If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 47
  1. #1
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    flight trim on full stabs
    My f-16 with no trim has slight right roll at full throttle, but under 3/4 throttle it flies level. So if i trim it level at full throttle it will roll left when i back off the throttle. Is this the full stabs not being set or some kind of airfoil problem?
    Keith who?
    Xtreme ARF Rep
    Contest Director AMA # 8394
    FAA Registration # FA3W99AXCX
    https://www.youtube.com/channel/UCE_...BAxA8bHVCw3VQQ
    https://www.facebook.com/FenderbeanRCBuilds
  2. #2
    Join Date
    Apr 2002
    SANTA ANA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: flight trim on full stabs
    ORIGINAL: FenderBean
    Fender,
    Since surface authority is airspeed related it simply means your ailerons are possibly not exactly centered, or it could be your stabs are slightly off. The effect of the off center only shows above a certain airspeed. Very similar to VNE. Below VNE the structure is stable, above it, all hell breaks loose.
    David S
  3. #3
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    But to have that much from such a small air speed change? Well i have no idea how to trim it when i have to use two trims in the opp direction. Like i said it rolls right until a certain speed then rolls back left. So originally i trimmed it level at full throttle to stop right roll and as soon as i throttle back it rolls left. Is both out of trim and one have more authority over the other at higher speed?
    Keith who?
    Xtreme ARF Rep
  4. #4
    Join Date
    Apr 2002
    SANTA ANA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fender,
    This means your problem is in both the ailerons and stabs being unbalanced. For example. your aircraft might be reacting more to the offset of the ailerons at one speed, but that is then overpowered by the offset of the stabs at a higher speed, because the stabs, being larger have greater roll authority at speed, or perhaps it's the other way around. Just a theory, but aerodynamically correct, I think.
    Imagine, for example, using aileron trim to correct an offset which is actually in the stabs or vice versa. No way will you get a consistent result.
    David S
  5. #5
    Dr Honda's Avatar
    Join Date
    Apr 2005
    Latrobe, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can also be lightly twisting somthing as you push the throttle higher. (from air pressure) You could simply add a mix to trim it out.
    Tony
  6. #6
    FalconWings's Avatar
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Fender, just had a similar issue with my smaller F-16. I had it trimmed for medium to high speed flight, and then started noticing a tendency to bank at slower speeds, specially during final approach and flare. I was almost fighting it to the ground, which resulted on a broken nose gear strut eventually.
    It turned out one of my stabs, eventhough appeared to be centered, there was enough slop to make it asymetrical to the opposite side. To fix, I simply used one side as a reference by aux trimming until the stab was centered with the speedbrake. Next I loosened the other stab and centered it with the speedbrake and clamped it fixed, with the radio on of course. The retighten the fitting. After this then simply return the aux trim to zero or whatever the initial value was before centering with speedbrake. That took care of it.
    Just a thought.
    David
    .......by Mennen.
  7. #7
    Join Date
    Aug 2004
    tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You could just build a thortte to aileron (or stab) mix to adjust the trim between 3/4 to full throttle when you get your roll.
  8. #8
    Join Date
    Apr 2002
    SANTA ANA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sailing1
    Guys,
    Using a throttle mix to correct an airspeed issue just makes the issue worse. Example: Upwind airspeed at a certain throttle setting is higher that downwind setting at the same throttle setting. Now you have one trim for upwind and a different one for downwind. Another example: Pulling vertical, you will immediately start to bleed airspeed, even though the throttle setting is the same, the airspeed isn't, and will continue to change the longer the vertical line. Doesn't work.
    Falconwings has the right idea. You have to fix the problem at it's source, which seems to be the stabs being offset per his experience.
    David S
  9. #9
    DelGatoGrande's Avatar
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FenderBean, IMHO
    check your lateral balance first .
    your F-16 might not be balanced lateral correct.
    You have trim to counterbalance the heavy side in slow flight. Dont confuse your self by seeing your stabs in same level.All airframe can give aileron input.
    Then in high speed where CG is not that important your build in trim rolls your model.
    Balance your model and add some lead unter the edge of the wing, on the light side.witch one= work it out from the roll tendency>bear in mind the trim.
    Throtle mix wont work because our airframes dont accelerate as fast as our engines anyway.
    my 2c
    Best Regards George
    www.rcjet.gr \"props are for boats\"
  10. #10
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay cool i will check lateral balance again, i will set my ailerons back to center and work on trim with elevators. My stabs have the typical jr 8711 play. Arrrg which is why my new jets will not be jr. Thanks for the info i figured it was both being wrong when it changed with airspeed.
    Keith who?
    Xtreme ARF Rep
  11. #11
    Join Date
    Mar 2002
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Unfortunately a lot of the centerting issues are invisible because of the inherent slop of the linkeage. A lot of the slop goes away if you use a small wheel servo arm at the servo, and place the linkeage as far away from center on the torque rod, which is not always possible (mechanical advantage). This has been beaten to death so I'm sure you are aware by now. If you use 8711's, your elevators should not drop once you turn the radio off. If they do, it's proof of a lot of built in slop, just use a smaller servo arm or a servo wheel, it should still provide more than enough stab travel, but you greatly increase precision.
