BVM F-86 80
RE: BVM F-86 80
Hi Eric,
I still have the gold powder and i was unable to get any help from the paint people to help me figure out a way to get it to dissolve in todays type of paint. So i took it and had them scan a small amount of it to give me a close match in a color that i could use.
The parts you see sitting on the table still need to have a clearcoat sprayed onto them so i think it will darken up a little bit once i do that.
#34
RE: BVM F-86 80
Greg,
great job you have done there, a lot of prep work has gone into getting a good base to start from.
What is the paint (brand, colour) and the clear coat you have used here, its turned out very well.
Its going to look great against a clear blue sky !
In regards to the eagle motif on the side, I am assuming thats a paint mask with decals for the nomenclature.
thanks,
Dale
thanks,
Dale
#35
RE: BVM F-86 80
Hi Dale,
All of the paint is the PPG DBC base coat. The whole plane is completely done in paint. There are no decals for the nomenclature on the airplane. The only thing i had made as a vinyl decal is the flag emblem on the tail. The color for the blue is insignia blue and the red is insignia red. The white is just a base white and the gold is from a 1974/75 chrysler called Inca Gold Poly. The clear is PPG 2042. Yes i did have paint masks made for everything including all the lettering and the maple leaf roundels.
#46
RE: BVM F-86 80
Are your wing tanks in the right place?
I notice this Sabre is unusual in that the tanks are carried on the inner pylons
or did they fly in both positions?
BTW, your Sabre looks fabulous! - John.
