If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 26 to 50 of 124
  1. #26
    wfield0455's Avatar
    Join Date
    Sep 2005
    Holliston, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Skymaster Extreme Dragon Build with JetCentral Cheeta
    ORIGINAL: mhadjiky
    I was so excited that I managed to install properly the servos and I forgot to take same pictures. The attached picture shows my solution.
    First I have cut a 2,5mm plywood slightly bigger than servo and then I have screwed the servo on it using supplied aluminum supports. I also applied some Hysol around aluminum supports. Then I have installed the servo arm. Take care, you have to put everything in the correct direction (center the servo, servo reverse, etc). Then I made the servo slot on the former bigger , I have applied Hysol on the plywood and installed the servo in the desired position. Next day when the hysol was dry I made all needed measurements and I opened the slot for the servo arm. To get out the servo arm you must open a little longer slot. With that solution you can put the servo in the correct position and if you need to replace it you can do it.
    Thanks for the detailed explanation. Until this morning I hadn't noticed that they had provided aluminum brackets for mounting the servos. I like your solution of screwing the brackets
    to a plywood plate and then Hysoling the entire assembly into place. With the servos that I have I'm not certain I will have enough room to add a plywood plate as my servo fit very tight.
    I may need to attach the brackets using bolts through the bottom stabilizer skin. I've started making a template that I should be able to tape in place to drill the holes for the servo brackets
    and cut the servo arm slot.
    I also really liked the clevises that you used as they look very heavy duty. Where did you get them from?
    Wayne
  2. #27
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ξ™ bought it from from JetPower 2012 show in Germany.
    You can find these clevices at www.airfighter.eu
    Very strong clevices.
    Jet Noise is the Noise of Freedom
  3. #28
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ξ–ΞΏnker123 did you try to put canopy in place?
    As I have seen from your pictures I think fuel lines from main tanks does not allow the canopy to be attached in place.
    Did you modify canopy? If yes could you attached some pictures?
  4. #29
    Join Date
    Mar 2003
    North Port , FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If I recall you must cut out the cross pieces of the canopy frame.
    Attached is a photo of the last one I built.
    thanks
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1818968   Click image for larger version.
    Bill Hatcher | 941-429-1903
    Hatcher\'\'s Hangar Building Service
  5. #30
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mhadjiky
    Yes you have to remove the cross member at the rear to clear the fuel lines.
    Finished my equipment install and mocked up the battery plate. With the batteries forward on the plate I believe that I will be ok on the C/G with any extra weight. Had to put a block on the forward bulkhead to mount the front of the battery plate to
    Using 4 batteries, 2 x 2300 A123 for the RX, the 9.9 3800 for the Cheetah, 2100 6.6 volt LIFEPO for the smoke pump.
    Only thing left now are the wings.
ID:	1819362   Click image for larger version.
ID:	1819363   Click image for larger version.
ID:	1819364   Click image for larger version.
ID:	1819365   Click image for larger version.
    KINSTON NC AEROMODELLERS
    A & E JETS
    Team 2DogR/C
  6. #31
    Join Date
    Nov 2003
    Martinsville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Zonker. Great build going on here. May I ask? What size CAT tank do you have pictured.
    Scratch it till it bleeds Convert it till it chokes
  7. #32
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hooker53
    It is the 130 ML size CAT. Ive run the same size on my Rhino with success.
    A & E JETS
    Team 2DogR/C
  8. #33
    Join Date
    Mar 2003
    Raleigh, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Bill Hatcher
    thanks
    Ya know Bill,,,,,, To be such a big ugly guy,,,,you sure do pretty installs!!! lololol
    Seriously,,, I always enjoy looking at your work and appreciate the clean installs you do. Looking at all these pics,,, I may have to call Eric and order one of these Dragons! I have a Cheetah needing a new home!
    Team "Horizon"
    Team "Jet Central"
    "First In Flight" Jet Rally
    Jackie Sacks Wing Bags
  9. #34
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Almost finished the wiring except batteries and turbine. I am waiting to send me the longer thrust pipe. I have installed ECU, fuel system and fuel pump. Just to install turbine and thrust pipe.
    I have attached some pictures of my progress. I have reinforced tail section with carbon and nose gear retract mount.
    I must find a solution to re-route wiring because I do not like as it is now.
ID:	1819769   Click image for larger version.
ID:	1819770   Click image for larger version.
ID:	1819771   Click image for larger version.
ID:	1819772   Click image for larger version.
ID:	1819774   Click image for larger version.
ID:	1819775   Click image for larger version.
ID:	1819776   Click image for larger version.
  10. #35
    Join Date
    Jan 2010
    glasgow, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mhadjiky
    Why dont you put the wiring under the radio tray, just make sure the hole beside whatever your wiring to is big enough for the plug or connector your using.
    Here's a picture of the install on my F-16 with all the wiring below the tray. the grey on the tray is actually dolls house carpeting and not paint.
  11. #36
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very Good job John. I will try to put as much as I can wires under the tray.
    Thanks.
  12. #37
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have changed receiver possision and as a result the wire routing is better.
    The airplane is almost ready. I have to install cockpit and turbine. I still waiting the thrust pipe.
ID:	1820557   Click image for larger version.
  13. #38
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: mhadjiky
    Looking good !
  14. #39
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any recommendations for CG and flap settings?
    Will you set landing flaps to 90 degrees?
    I am thinking to use four conditions.
    Condition 1 for normal flight
    Condition 2 for take off. Flaps at 30 degrees
    Condition 3 for landing1 and flaps at 70 degrees
    and Condition 4 for landing2 and flaps at 90 degrees.
