Reload this Page >
I-Gyro HELP!!!!
I-Gyro HELP!!!!
Old 10-22-2012, 07:27 PM
Terry Holston
Terry Holston's Avatar
Default I-Gyro HELP!!!!
May be a dumb question for some of you.
I am trying to get my POwerBox I-gyro set up on my Spectrum DX18.
I have it in an Electric plane for testing. Before I put it in one of my jets.
I can not figure out how to get it set up on the 2 sliders to set the gains and the 3 position switch so it can be shutoff. Can any one help?????
Old 10-22-2012, 07:38 PM
Greg Wright
Greg Wright's Avatar
Default RE: I-Gyro HELP!!!!
Get a hold of Tim Redelman.
Old 10-23-2012, 09:57 AM
Terry Holston
Thanks Greg, I was hoping Tim would chime in here as I don't have his phone number.
I have it installed and bound with the Reciever that came with the Dx18. All Gyro controls are working in the correct direction. I used the values that are shown in the I-Gyro instructions.
I just can't turn it off or adjust the gain.
I even flew it yesterday, What a rush.............Had a he!! of a time getting it to turn so I could land......... It wanted to go straight, in a cross wind.........LOL
Old 10-23-2012, 12:35 PM
jetmon
This may help
https://duraliteflightsystems.com/im...Simplified.pdf
Old 10-23-2012, 02:35 PM
bidrseed2
Try the powerbox forum, they're very quick to respond.
http://forum.powerbox-systems.com/
Old 10-24-2012, 08:28 AM
Terry Holston
I printed off the PDF file, But I still Can't access the switch asignments on the DX18 to get the flight modes and gain switches set to the proper channels............................
Old 10-24-2012, 08:57 AM
Andrew Bird
Andrew Bird's Avatar
I don't have mine in front of me but I'm pretty sure I had to assign the gain adjustment to the sliders via the gyro itself. But it was a while ago that I did it and it's on a DSX 12 so things may be different. I seem to remember assigning the gain to a channel using the adjuster switch and then if necessary just reassigned the switches on the TX to make sure the gain was where I wanted it. Once the gain is set I locked the value in the unit and it was no longer assigned to a channel so it could not be changed until I decide to do it again if necessary.
Old 10-24-2012, 11:36 AM
gooseF22
gooseF22's Avatar
Terry... davey fix.. catch me at the field..
Old 10-24-2012, 03:43 PM
Terry Holston
Got it assigned, Now I gotta figure out how to keep it set and take them off the sliders................who said this was easy????
Old 10-24-2012, 03:48 PM
Andrew Bird
Again - going from memory here. Fly, find the gain setting that works, leave that slider alone and land. You can then use the switch to go to that gain setting and deactivate the channel it's assigned to, so the number you have in there is set. It literally takes a minute or so to do - you've done the more complicated bit by getting it assigned to a slider.
Old 10-24-2012, 04:13 PM
Terry Holston
So how do I deactivate the channel it is assigned to? Reset the values to "0"?
Old 10-24-2012, 04:56 PM
quist
My Feedback: (198)
quist's Avatar
Yes. Back to zero.
Old 10-26-2012, 02:08 PM
Terry Holston
Thanks for all the help, guys..........Now if I can remember how to finish it up when the winds calm down and the temp gets a bit warmer, all will be good.......(When my fingers get cold, it's no longer fun)..........See ya all in the spring......LOL
