Reload this Page >
CARF Skygate Hawk in the house !
Old 08-24-2017, 05:54 AM
  #1251
skymaster68
Originally Posted by In the Haze
Thanks would you mind posting a picture of your Hawk with the pilot installed? I got a Tailored pilot for my Glider and agree they are very nice.
Have this two at the moment, hope it helps....
Name:	AndesJets_Hawk_CC - 5.jpg
ID:	2229279   Click image for larger version
Name:	AndesJets_Hawk_CC - 7.jpg
Old 08-26-2017, 10:09 AM
  #1252
c_makhija
Originally Posted by Bobneal1
Is there anyone with one of these Hawks disassembling the fuselage for transport to and from the flying field? If so did you have to make modifications? It appears to me that you have to reach in through the gear doors on the bottom to remove and install the screws that hold the fuselage together .
Thanks in advance,
Bob Neal
I need to join the 2 parts of the fuse together at the field. I have the SG hawk, yes the lower 2 screws go in from the main doors. It's not too bad with a ball driver, will take you a few times to get used to.
Chatty.
Old 08-26-2017, 08:42 PM
  #1253
Mike Haddox
Did anybody use the stock tail pipe from Comp Arf? If so did you have any heat problems?
Old 08-27-2017, 07:40 AM
  #1254
skymaster68
I'm using that, never had a heat issue, runing a K210 on mine...
Old 08-27-2017, 10:44 AM
  #1255
Mike Haddox
Thank you.
Old 08-27-2017, 09:19 PM
  #1256
In the Haze
In the Haze's Avatar
Thanks, is that the 1:3.5 scale pilot?
Old 09-06-2017, 02:24 AM
  #1257
In the Haze
Originally Posted by lavi rider
Inlet restriction ..
Lavi were you happy with this setup and amount of restriction before it came to an unfortunate end?http://www.rcuniverse.com/forum/rc-j...l#post12043977
Old 09-06-2017, 04:31 AM
  #1258
lavi rider
Yes .
Old 09-06-2017, 04:32 AM
  #1259
lavi rider
I've got a new hawk in the box already ..:-)
Old 10-02-2017, 03:42 AM
  #1260
In the Haze
Kit comes with 5 small and 1 large molded NACA ducts, you need to cut the fus and install from the inside. 2 on top rear section near the fin, 2 on the bottom rear section and 1 on the top of the nose section. Can anyone help with the position of the bigger one, I cannot fathom where it would go.
Old 10-02-2017, 03:48 AM
  #1261
Dave Wilshere
Think its the same mouldings supplied with the L-39 so its not used on the Hawk
Old 10-02-2017, 03:55 AM
  #1262
In the Haze
Ah ok good, tks Dave.
Old 10-02-2017, 01:23 PM
  #1263
Springbok Flyer
Springbok Flyer's Avatar
Sounds like you are having fun Nev!
Jan
Old 10-02-2017, 09:34 PM
  #1264
In the Haze
Yep Jan, pretty enjoyable build though.
Old 10-03-2017, 12:24 AM
  #1265
Springbok Flyer
Judging from what I saw in your workshop the other day, another top job no doubt.
Cheers,
Jan
Old 10-07-2017, 05:46 AM
  #1266
Bobneal1
My Feedback: (21)
Default Main gear locks?
My main gear from Aerotech Germany does not lock in the down position. It needs a small amount of air pressure to hold the slides at the travel limit, which is not at the end of the slots in the retract side frames.
Is this correct?
thanks
Old 10-07-2017, 07:12 AM
  #1267
DUCMOZ
From what I know, that is not right. Mine locks in either up or down position and remain locked even if the lines are disconnected. In fact, all the retracts that I have ever had acted in this manner so you might have a problem with the gear.
Behzad
Old 10-07-2017, 08:36 AM
  #1268
Bobneal1
My Feedback: (21)
Default Gear locks
Well, if you are correct , mine is machined incorrectly. There is no physical way it can lock down . The trunion block has curved surfaces that hook. The slider hits those hooks and stops. It could never pass to the ends of the slides because the trunnion stops it. I'll post a picture soon
Old 10-07-2017, 09:49 AM
  #1269
DUCMOZ
The only retracts that I know needed air to stay (in that case up) was the spring air and we used those late 80's or early 90's. But, this could be new design. I know I wouldn't like it . As you mentioned, maybe the geometry is a little off. Maybe Dave can comment as he is well knowledgeable.
Behzad
Old 10-08-2017, 06:20 PM
  #1270
Bobneal1
My Feedback: (21)
Default Photos of retracts
[img]webkit-fake-url://0b3a32c8-806b-4103-909b-d6e19ccf0d19/imagejpeg[/img]That's as far as the slide will go
Last edited by Bobneal1; 10-08-2017 at 06:40 PM. Reason: Photos didn't come through
Old 10-09-2017, 12:56 AM
  #1271
Mike Haddox
If you remove the top two set screws that holds the gear legs on would that help? Try that.
Old 10-09-2017, 05:28 AM
  #1272
Bobneal1
My Feedback: (21)
You can see the trunnion has curved tips at the end that stop the slider from going to the end of the slot. In the first picture , the slider is as far as it will go.
Old 10-09-2017, 07:14 AM
  #1273
rhklenke
My Feedback: (24)
rhklenke's Avatar
Here's the picture of the gear with the slider in the "down" position...
Old 10-09-2017, 10:10 AM
  #1274
jws_aces
My Feedback: (33)
jws_aces's Avatar
When the slider is at the end travel the trunnion has a flat spot it rest on as show in the picture it is also overcenter so the weight is also adding in the lock. I have not see any issues with this set up in both my Hawk and I have a EA havoc that has the same on air. I have used the air before on my hawk when I had a electric motor fail and it worked perfectly.
I wouldn't recommend changing anything.
Old 10-09-2017, 11:27 AM
  #1275
topiwala
Easy fix on that issue. It’s merely an issue of the trunnion not rotating far enough to allow the slider to ride fully to the down and locked position. And I wouldn’t leave it like that.
Two things to look for. The trunnion has four grub screws on one face which are there to lock the gear leg in place. If these grub screws are not fully screwed in and are sticking out at all, then they will hit and bind with the aluminium cross member post which is there to stop the trunnion rotating too far. Check that the grub screws are all the way in.
Second thing to check is really just that alluminium post that the trunnion rests against in the down locked position. In my one, I had to loosen the two hex countersunk screws to loosen the post, push the trunnion against it until the slider moved fully to the locked position, and then re-tighten the hex screws. It’s just an alignment exercise.
The aluminium post that I’m referring to is the round cross member which also holds the red retract frames together. I’m talking about the top right corner one in your picture,
This should fix the issue. Other than that there should be nothing wrong with the retract. I had to do the same on mine.
