Help installation Speed Brake (Detail4scale) F-16 SM.
Reply
Old 11-29-2012, 11:22 AM
bruno borges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help installation Speed Brake (Detail4scale) F-16 SM.
Hello everybody,
I bought the game the Speed ​​Brake Scale4detail, and want to know if anyone has the manual for installation instructions.
Well not in my order came.
BRG
Bruno
bruno borges is offline
Old 11-29-2012, 12:28 PM
DelGatoGrande
DelGatoGrande's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Help installation Speed Brake (Detail4scale) F-16 SM.
you have p.m.
DelGatoGrande is online now
Old 11-29-2012, 12:41 PM
bruno borges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok.
Old 11-29-2012, 12:56 PM
FalconWings
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL - Instruction manual from D4S?
FalconWings is offline
Old 11-29-2012, 03:51 PM
bruno borges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Someone already installed the Speed ​​Brake on some F-16?
Old 11-29-2012, 10:04 PM
DelGatoGrande
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bruno borges
yes i used two hitec 5645 servo on a triple switch with slow servo speed. http://www.petame.gr/forumv/showthread.php?t=8403
manual is very detail with photos .What you need?
Old 11-30-2012, 03:51 AM
bruno borges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Del Gato Grande, Thanksssss!!!!
Old 11-30-2012, 04:13 AM
lookilook
lookilook's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when i saw the title i was ready to reply that possibly only George AKA ''DelGatoGrande'' could help you!! there you go....good luck!
lookilook is offline
Old 11-30-2012, 10:50 AM
DelGatoGrande
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...you are wellcome Bruno.
One thing i forgot to note is that i found hard to keep the airbrakes perfected closed and look good using just the end travel points
and at the same time keeping the servos from fighting the cable link and buzzing.And when servos where not buzzing airbrakes where not closed well.
(downside of a flex cable push/pull link)
Thats why i used the triple switch= (+100% 0% -100% )
With the help of a programable channel from a PowerBox unit (Competition SRS in my case) i was able to move the middle (0%) position of my switch to a further out position for example +140% where the servo closed perfect the airbrakes and then return to the +100% point for example where the servo was resting.
Dont know if that makes any sense but here is the closing sequence result you to get the idea:
Switch position 2: Airbrakes open , servo -100%
Switch position 1: Airbrakes closed perfect , servo +140% =pushing good to close them well (loads of noise and fighting)
Switch position 0: Airbrakes closed perfect , servo +100% =back up to a point where servo rest with out noise and at the same time leave airbrakes closed.
Later on you can leave programming the same and just moved it to a two position switch and cant tell the deference !.
>numbers are just an example -not to be used<
Niko we must make a netherlands F16 display team
cat out...gone flying
Old 12-01-2012, 03:34 AM
lookilook
lookilook's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ready as always George!!
Old 12-01-2012, 04:07 AM
mdeseve
mdeseve's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bruno, i use lado e-door electric cylinder insted of servo, it open and close very scale and it won't drain your battery. Watch the video.
http://www.lado-tech.net/en/e-doors/...door-30mm.html
mdeseve is offline
Reply
Display Modes
