Reload this Page >
Which UAT for P200sx
Old 01-01-2013, 07:52 AM
ricardinho
Default RE: Which UAT for P200sx
it wont hurt using this big one on the 180 will it..? it says for engines 200 and up...just wanted to overkill it a little..haha
Old 01-01-2013, 07:56 AM
ricardinho
we are talking about the cylinder shaped composite one correct? the one that todd at dreamworks sells...
Old 01-01-2013, 09:28 AM
marc s
marc s's Avatar
i was thinking of getting the big cat uat for this build ..seems thats the best for the bigger engines...what do you think
The fittings and bores on them are the same on the CAT-M and the CAT-L - the rule of thumb is really around what space you have, fitting the largest CAT within your build confines is the best option.
In addition to this the CAT-L is designed to give a P200 size turbine around a 20-30 second full power 'reserve' whilst the CAT-M will give similar to turbines around the 140N size.
Hope that helps.
marcs