    .......by Mennen.
  12. #12
    DAN AVILLA's Avatar
    Join Date
    Dec 2001
    roseville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have you checked the incidence in the wings. I had that problem with a boomer Xl and I cured the problem by moving the wing pins. might be hard if you have tubes.Dan
  13. #13
    rgburrill's Avatar
    Join Date
    Dec 2010
    Trumbull, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what you all are saying is taht jet engines do not have torque.  Interesting.
  14. #14
    JohnMac's Avatar
    Join Date
    Oct 2002
    Leeds, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rgburrill
    So what you all are saying is taht jet engines do not have torque.Β* Interesting.
    Really!? Did they?
  15. #15
    tp777fo's Avatar
    Join Date
    Feb 2002
    Greer, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Try just a twek of left rudder. Rudder becomes more effective and less at high speed. Just a couple clicks of trim should do it.
    Tom Perry
    In Dog beers, I only had one!
  16. #16
    mr_matt's Avatar
    Join Date
    Dec 2001
    Oak Park, CA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How is the trim different on upwind versus downwind if the power setting is the same? Soory this keyboard is awful
    Matt
  17. #17
    FenderBean's Avatar
    Join Date
    Feb 2006
    Clarksville , TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah I will try this first, start with the easy first. I have tried the rudder before but I have not tried it at full throttle. I have found this to be true, my f-16 rudder doesnt do much unless I am about 1/2 stick, I had a 10-15mph crosswind one day and the rudder didnt do anything. I had such a bad crab in and the only thing that fixed it was coming in faster.
    ORIGINAL: tp777fo
    Keith who?
    Xtreme ARF Rep
  18. #18
    Join Date
    Mar 2006
    Littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: David Searles
    ORIGINAL: sailing1
    Guys,
    David S
    Hehehe, did somebody say "Downwind"? I wonder how everything is affected in a downwind turn? [X(]
    Shaz
  19. #19
    rctech2k7's Avatar
    Join Date
    May 2009
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is actually not easy to figure out. David has a point but when I tried to solve it's hard to find. Maybe someone else can. The relationship between aerodynamic force and airspeed are expo but constant with its coefficient. The only thing that coefficient can change is by changing the airfoil, camber or angle. Considering flying a trimmed aircraft with no changes in surfaces, Cls are all constant and all their forces change exponentially at the same rate with airspeed therefore the difference in roll is the same throughout any speed...
    More than just sports, hobby and recreation, it’s technology…
  20. #20
    Join Date
    Mar 2006
    Littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rctech2k7
    "This is actually not easy to figure out. David has a point..."
    Big D, you getting a load of this?
    Shaz
  21. #21
    rctech2k7's Avatar
    Join Date
    May 2009
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: JohnMac
    ORIGINAL: rgburrill
    Really!? Did they?
    IMO, the torque of our jet engine is a approximately the product of mass of the rotating parts, average distance to the center and its acceleration. Not sure about the mass of rotor but radius I know is small. At constant rpm acceleration is zero therefore it's only exist as transient...
  22. #22
    rctech2k7's Avatar
    Join Date
    May 2009
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sskianpour
    ORIGINAL: rctech2k7
    ''This is actually not easy to figure out. David has a point...''
    Shaz
    Just curious, one more option I'm thinking is the rudder, when center of pressure in both wings are offset...
  23. #23
    tp777fo's Avatar
    Join Date
    Feb 2002
    Greer, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The rudder becomes more effective as the AOA increases and thus less effective as the AOA decreases. At high speed rudder will just make the airplane yaw as you slow it will induce roll. We used to have a rudder effectiveness demo in the T38. Go about 300 kts and push rudder...jet yawed a lot. Hold rudder and pull back on stick.....then it did a nice rudder roll. If its your rudder trim the jet will roll slightly as you try to loop.
    Tom Perry
  24. #24
    rctech2k7's Avatar
    Join Date
    May 2009
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: tp777fo
    Good help as I'm also trying to find out why the trim that contributes perfect balance fail when airspeed change. I know it happen on longitudinal that change moment out of equilibrium when airspeed drops but not on ailerons. I found it that once aileron is trimmed it remains trim at any speed. I'm also thinking rapid airflow at the sweep wings, also some kind of air separation at lower speed. I can't prove it at this time due to my old 3D modelling background but I've now seen another reason why it happens when rudder is out of trim and ailerons was used to correct it.
    A very good point...
  25. #25
    marquisvns's Avatar
    Join Date
    Oct 2005
    Pasadena, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Keith, If my analysis is correct, there's an enormous down force onto the leading edges of the stabs at high airspeed, especially in a dive. If one servo is weaker than the other and start fail to hold at a certain airspeed, the 16 will pull toward that side.
    My first Jet, a Cermark F-16, everything was fine with 9411s and P-60, but this problem surfaced as soon as I had a K-80 in it. After verifying one servo being weaker then the other on the ground and replacing them with full size 7955s, problem solved.
    Perhaps something also worth look into,
    Cheers,
    Barry
    www.kingtechturbines.com
    kingtechturbines@gmail.com
    1-626-793-4677
    1-626-399-7588 Barry's cell/text
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
