Fei Bao Euro Fighter EF-2000 build thread *Lots of Pics!*
Reply
Old 11-15-2012, 08:01 AM
  #51
Canadian Man
Canadian Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fei Bao Euro Fighter EF-2000 build thread *Lots of Pics!*
Started working on the new nose door. Ordering one is 5 weeks out so going to make one.
I first separated the old nose door into two pieces.
Then Traced onto a thin piece of ply. 3/16" I believe for the outside finish and checked fit.
Then traced the inner piece onto the same ply with Hinge cutouts. I glued it all together first and cut the hinge cutouts afterwards.
The fuse at the nose gear door has a slight bend from front to back because of the gear mount former in that spot. The piece of ply that I picked had a slight bend to it so it fit perfect[8D]
ID:	1820497   Click image for larger version
Canadian Man is offline
Old 11-15-2012, 08:06 AM
  #52
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I applied two layers of Medium weight glass cloth to the outside first. One layer was laid at a 45deg to the other layer. I used finishing resin to create this. After 5 hours I could handle the part and trim the excess glass from the outside.
I then worked on the backside and applied 1 layer. This was a bit more difficult as there was the edge details to deal with and also the Hinge cutouts. I installed it and used an xacto knife to cut around those details while everything was still wet.
The second picture is from this morning while Trimming the excess.
The outcome. I am happy with the results. The door is slightly heavier than the stock one but it is insanely stiff!
ID:	1820499   Click image for larger version
Old 11-16-2012, 05:23 AM
  #53
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sanded the nose door. Will start priming to smooth it out.
Got the nose door mounted. The plastic hinges from FB have a remove able screw to allow for easy door removal once mounted.
Hinging was quick and easy. Again I used CA up front. I'm still undecided if I will use nuts and bolts for the nose hinges.
Recieved my order from Altecare yesterday which had my Hysol I needed. So the remaining areas on the formers were done last night.
ID:	1820815   Click image for larger version
ID:	1820816   Click image for larger version
Old 11-16-2012, 05:28 AM
  #54
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next I had to complete the cut outs for the gear where it passes into the fuse.
I mounted the wing on one side, marked the cutout line from the wing. Removed the wing and used a dremel to cut out area. Then sanded edges and corners.
ID:	1820823   Click image for larger version
ID:	1820824   Click image for larger version
Old 11-16-2012, 05:32 AM
  #55
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is an overview shot of both doors open.
I mounted gear to check how far the fuse door needs to be open to allow gear to pass by.
Final shot of gear retracted and doors closed.
The gear side door required a bit of sanding where it met the new fuse. Non issue. Took ten seconds with a dremel.
ID:	1820828   Click image for larger version
ID:	1820829   Click image for larger version
Old 11-16-2012, 11:26 AM
  #56
Pepperpete
Pepperpete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keep it up! This is facinating.
Pepperpete is offline
Old 11-17-2012, 03:52 PM
  #57
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided last night to glass the inside of the front gear cover.
This morning I trimmed the excess off and did the cutouts for the door hinges.
Ready for primer.
ID:	1821302   Click image for larger version
Old 11-17-2012, 03:54 PM
  #58
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Door primed. I primed and sanded it three times to get it smooth.
Primed the nose cover inside and out.
ID:	1821304   Click image for larger version
Old 11-17-2012, 03:57 PM
  #59
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Removed the gear door cylinder from the previous fuse and got it ready for install.
In the next set of pics you will see that I did a lot of epoxy ing today.
ID:	1821308   Click image for larger version
Old 11-17-2012, 03:59 PM
  #60
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nose cover installed
Front tray support installed. This is aft of the stock one.
Nose gear door air cylinder mounted.
ID:	1821310   Click image for larger version
ID:	1821311   Click image for larger version
Old 11-17-2012, 06:21 PM
  #61
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gluing the main gear covers on. Went well even though they were pretty rough from being removed from the damaged fuse.
ID:	1821342   Click image for larger version
Old 11-17-2012, 06:25 PM
  #62
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mounted the front steering servo mount.
