BVM F-86 (60") Build Thread
RE: BVM F-86 (60
Shaun,
Sorry for my misspelling.
Matt
As I recall BVM did do an AFS Mig 15.. Unfortunately no longer available. I guess that it is no longer economical for BV to produce these AFS kits. The ARFs have taken over as they are more accessible, and probably more cost effective to manufacture. (They are certainly more expensive!!). You might be able to get one second hand.
I have just purchased a BVM P80 AFS, NIB. The kit is 7 years old and untouched.. It will probably stay like that for a while too as I work through my other projects..
Roger
ORIGINAL: mr_matt
Great pictures thanks for posting.
Did BV ever make a MIG 15 AFS? I would love to get my hands on one!
Keep the pictures coming. How much usable fuel can you get in this model?
Matt
Roger
RE: BVM F-86 (60
Hi,
I was about to get a bunch of work done on the Sabre, but then someone sent me this video and it stopped my work cold. I literally almost died. How did I not get into this stuff earlier?
http://www.youtube.com/watch?v=Qlwil...ature=youtu.be
RE: BVM F-86 (60
Ok,
So after recovering from that video, I did get some more work done. I got the carbon tongues glued into the stabs. After the epoxy cures, you have to epoxy some balsa anchors/fillers into the slot on the bottom of the stab. Once everything is cured, you've got a very solid removable stab.
My customer sent me a bunch of Airtronics 94820 digital servos for this plane. I've only used one once before in my E-Flite F-4 on the stab, and I was VERY impressed with the servo...especially when compared to the JR 3421 that they recommend. The rudder servo was fitted to the inside of the fin to measure where to cut the slot, then I assembled the rudder. The rudder is two shaped balsa sides sandwiching a 1/32" plywood center. You have to glue on the balance tab, then final-sand the whole thing to shape. To do this, I used a few drops of CA to tack the rudder to the fin, then use a little masking tape to protect the fin while I sand the rudder down to it.
All in all, the tail group looks GREAT, and the dihedral stabs just set off the look of this bird. Next I'll cut out the main doors...
#32
RE: BVM F-86 (60
Hi,
Yeah, I learned that from the instruction book! They've got some dimples on the fuse to align the stabs, so it helps that the neutral is held somehow. Pretty nifty!
#33
RE: BVM F-86 (60
Hi,
The carbon stab tongues are glued in and the filler blocks are epoxied in and sanded. The thin dremel cutoff disc makes for a nice cut if you're careful.
#36
RE: BVM F-86 (60
Hi,
Thanks, Ron! Once I figure out where/how I want to mount the air cylinders, I'll trim off the extra tabs on the hinges and that should clean that up quite a bit.
#38
RE: BVM F-86 (60
http://www.youtube.com/watch?v=D21EH...ure=plpp_video
This is some footage of my Sabre after d/f conversion, Ron.
#41
RE: BVM F-86 (60
Nice work Shaun, and you are very fast as well!! It would take me weeks or months to progress what you have done in the last few days.
I have always been too frightened to use a dremel to cut out doors or hatches. One slip or shake of the hand and the door can be ruined. I prefer to use the Excel #13 blades (A John Redman tip) or a balsa saw with the back removed.
Roger
Roger
#42
RE: BVM F-86 (60
Sean these are only about .047 thick. They are great to do the cuts. They are much thinner than the cut off wheels made by dremel. They are also great for cutting carbon fibre.
Roger, if you use the diamond cut off wheel i have shown you. you can lay a metal straight edge along the line you want to cut and use it as a guide. Just go slow and the work great. This was a tip from my friend (Tim Redelman).
#44
RE: BVM F-86 (60
Hi,
Thanks, Greg. I'll take a second look. It's crazy what carbon fiber does to saw blades. I bought an ultra-fine X-acto saw blade to cut the flaps out, and the carbon cloth under the obechi made quick work of the blade. That thing was to dull for balsa by the time I was done. I ended up using a cutoff disc for the last cut [:'(]
#46
RE: BVM F-86 (60
Hi,
Got more done yesterday. I cut out the flaps per the instructions and capped them with the supplied balsa. The balsa is precut for the hinges and horn, as is the ply facing for the TE of the wing. The flaps fit nicely, and will look great when hinged.
I also got the cutouts in the side of the fuselage made with a cutoff disc then a drum sander.
#48
RE: BVM F-86 (60
Hi,
After you use a dremel to open up the foam in the wing for the slotted balsa dowel (the hinge filler block), you can test fit the pieces in. I plan to epoxy them into the foam, then sand the LE of the flap flush.
#49
RE: BVM F-86 (60
Hi,
For kicks and motivation, I put the Sabre up on her gear. It sits VERY tail-high with the nose and mains cut to what looks like the right length. Does the Sabre sit this nose-low?
