PITA pneumatic lines!
Reply
Old 10-17-2012, 09:20 PM
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PITA pneumatic lines!
Any good techniques to install the air lines to the retracts & fittings? There must be an easier way[:@]
BlueBus320 is offline
Old 10-17-2012, 09:27 PM
mr_matt
mr_matt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: PITA pneumatic lines!
Chew on the end of them before you put them on.
mr_matt is offline
Old 10-17-2012, 09:47 PM
mongo
mongo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
get someone else to do em.
mongo is online now
Old 10-17-2012, 10:11 PM
Pepperpete
Pepperpete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow some real helpful people in here. I use a lighter and briefly (VERY briefly) heat the very tip of the airline itself. I mean a quick pass with the flame. That softens and enlarges the opening just enough to let you slide them onto the retract nipple. And once it cools it will shrink back down and the fit is airtight. Done this for years with no issues. Works like a charm and I feel your pain. The DAY that air systems no longer exist can't come soon enough.
Pepperpete is offline
Old 10-18-2012, 12:06 AM
jason
jason's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use this from BVM
[link=http://shopbvmjets.com/zencart/index.php?main_page=product_info&cPath=12&products_id=26&zenid=rt58s35ro6839nhtgfeu7p69d1]BVM O ring lube[/link]
Jason
jason is offline
Old 10-18-2012, 12:16 AM
Malcolm H
Malcolm H's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I run a small hydraulic and Pneumatic engineering company. I saw this trick being used by one of our fitters in the workshop while installing small push on pneumatic lines and couldn't believe how well it worked until I tried it.
Rub the end of the tube against the side of your nose where it joins your face and then slip it straight on the nipple. A little extra skin oil gets trapped here and is the perfect lubricant to allow the tube to slip on.
Please do not refer any cases of industrial dermatitis to me!
Malcolm
Malcolm H is offline
Old 10-18-2012, 03:51 AM
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Pepperpete
I've never had luck with that. Every time I've used heat... they leak.
Dr Honda is offline
Old 10-18-2012, 04:37 AM
basimpsn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Face and then slip it straight on the nipple
Now.. that I'm going to try tonight
basimpsn is offline
Old 10-18-2012, 05:33 AM
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys. I want this to be easy!!! So I'm gonna chew it, rub it on my nose, stick it in BV O'lube, set it on fire (briefly), then stick it on the nipple! #GetErDone
Old 10-18-2012, 06:12 AM
E.N.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After that, go to the gynecologist, HA///
ENT
E.N.T. is offline
Old 10-18-2012, 06:25 AM
Sparhawk
Sparhawk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did I miss something here? Are you saying you have a hard time simply pushing the end of a small plastic tube over a metal, barbed, air nipple?
Is this right? OK, where are the hidden cameras?? I have all types and brands of air lines, and I have NEVER had a problem pushing them on the barbs... I think you need to develop those pinching muscles in your fingers..
Don't mean to sound cruel.. but really?
Pepperpete - from what I have observed so far regarding electric retracts, you can have them. Unreliable and no where up to the task, and easy to burn out the control boards where the overcurrent protection utterly failed. Current costs are over the top in comparison to standard air, and I don't think there is even a close savings in the weight. All my sets can hold over 100lbs for DAYS, before you see them starting to lose pressure.
Sparhawk is offline
Old 10-18-2012, 06:56 AM
John Redman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use a small piece of sandpaper (120 - 150 grit) between your finger and the tubing. The sandpaper allows you to grip the tubing as your fingers do not slide on the paper and the sandpaper side grips the tubing. Works everytime!!!!
Not the best picture but should give you the idea.
John Redman is offline
Old 10-18-2012, 07:16 AM
uncljoe
uncljoe's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: John Redman
John
Looks like something an Old Jet Cat rep would use... Works the first time & everytime
Semper Fi
Joe
uncljoe is offline
Old 10-18-2012, 07:21 AM
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey someone forgot to suggest chew gum and rub your belly at the same time! LOL
Bob_B is offline
Old 10-18-2012, 07:38 AM
Ron Stahl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A trick we use here at work is to get a cup of hot water and dip the tube into the hot water for a few seconds before installing it onto the barb fitting; this along with Johns tip of the sandpaper should make it totally painless.
Ron Stahl is offline
Old 10-18-2012, 07:53 AM
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So far between the rubbing in the corner of the nose & the sandpaper trick, LIFE IS GOOD! piece of cake! Guess I can't shower until I'm finished though..lol I think a lil O-lube would be great too.. Thanks a million!!!
Old 10-18-2012, 08:01 AM
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ron, was it you about 10 years ago, when I came into a hobby shop with Richard Moch & bought that BV twin Rafale from Eric? If so, I remember you guys were painting a nice BV Phantom & gave me some good painting pointers I've used ever since.
Old 10-18-2012, 09:04 AM
Xairflyer
Xairflyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I am plumbing up a fuel system that has barbs (pump, valves etc) with the festo tube, I use a method that I discovered when fitting pitot tubes to gauges on fullsize aircraft. This was to inject a tiny amount of turbine oil (I keep some in a syringe) into the end of the tube, then heat the end with a hot airgun/lighter, the oil stops the tube from deforming or going wobbly and also provides lube, tube just slips on and looks perfect every time.
Obviously you select the oil to suit application, for retract pipes use a silicone oil.
Xairflyer is offline
Old 10-18-2012, 09:13 AM
FalconWings
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BlueBus320
Was that one of the 3 Bucaneros Ive built?
FalconWings is offline
mr_matt
mr_matt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Never knew that sandpaper trick! And for chewing the lines, i forgot I mainly do that on the 4 mm urethane fuel tubing. For airlines I love the stuff that Ultra Precision sells.
mr_matt is offline
Old 10-18-2012, 10:16 AM
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FalconWings
Hey Falconwings, this one is not one that you built, but if your name is David R. you sent me a few really cool pics of a JL-16 (I think) when I was first picking a scheme
Old 10-18-2012, 10:49 AM
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes that was me. You did a great job on it, is it a Tams?
Old 10-18-2012, 11:24 AM
Boating Bob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The sand paper sounds good. I have allways used paper towels to hold the line with, That helps a lot.
Boating Bob is offline
BlueBus320
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, Tams.. I wasn't looking to do anything fancy/pretty, just an old dirty American war dog. Bucanero's was perfect[8D] & thanks
Old 10-18-2012, 02:47 PM
hooker53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys. Guys. Slip the end of that tube up on a small Hemostat and pull the handles apart for a five count to stretch it and slip it right on.
hooker53 is offline
Reply
Display Modes