    I will adjust CG at the rear end of wing aluminum spar.
    What about yours settings?
  15. #40
    wfield0455's Avatar
    Join Date
    Sep 2005
    Holliston, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How did you attach the fuselage nose section to the rear. Did you permanently attach it using Hysol and simply use the screws for alignment / clamping or did you simply bolt it together so you can remove the nose section in the future?
    Wayne
  16. #41
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have used the 4 screws. I also used 4 bigger washers and 4 spring washers.
    I can not see any benefit to use Hysol.
    If you use Hysol and after you have to remove fuel tank, you must take out
    everything.
    If you want you can use longer screws and install locknut from behind.
  17. #42
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I only used the four bolts also with larger washers and a lock-washer with a dab of blue thread-locker on each bolt.
    Mine is within an hour of being flight ready. Just need to set the flaps and the aileron travels and give it a once over. Looks like Friday afternoon will be the go time.
    I will start with 20 degrees of half flap and 70 degrees at full flap to begin with. Flaps will be on separate switch for starters
    Elevators are set up for 30mm/21 degrees on high (the manual recommended setting), 16 degrees mid, and 11 degrees low.
    Once I figure out the throws I will combine on flight modes
    A few more pics.
ID:	1822052   Click image for larger version.
ID:	1822053   Click image for larger version.
ID:	1822054   Click image for larger version.
ID:	1822055   Click image for larger version.
    A & E JETS
    Team 2DogR/C
  18. #43
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What about CG?
    Will you follow manufacturer recommendations?
  19. #44
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes on the spar or just slightly ahead of it.
    Did you get your pipe yet?
    Mike
    A & E JETS
    Team 2DogR/C
  20. #45
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No, I did not get the thrust pipe.
    According trucking number they sent it out on 17th. Propaply I will have it next week.
    Will you make the maiden flight this weekend?
  21. #46
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, I am looking at a Friday afternoon lift off.
    Will let you know how it works out.
    take care
    mike
    A & E JETS
    Team 2DogR/C
  22. #47
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wish you good luck today for the maiden flight of your plane.
    I am waiting your opinion especialy when you extend the flaps at 90 degrees.
    I just received the thrust pipe. Time for work.......
  23. #48
    zonker123's Avatar
    Join Date
    Apr 2003
    Grifton, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK two flights on the plane today
    The first take off was a bit rocky but got it trimmed out in a couple of minutes Flew nice and smooth. No elevator compensation with flap deployment but it wanted to roll left with 35 degree flap. Held some correction and bounced it a bit on the first landing. I was so used to landing my Boomerang torus at this field that I turned in a bit to soon with the dragon and didn't slow it down quite enough. Re rigged the flaps a little for the second flight and it was better but not quite there yet. Went high and played with the full flap and the plane is very stable.
    The elevator setting at 30mm/21 Degrees is too much for normal flight. The plane would snap over hard at that setting. At my mid rate setting of 15 degrees. you can do a full back tight loop at half throttle and the plane just comes around with no problem. At my low rate of 11 Degrees the plane is super smooth. 25mm on the ailerons gives a fast enough roll.
    Plane is stupid easy to knife edge. There are some very small coupling issues but nothing that can't wait to trim out later.
    I had wanted to put my Rhino in this thing at first but Eric assured me the Cheetah was the better choice. He was right, it has plenty of vertical and it will break the AMA speed limit (Im using the Spectrum GPS module to down link to my DX18. Good Stuff!) I flew the plane most times at 1/2 throttle and other than the verticals it appears it will do anything at that speed you want. what really impressed me about the Cheetah was that it had not been started in 6 months but it started right up with zero problems (OK it did give a little belch on the first run up but after that was as smooth as could be)
    The plane with NO fuel weighed in at 29.7 lbs. I had to move the ECU battery to the very nose of the plane and add 8 ozs to get it to balance at the front of the wing tube. so the plane is just a tadd less than 31 lbs w/o fuel. after flying it that may be a little nose heavy. 1/2 throttle 45 degree up line then rolling inverted the plane start to tuck the nose down some. Will move some stuff around next flight.
    The gear door is pain. sometimes it closes, and some times it will be open as you pass by. Maybe it needs a second ram? Its fine on the ground, its at speed it acts silly.
    The nose gear failed to extend once on the second flight, went around a cycled the gear again and out it popped. On inspection after the landing the pin was bent and the "E" clip groove on the head of the pin was broken and the gear came out of the trunnion as i was taxing back. Not to worry, been through this before with the gear on BD-5, Dreamworks bushing and pin will fit right in with little modification.
    I have posted a short video of the second flight on you tube. Its of poor quality but it does prove that it does fly.
    http://youtu.be/NpPDmsksZxE
    A & E JETS
    Team 2DogR/C
  24. #49
    MNModels's Avatar
    Join Date
    Dec 2003
    Oudtshoorn, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Zonker123,
    Cangratulations! Hope you have plenty more flights with Dragon/Cheetah!
    I will redo the manual for Dragon as the current one is outdated. I did it couple of years back when i received the prototype with balsa wings and film covering. So i ask the pilots permission to use some of the pictures in this forum in the manual.
    If you have more pictures pls let me know. I build about 10 myself but never took pictures again...
    Say high to Eric for me....
    Regards
    Morne
    MNModels
    Skymaster & Xtremejets
  25. #50
    mhadjiky's Avatar
    Join Date
    Dec 2006
    Nicosia, CYPRUS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Mike
    Congratulations! I wish you many many succesful landings with your Dragon.
    As I have seen from the video the plane can come very slow for landing.
    What was the problem with nose door?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