Installed the servo. Marked the servo shaft point so I could line up the servo horn so it's equal between the nose cover.
ID:	1821345   Click image for larger version
Old 11-17-2012, 08:33 PM
  #63
jzuniga
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice re-build CM...
Z
jzuniga is offline
Old 11-18-2012, 07:25 AM
  #64
bidrseed2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone following this thread have the undercarriage set for this model that they no longer require?
Send me a pm if you do, I live in the uk but am frequently in the states.
bidrseed2 is online now
Old 11-18-2012, 08:41 AM
  #65
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next thing I did was sand down the former that sits under the turbine.
When mounted the turbine was within 1-2mm of the former. I should have done this before mounting the gear covers.
I marked it with a sharpie marker to give some refrence while sanding.
I didn't take an after shot but with about 1/4" removed I am happy with the gap.
It was easy to view from the back of the fuse with turbine in place.
Second thing was to replace one of the gear doors that hinge with the gear. The hinges were damaged by the previous pilot and the door was in rough shape.
Hinging was fairly straight forward as I had the previous locations to use. Used 2 Dubro 1/4" scale hinges.
Also had to insert a new ball joint mount on the door. I used a standard plastic off set hinge. Cut it. Cut a spot out of the door. Hysol in place. Used the existing door for position.
ID:	1821446   Click image for larger version
Old 11-18-2012, 08:46 AM
  #66
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next I made a support for the rear of the rear tray. (Sounds funny. Lol)
Pretty straight forward.
I am undecided at this point if I should glue it in position or use fasteners.
Cheers!
ID:	1821448   Click image for larger version
Old 11-18-2012, 10:10 AM
  #67
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Front, rear tray mount complete. I installed with two screws.
ID:	1821495   Click image for larger version
Old 11-18-2012, 10:12 AM
  #68
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone know what these two pieces are for?
They were in the former bag supplied with the new fuse?
Old 11-18-2012, 11:44 AM
  #69
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next I worked in mounting the main panel to house air controller/display, air fill valves, fuel fill and fuel shut off valve.
I lined it up and traced lower section onto fuse. Panel was backwards as to sit flush against fuse.
The panel will sit behind the face of the mounting point.
Final pic shows panel in place on wrong side. I couldn't mount it on the inside as paint still wet.
ID:	1821536   Click image for larger version
ID:	1821537   Click image for larger version
Old 11-19-2012, 10:37 AM
  #70
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a shot if the main panel installed.
Interior of the fuse will be painted the same color as the panel is painted.
Old 11-21-2012, 08:35 PM
  #71
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Started painting gear doors.
Cut out part of hatch that sits against main panel.
Added a support.
Took front gear apart. Cleaned. Lubed and re assembled.
ID:	1822467   Click image for larger version
ID:	1822468   Click image for larger version
Old 11-24-2012, 08:43 AM
  #72
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Took the day off from work yesterday to work on the jet!
Got lots done. Worked on front fuel tank mount. Made a plate that attaches to 2 L brackets fastened with the same fasteners that I used for the engine rails.
Hysol 2 strips of ply onto the bottom of the tank.
ID:	1823339   Click image for larger version
ID:	1823340   Click image for larger version
Old 11-24-2012, 08:46 AM
  #73
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pics showing tank position on plate.
It will be slotted in the front and screwed on from the rear.
ID:	1823342   Click image for larger version
ID:	1823343   Click image for larger version
Old 11-24-2012, 08:51 AM
  #74
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pics showing front slots and detail. I used large aluminum washer and a spring to apply pressure to keep the washer up. Works great.
Pic of the back of the tank. 2 screws used. Easy to access.
ID:	1823345   Click image for larger version
ID:	1823346   Click image for larger version
Old 11-24-2012, 08:54 AM
  #75
Canadian Man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Added carbon strip to the area in front of the canard former.
Added carbon strip to the engine hatch support.
ID:	1823348   Click image for larger version
ID:	1823349   Click image for larger version
Reply
Display Modes
