Census of Hotspots !!!
Reply
Old 01-20-2013, 10:09 PM
  #151
iiievolution
iiievolution's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Census of Hotspots !!!
Hello
I like your color. What brand/code number/name is it.
iiievolution is offline
Old 01-21-2013, 03:09 AM
  #152
B.S.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Carlos
Yes it is painted and the same problem as usually with to much weight.
With P100 and 2 litrefuel the weight is10,4 kg.
It is 0,5 kg to much
Hi iiievolution
Thecolors are:
Grey metallic / Ford Moondust Metallic
Bluepurple / Honda B90P
Later this week I will add a picture of the plane taken with a real camera.
The purple color seems blue with a photo taken with my mobile phone.
B.S. is offline
Old 01-21-2013, 04:42 AM
  #153
iiievolution
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info.
Paul
Old 01-22-2013, 01:27 AM
  #154
mauryr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cmjets
Hi again:
Yes, this system run perfect, I fit the bank with 2 screws and you can easily remove it from. You can put the smoke pumb down too.
I am working in another Hotspot, I need make the bulkheads for can close it. The nylon hinge is installed in the process of laminate, the door is in carbon fiber.
Regards from Spain.
Carlos Márquez.
_______________________________
http://cmjets.blogspot.com.es/
Tested balance with all components in their intended position and it seems like I can put pump, solenoids and ECU in the gear bay, so I can just send one fuel line, the throttle, the main power line and an extension for the GSU from the front to the back. I am a bit concerned that the components might get fouled up by the gears during a landing in grass or might be disturbed by strong airflow in flight. Am I thinking too much or would it be best to protect them a little?
mauryr is offline
Old 01-22-2013, 02:24 AM
  #155
daorizio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very easy out of the situation: you have to stall .
In the video (5'10'') I make the flat spin, I change the direction of rotation, I stabilized the model, pull up and pull down the elev stick. Obviously I have rudders.
The exit is facilitated by the position of the CG back.
This model is over 12 years old, hundreds of flight.
Last summer I given the model to my friend. He made other 20 hours of flight too. And he flight every week.... forever....
http://www.youtube.com/watch?v=n1Xgv...ature=youtu.be
damiano
daorizio is offline
Old 01-22-2013, 02:36 AM
  #156
mauryr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: daorizio
damiano
Ciao Damiano,
thanks for the tip, if I end up in the same situation again I'll try cutting the power and have faith
And yes, I should cut rudders some day.
mauryr is offline
Old 01-22-2013, 06:42 AM
  #157
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi friends:
Really the Hot flown perfect and all components all well fixed, no problem with the LG. When you close the gears the hole is almost closed, and the wind not would be a problem, I think.
Now I not have any Hotspot in flight. I will built another and I will install in the same way.
If never give me problems, not will give me now.
I remember that I used Ni-Cd bateries.
BR.
cmjets is offline
Old 01-23-2013, 12:13 PM
  #158
wichet
wichet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
here is a couple of Hotspots ive had in over the years. Looking to buy another one in a few months, can't seem to stay away from them.
Custom paint scheme was my first ever turbine jet that i cut my teeth on.
Red Bull scheme i got rid of only last year after buying a second hand airframe and re-doing it.
Wichet
ID:	1843588   Click image for larger version
wichet is offline
Old 01-23-2013, 02:22 PM
  #159
iiievolution
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wichet
Hi
Wichet
Hello
Your custom paint hotspot in the first picture is in Cyprus alive and well. A friend of mine has it.
Paul
Old 01-23-2013, 02:31 PM
  #160
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cricky its made its way from Tyne and Wear UK to Cyprus, pretty good flying. LOL
Mike
BaldEagel is offline
Old 01-24-2013, 12:53 AM
  #161
wichet
wichet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's nice to know it's still flying. Goes to show how good of a model they are.
Wichet
wichet is offline
Old 01-24-2013, 07:56 AM
  #162
flyinfool1
flyinfool1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keep the pics coming guys. I'm building a YA Stingray which is a very similar plan form and am getting a lot of good ideas from this thread.
