BVM Nose Gear
Reply
Old 10-01-2012, 03:06 PM
Shaun Evans
Shaun Evans's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default BVM Nose Gear
Hi,
Has anyone used the old plastic BVM nose unit (like from the 60" Sabre) with a separate air cylinder instead of the retract servo they were designed for? I have the plastic set and I'm trying to use them for this Sabre build.
Thanks in advance for any help.
Shaun Evans is offline
Old 10-01-2012, 03:23 PM
NickC5FE
NickC5FE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BVM Nose Gear
Yeah i have and they work fine. I would just make sure the trunnion in the gear unit is aluminum. BV updated them years back because that was a high failure point. The plastic housing with separate air ram is ok though..
NickC5FE is offline
Old 10-01-2012, 03:33 PM
DAN AVILLA
DAN AVILLA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a 60" saber many years ago and I converted it to all air. Not a problem. The only thing is the plastic retract frame doesnot hold up well when it is turbine powered. The weight gets to it. If you can find the metal frames or use the new gear it would be better. Dan Avilla
DAN AVILLA is offline
Old 10-02-2012, 05:28 AM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks, guys. I guess what I should have asked was how you installed the air cylinder. The nose cone/inlet lip appears to be in the way. Thanks.
Old 10-02-2012, 07:08 AM
Per Strommen
Per Strommen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put the air cylinder behind the wheel opening with a brass tube "pushrod" on my ducted fan Sabre
ID:	1807182   Click image for larger version
ID:	1807183   Click image for larger version
Per Strommen is offline
Old 10-02-2012, 11:26 AM
ron Sweeney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trim aircraft in Australia make the metal rotating nose retract and the extended air cylinder. I use this on my bvm Sabre. works a treat on grass, Ron.
ron Sweeney is offline
Old 10-02-2012, 11:46 AM
Shaun Evans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ron,
Do you have any pics of your install? That'd be very helpful!
Old 10-02-2012, 06:55 PM
Chris True
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The trick is the bend in the brass tube
ID:	1807380   Click image for larger version
Chris True is offline
Reply
Display Modes
