omg omg omg my first turbine, Kingtech K80F pitot tube question
I just recieved and mounted my new and first turbine to my test bed, I would like to install a pitot tube into the fadec to give me an idea of the stupid speeds in which it runs. Does anyone know of a compatible pitot tube system that would work witht he kingtech fadec? I know eagle treee have one, would that work?
Thanks in advance,
Devin
Thanks in advance,
Devin
My Feedback: (22)
RE: omg omg omg my first turbine, Kingtech K80F pitot tube question
If you are referring to rpm the ecu will already tell you what rpm it is running. If you want the exhaust gas velocity, I doubt a pitot will help you, if the heat doesn't destroy it I doubt it will read the velocity. I don't know for sure what the kingtech is but I know there are plenty of turbines where exhaust gas velocity exceeds 1000mph according to manufacture specifications.
PA
Yep... what he said.
If you are looking for air speed of the model... then this was covered earlier this week. (do a quick search)
QUOTE - rpm the ecu will already tell you what rpm it is running. If you want the exhaust gas velocity, I doubt a pitot will help you, if the heat doesn't destroy it I doubt it will read the velocity. I don't know for sure what the kingtech is but I know there are plenty of turbines where exhaust gas velocity exceeds 1000mph according to manufacture specifications.
What?
Pitot tube measures air speed. I understand that. Could someone link me or tell me a model that would work with my xicoy fadec? (this is for mouting to my jet....)
Thanks in advance,
Devin
What?
Thanks in advance,
Devin
There you go... but this AIRSPEED SENSOR only limit the JET by dialing down the turbine RPM preventing the jet going pass 200 MPH.
http://www.xicoy.com/catalog/index.php?cPath=22_25
My Feedback: (10)
ORIGINAL: devin120
Thanks in advance,
Devin
Thanks in advance,
Devin
Yes the eagletree pitot should work. JetCat has one too but for 10 bucks I would go with the eagletree.
This of course assumes you already have the little electronic transducer that Xicoy sells.
Thanks guys! Exactly the information i needed and not a post recommending me to do a search. Very nice of the pros to help me like that!
My engine is ready to run, im getting a test bed fuel tank and hope to fire up today!!! Im so excited. im freaking out. My first turbine!!!!! I swear to god i kiss this k80 before i go to sleep. Saved my money for ages for this thing.
Ill let you know how it goes, kero start, hopefully she spools up! WOOOOT Ill post a vid on youtube.
Devin (Very excited man) wooohooooooooooo!!!!!!!!!
ORIGINAL: devin120
Feel free to ask question if you are not sure, because turbine repairs are expensive.
Thanks Basimpsm!
hahaha, i cant say what i want to on an online forum open to the general public and the younger ones. But yes, i wont bring it to bed.... all the time..
But i heard the inlet suction is immense? I should be careful? I have a nice test bed nothings in front and i have a make shift fod screen until i order one from king tech...
My fathedr worked for Pratt for 40 years so hes helping me out with it, but hes worried about a tri hub failure, althought i know its not as complex as a pt-6.. i should satnd in front of it i guess?
Devin
Devin
