How to dissasemble Tamjets 1/8th Scale F-16 Wheels? Brakes won't lock tight...Help?
AB, CANADA
Does anyone know how to dissassemble the Tamjets 1/8th Scale F-16 non scale wheels? They are not leaking air but there is almost no tension on the wheels when I engage the brakes. I want to take them apart to see if something is worn out but I can't for the life of me figure out how they dissassemble.
AB, CANADA
RE: How to dissasemble Tamjets 1/8th Scale F-16 Wheels? Brakes won't lock tight...Help?
ORIGINAL: Wayne22
loosen the bolt holding the axle to the strut, and they will slide right out...
You've got to be kidding me...that's it?? Thanks Wayne that is the only thing I didn't think would make a difference. I suppose I should have tried it first. [&:] Did your brakes lock completely or was there a fair amount of give when you tried to rotate the tires with the brakes engaged?
