Reload this Page >
Hitec servo jitters/unresponsive
Old 11-21-2012, 11:14 PM
757Driver
My Feedback: (90)
757Driver's Avatar
Default Hitec servo jitters/unresponsive
Hello and happy Thanksgiving to those that are celebrating.
I have setup two HS5955TG's on a 6" Y-Harness and plugged it into my Futaba 6014 RX. Power is Li-Ion via a regulated powerbox switch.
Issue: At power up the servos are either totally unresponsive to any control command OR one of them jitters quite alot.
Trouble shooting: I have verified voltage to the RX and its 5.5V under a 1A load and 5.8V unloaded at the switch/regulator. I believe this to be sufficient.
I suspected the new Y-Harness and replaced it with a proven one. No improvment, same problems.
I reprogramed both servos. No improvment, same problems.
I use this same setup on the flaps of another jet without any problems.
Any ideas?
Jason
Old 11-21-2012, 11:34 PM
757Driver
My Feedback: (90)
757Driver's Avatar
Default RE: Hitec servo jitters/unresponsive
Update:
I just bypassed the 24" harness in the airplane and went from the RX via a 12" Y-Harness directly to each servo, one side at a time. Both tests yeilded the same result= Both servos jittered.
I suspect one of the servos may have an issue that is degrading the signal to both when both are plugged in but the problem doesn't appear if each servo is getting the full signal during the single servo test.
Old 11-21-2012, 11:40 PM
Flynstuff
My Feedback: (29)
Flynstuff's Avatar
Jason
Have you tried another RX with a power source @ 6v and plug the servo right into RX?
This would determen if its the servos or not.
Old 11-21-2012, 11:54 PM
757Driver
My Feedback: (90)
757Driver's Avatar
Willco. I'll try tomorrow.
Thanks!
Old 11-22-2012, 12:31 AM
rfbenn
Is the 6014 in HS mode ,maybe the servos don't like it.
Rob
Kevin_W
Check your servo connectors as well. A bad (or dirty) electrical connection can cause the problems you described.
Old 11-22-2012, 03:34 AM
Boomerang1
Boomerang1's Avatar
I had the same problem with 5645's on the 6014 FS reciever. Not sure about the 6014 HS.
I cannot say what caused it. I did find that it only happened with 2 x Hitec digital servos sharing
a Y lead & only on certain ports on the reciever. With 1 x Hitec digital servo sharing a Y lead with
any other servo it was fine.
Not a problem on a JR 36mhz reciever, only the F6014 & only on certain ports. On that model I
ended up putting the servos on different channels & mixing them to solve the problem.
John.
Old 11-22-2012, 03:56 AM
BaldEagel
BaldEagel's Avatar
Jason
The Futaba 6014 Rx's have a reduced voltage output to the signal wire, Some Hitec servo's do not like it, cure is an "Orbit power jack" which has a increased signal wire voltage plus two power inputs.
Mike
Old 11-22-2012, 09:33 AM
757Driver
My Feedback: (90)
757Driver's Avatar
Thanks for the jet like help guys! I got it resolved this morning. I replaced the Y-harness with a Smart-Fly EQ-II and it seems to work normally. I suspect that EQ boosted the signal voltage enough to handle both digitals. It was a leftover from my gasser days.
The two servos are on Ch.10 for future reference. I'm going to inform Futaba of the issue. Seems they should supply higher signal voltages in this digital age.
Thanks again for all the help gents!
Now go fly something.
Old 11-22-2012, 10:17 AM
bcovish
My Feedback: (8)
bcovish's Avatar
Was the "Y" harness an amplified one. I know with JR you can not use a amplified one when using 2.4.
Old 11-22-2012, 11:58 AM
757Driver
My Feedback: (90)
757Driver's Avatar
Nope. Just a 6" heavy duty.
Old 11-22-2012, 09:46 PM
All Day Dan
All Day Dan's Avatar
Jason, I am pretty sure that Futaba will tell you to go “shove it†because all of their servos will work with all of their receivers. They have no interest in how any non-Futaba piece of electronics works with their receivers and will probably warn that they are not responsible for the consequences that you may incur. Please post their response. I’m curious to see if they have changed their attitude. Dan.
Old 11-22-2012, 10:27 PM
757Driver
My Feedback: (90)
757Driver's Avatar
Hahaa. You are probably right on target Dan.
Old 11-22-2012, 11:31 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
signal amplifier:
http://powerbox-systems.com/e/powerb...rker/start.php
Old 11-23-2012, 02:53 AM
BaldEagel
BaldEagel's Avatar
Did not know that Orbit now do a power jack for the 8 channel Rx's as well as the 6014: http://www.intairco.net/products.php...-6008-Receiver
Mike
Old 11-23-2012, 04:23 AM
Henke Torphammar
Henke Torphammar's Avatar
[youtube]http://www.youtube.com/watch?v=3e8W194ETDY[/youtube]
We also found the servo cables beeing corroted/black. Hitec never solved the problem, they offerd me to change the servo wires but no word about the glitching. Hitec used to make very good servos but now days you don't fly hitec servos any more
Old 11-23-2012, 04:34 AM
HarryC
The fault is not the futaba signal level, it is the hitec servo. This complaint has come up many times for many years, it happened with the 35/72 mhz rx, of different brands, the common point was it was always hitec servos. Their threshold to discriminate between high and low signal is too insensitive and reads both states as low. Complain to hitec, not to futaba.
Old 11-23-2012, 05:08 AM
757Driver
My Feedback: (90)
757Driver's Avatar
Thanks Harry. This a very good idea indeed. Henke, no corrosion noted during wire inspection. Funny that Hitec troubleshooting page only suggests a dirty potentiometer as a possible cause for a jittery servo. I will post responses from both companies.
