did for him, here's a photo
    Phil Noel
  12. #62
    vease's Avatar
    Join Date
    Feb 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes I had seen that... hope he didn't want it kept a secret!
    Looks great and a very different scheme. He must lose the spinner though!!
    Hopefully I can learn from you when doing mine which will be in this scheme:
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  13. #63
    vease's Avatar
    Join Date
    Feb 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry, I seem to have highjacked the thread with warbird talk!!
    Back to the superb F20 UF
  14. #64
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That's a cool scheme Gregg, if ever you need a hand feel free to pop up with a wing or fuse and I could show you first hand.
    Nah, it's not a secret
    Phil Noel
  15. #65
    vease's Avatar
    Join Date
    Feb 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now that is an offer that the guys across the pond must be very jealous of.
    Much appreciated Phil, hope to see you Sunday at your field.
  16. #66
    vease's Avatar
    Join Date
    Feb 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: vease
    Now that is an offer that many people must be very jealous of.
  17. #67
    yeahbaby's Avatar
    Join Date
    Dec 2001
    FT Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    great job amigo!!! the desert aggressor paint scheme fits the ultraFlash nicely.
    work work work ......livin the dream
  18. #68
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It looks so much better with a couple of coats of flat clear applied.
    Phil Noel
  19. #69
    Join Date
    Jun 2008
    Kempton park, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Phil
    Thanks for all your threads and posts, I really learn a lot reading them. This is something I would like to try.
    I just have one question.
    Once you have done the weathering and decals what do you do as far as prep work before you shoot the clear.
    ie. sanding, cleaning, etc
    Regards
    Neil
  20. #70
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Neil,
    During the process of painting, weathering and applying the decals I am very careful handling the model, once the decals are applied I give the model a blast with an airline to remove any dust, then a wipe with an anti static cloth, no liquids.
    Once that is completed then the clear is applied.
    I hope this is helpful.
    Phil Noel
  21. #71
    furloughed ual's Avatar
    Join Date
    Feb 2002
    Parker, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Does anyone know if the artists oil paints would be compatible under an epoxy based cleaer? I use Klass Kote epoxy paints exclusively but would like to try this weathering method.
    \"somewhere between the port of indecision and southeast of disorder\"
  22. #72
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    As long as you leave the oil paint to harden for between 2 to 3 days you should be fine, but I would always do a test sample.
    Whenever I am trying something new I always do a test sample to ensure that it has no reaction between the different paints.
    One type of paint you have to be careful of is Humbrol emamals, the only way to get over a reaction with this type of paint is to give it a very light dust coat before a heavy coat is applied.
    Phil Noel
  23. #73
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got round to taking some photos today of her put together before I start the final install of the radio, engine and landing gear which I hope arrives tomorrow.
    Phil Noel
  24. #74
    Join Date
    Feb 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Canopy glass fitted
    Phil Noel
  25. #75
    smchale's Avatar
    Join Date
    Jun 2002
    Philadelphia PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Looks great Phil, it's really coming together well. Refreshing look to the popular Flash.
    Sean McHale - Philadelphia, PA
    "Strive for simplicity. You never have to repair what you leave out." - Bill Lear
    Dream. Build. Fly. SCALE. - www.strictlyscale.com
    Kingtech Turbines - www.kingtechturbines.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
