Reload this Page >
Control Rods, Linkages and Associated Hardware
Old 11-13-2012, 02:39 PM
Ozmodeller
Default Control Rods, Linkages and Associated Hardware
Guys
Looking for the above for my new FB T33, must be of the highest quality, also looking for carbon fibre control horns as I intend to use double horns with the link captured between them, if anyone can provide links or manufacturers I would be gratefull.
Peter
Old 11-13-2012, 03:30 PM
marc s
marc s's Avatar
Default RE: Control Rods, Linkages and Associated Hardware
Peter I recently kitted out two kits with this guys servo arms, horns, linkages etc and have to say they are superb. Made from a high temperature pressure injected carbon filled abs they are unbelievably hard, the servo arms a clever as the ends branch into two so the ball link sits centrally in the end so forces are spread evenly, the horns are the same and as they have a wide base plate and robart style pins they are really simple to install as you only have to drill two holes rather than try to neatly cut a slot.
He has just introduced control rods which are carbon tubes with a special end which are glued in place and these look super as well.
If you want some pictures I can dig out the thread here on RCU where I installed them on my Orion jet.
Highly recommended, any issue is the site is all in German but you can work your way round it with a little patience Good luck with your project.
marcs
[link]http://www.gabriel-stahlformenbau.de[/link]
Old 11-13-2012, 03:39 PM
smchale
My Feedback: (67)
smchale's Avatar
Marc,
I've used their stuff quite a bit too. Nice to see they now offer payment with PayPal. That was the toughest part, trying to pay for items, in the past. I hade to send via western union which was a royal pain.
Old 11-13-2012, 03:46 PM
roger.alli
roger.alli's Avatar
BVM has a range of CF horns as well as loads of other gear. http://shopbvmjets.com/zencart/index...1krhfb6d6ugok4
A bit closed to home, try Pete at Intairco. He also has quite a bit of gear not listed on his site. It is all very good quality. I suggest you call him. http://www.intairco.net/categories.p...ontrol-Linkage
Roger
Old 11-13-2012, 03:58 PM
Ozmodeller
ORIGINAL: marc s
marcs
Would really appreciate any photos of your installation.
Peter
Old 11-13-2012, 04:04 PM
smchale
My Feedback: (67)
smchale's Avatar
Another source I have used is:
http://shop.lindinger.at/index.php?cPath=1730_1736
They carry a lot of the Gabriel product as well as items like this in various sizes:
http://shop.lindinger.at/product_inf...ducts_id=54823
Old 11-13-2012, 04:15 PM
jetpilot
My Feedback: (48)
jetpilot's Avatar
http://store.rc4wd.com/Solid-Links_c_33.html
Old 11-14-2012, 02:19 AM
jetnuno
Hi
Nice link. Thanks
I've look arround to find a similar store in Europe, but nothing....
Any one knows one?
regards
Nuno
Old 11-14-2012, 03:06 AM
BaldEagel
BaldEagel's Avatar
Nuno
I am not at by desktop at the moment, but be assured carbon horns are available in Germany, I will look up the link when I get back to the UK and post it for you, the alternative is you can always make your own.
Mike
EDIT: to add pics of home made carbon horns and to add link: http://www.rcuniverse.com/forum/m_72..._1/key_/tm.htm
ID:	1820225   Click image for larger version
ID:	1820226   Click image for larger version
Old 11-14-2012, 05:39 AM
marc s
marc s's Avatar
Pics as requested... so simple to fit, mask, drill two holes, scuff area where plate on base fits and glue.
marcs
ID:	1820239   Click image for larger version
ID:	1820240   Click image for larger version
ID:	1820241   Click image for larger version
ID:	1820242   Click image for larger version
Old 11-14-2012, 12:20 PM
Ozmodeller
ORIGINAL: marc s
marcs
Thanks very much for the photos.
Peter
