Neutral position elevator SM F-4 Phantom!
My Feedback: (90)
RE: Neutral position elevator SM F-4 Phantom!
Where is your CG? I can probably get you a picture Sunday. Hopfully someone will reply before then. There are alot of them flying. I have pics for the JL and as I remember they are very similar in position. That said they are vastly different airplanes. Lets get you a pic of the SM.
My Feedback: (21)
not the best pix but you should have an idea, there are 3 tick marks that are visible in the 2nd pix. the top was at cruise, the middle was at take off, the bottom was at landing.
I had my CG at 300mm and this is the large SM F4
it's a great flying jet and I look forward to getting another one..
good luck
good luck
ORIGINAL: yeahbaby
good luck
good luck
Alan
My Feedback: (21)
Hey Alan how ya doin? Merry XMAS
yup, I was a Delta Alpha and didn't do a good pre-flight after having sat the jet for an extended period of time. somehow I reversed ailerons while setting up another jet on the same radio...and while doing the control check....well.....I saw what I wanted to see instead of actually seeing the appropriate control deflection.
essentially dumb thumbed it into the ground on the best take off I ever had with that bird. a fleeting moment of....."I can fly this out" turned into just dumping it into the ground. no fire thankfully having shut down the motor prior to impact.
there is another one in my future. all the internals were fine, tanks, gear, tail pipe etc.
How's your F4 doing? enjoying it I see from 400'?? whew that's tight and ballzy!
cheers
cheers
Many thanks all!
I have found here is this subjects http://www.rcuniverse.com/forum/m_31...31/key_/tm.htm There all answers to my questions.
I build the Phantom. This is a first Phantom in Russia and I need the advices and help.
My Feedback: (21)
+1
great airplane and you found an informative thread with tons of helpful hints / tips etc.
it's a no brainer airplane to fly.....just remember if you find yourself gear down / flaps full etc on downwind and you're not in the vicinity of 1/3 throttle you gotta ask yourself...why? LOL
the beautiful thing with this bird if she gets slow is that it just develops a high sink rate....like a turd dropping on a flat rock from a tall moose.
enjoy
enjoy
ORIGINAL: 757Driver
Best of luck! She will pitch down a little with full flap. Easily handled with some trim. Stay on power until touchdown as she's a dirty bird and will slow/drop as soon as power is reduced.
Your gonna love it!
Your gonna love it!
ORIGINAL: yeahbaby
essentially dumb thumbed it into the ground on the best take off I ever had with that bird. a fleeting moment of.....''I can fly this out'' turned into just dumping it into the ground. no fire thankfully having shut down the motor prior to impact.
cheers
cheers
Yes Merry Christmas to you too. Being a Canadian I got involved with a Snowbirds Tutor the last while, so I have been having adventures with it.
The F-4 took a back seat for a little while. But I decided this year it will be finished and flying for 2013. I did get some motivation from Dave Phillips flying his at Whidbey Island when he was there in 2010. Also when I was at the Jet Masters in Dayton, I also talked and watched Andy Andrews flying his flying very well too. So I think 2013 will be it's year.
So sorry to hear about your accident. As your testament says, it happens to the best. I hope you get replaced soon and that the skies will be in fear of the big Rhino again. Maybe talk to you again when I get close. Still have kept all the PM's and emails you wrote me with your good guidance.
Talk to you soon Buck and have a good 2013.
Alan
ORIGINAL: yeahbaby
cheers
cheers