Lots of real purdy planes so far.
flyinfool1 is offline
Old 01-24-2013, 02:57 PM
  #163
B.S.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some pictures of my ready to fly HS
ID:	1843943   Click image for larger version
B.S. is offline
Old 01-24-2013, 08:49 PM
  #164
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice BS :-)
SJN is offline
Old 01-24-2013, 10:16 PM
  #165
VF169XO
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my Hotspot with a P-80 for power. Paint scheme is my last can of SuperPoxy metallic red directly over the white gelcote.
Had a lot of fun flying it but it didn't fly quite right until I put some down-thrust in the engine mount, then it grooved fine.
When I was investigating the stall characteristics, somehow I got into the flat spin more, very slow rotations. Recovery was with full power and a bit of down. very scary if you're not expecting it to happen.
ID:	1844079   Click image for larger version
ID:	1844080   Click image for larger version
VF169XO is offline
Old 01-25-2013, 08:57 PM
  #166
I-NAV
I-NAV's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here mine built back in 2005. Three engines and 3 sets of tires later it's still going..
ID:	1844352   Click image for larger version
ID:	1844353   Click image for larger version
I-NAV is offline
Old 01-27-2013, 04:44 AM
  #167
maxijets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello to all from Argentina
RED BULL Hotspot This was put together by me for a client, in my country. This photo was taken a year ago, the plane still flying and that is fine.
It is equipped with an old Ram750 plus it works awesome (electronica Xicoy), JR & Hitec servos, Robart retracts.
Hope you like.
Regards
ID:	1844766   Click image for larger version
ID:	1844767   Click image for larger version
ID:	1844768   Click image for larger version
ID:	1844769   Click image for larger version
maxijets is offline
Old 01-30-2013, 06:30 PM
  #168
cuevasan
cuevasan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[8D] Here is my new paint job on Hotspot Carlos just waiting on you my friend for that canopy so i can fly.
ID:	1846245   Click image for larger version
ID:	1846246   Click image for larger version
cuevasan is offline
Old 01-31-2013, 05:04 AM
  #169
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi friends:
Finally, the next week I will have more Hotspot canopies for send. If someone need a canopy for the Hotspot I can make it.
Regards from Spain.
Carlos Márquez
________________________________________
cmjets is offline
Old 02-01-2013, 01:09 AM
  #170
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carlos,
You will be a very popular man worldwide!
Regards
John
John Tancock is offline
Old 02-01-2013, 06:32 AM
  #171
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cmjets
Hi friends:
Regards from Spain.
Carlos Márquez
And shipping is reasonable. I got one from Carlos, and I think it was only $28 for shipping to the USA. (PA)
Now... I wish it would warm up, so I can get it painted !!!!! Can't wait to fly mine when spring time get's here.
Dr Honda is offline
Old 02-01-2013, 11:56 AM
  #172
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Friends:
I do most things that canopy ... this is the broken fuselage of Johnny Woods and his new nose.
Regards from Spain.
Carlos Márquez
ID:	1846821   Click image for larger version
ID:	1846822   Click image for larger version
ID:	1846823   Click image for larger version
cmjets is offline
Old 02-04-2013, 01:05 AM
  #173
mauryr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Finally maidened mine on turbine power after flying it on EDF for a year.
Everything went well, until I engaged the brakes, then a wheel flew off
Sick of these eurokit retracts, I really need to bother and get something better.
Friend of mine is selling a set of behotec C36, maybe these would be better...
What is everybody using? Any decent set out there which fits the hotspot?
mauryr is offline
Old 02-04-2013, 03:23 AM
  #174
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello:
Where are the photos ???
I will install AirPower or Electron Retracts, maybe the last with AirPower struts and wheels.
Regards from Spain.
Carlos Márquez.
______________________________________________
cmjets is offline
Old 02-06-2013, 05:08 AM
  #175
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi friends:
I have more canopies of Hotspot, if someone need it, please, tell me it before spend the plastic.
Regards.
Carlos.
cmjets is offline
Reply
Display Modes
