If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
  1. #1
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Interview of r/c jet engines users&owners
    Hello,
    I would know is it big advantage for you to use kero/burner against air/gas(propan+air compressor) start? Would you use engine with gas start if it would be better than your with kero-burner. Better i mean: lighter, lower dimesions, better
    maintenance interval, lower comsumption of fuel. Pls be advised we tolk about much butter amounts not just 5-7%less or better we says in times. Thx a lot for all whom answer to me.
  2. #2
    Robrow's Avatar
    Join Date
    Jan 2002
    Southport, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Interview of r/c jet engines users&owners
    It makes no difference to fuel consumption, dimensions or maintenance using a kero start engine as opposed to gas start. Advantages are no requirement to carry a gas canister, no glow plugs and generally much more convenient and user friendly.
    Kero starting can take a little more time to reach idle (only seconds) but most people use this time to do all those little see off jobs like installing canopy/access panels, disconnecting start/taxi tank, flight control system checks and generally getting into their comfort zone, etc.
    Hope that helps.
    Rob.
    UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU\'\'\'\'s UK
  3. #3
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Robrow thx for your answer. But I ansking something different. If i would offer you turbine with max diametr 100mm, weight 800 gramm, trust 8-9 Kg, consumption 3 times lower than JetCat JP80 and near Lamber Colibri would you by it but with gas start? Or you prefer JetCAt with kerstart?
  4. #4
    Henke Torphammar's Avatar
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    Robrow thx for your answer. But I ansking something different. If i would offer you turbine with max diametr 100mm, weight 800 gramm, trustΒ* 8-9 Kg, consumption 3 times lower than JetCat JP80 and near Lamber Colibri would you by it but with gas start? Or you prefer JetCAt with kerstart?
    A Kingtech K170 seem to have a 35watt(5.5amps on a 2S pack) burner and uses 100mAh for one start Not that much I think.
    We have just made tests checking tempratures on a kerostarting P20 and it's not as bad as is looks, flames shooting here and there but not as hot at you would expect. More tests will be done soon, where among checking the mAh needed to kerostart the P20. When cold outside it fails to ignite on the first couple of tries, but so does a gas started engine. However if useing a small battery it might be a problem. Important for the small jets but not a problem for larger jets where a larger battery is used.
    /Henke
    www.youtube.com/henke2
    Ready2fly - T45 Goshawk, Lambert Kolibri T35. Perfect if I want to do carrier training!
  5. #5
    Join Date
    Feb 2009
    sint-maartensdijk, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i like gas start
    the startermotors have to run much less, and the engine is starting much quicker
  6. #6
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: frema
    i like gas start
    Yeah that too! Kingtech and Jets munt do wear starter motors. I even made an upgraded 400 sized starter pod for the Kingtech engines :-)
    P20 Kerostart ~50sec
    Kolibri gas start ~25sec
    /Henke
  7. #7
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thx a lot for your answer.
    But we need to understand would you buy turbine with propan start, with 100mm diameter, 80-90N trust, weight ~0,7Kg, fuel consumption 60-70ml/min, with price about 2999USD. Or you prefer usual turbine with ker-start.
    thx
  8. #8
    Join Date
    Oct 2002
    Ljungby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    thx
    For me performance is more important then kerostart, specially as I fly small jets. I choose gas start with much better performance and feel good about it
    /Henke
  9. #9
    Robrow's Avatar
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Kero or gas start do not make any difference to performance.
    Rob.
  10. #10
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I try to say that we could offer better perfomance but only with propan& air start so would you buy turbine with it or you any way prefer old kero-start turbines.
  11. #11
    Join Date
    Jul 2006
    Norfolk , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There is no doubt the average jet flyer prefers to have kero start as it reduces the amount of things to bring to the flying field and would expect it of new engines. You should set this up as a poll.
    To your engine proposal, is the consumption 70ml at a steady 90N for 1 minute? This is a huge reduction from all engines currently on the market. Maybe you are quoting an average consumption?
    John
    John Wright
  12. #12
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yes it's correct about 70ml/min for 80-90N trust. Reducion in consumption will be because it's turbofan engine.
  13. #13
    Join Date
    Jul 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK now I understand. Well new technology is always welcome and if you can bring this to the market you will be the first, well done!
    Kero start is not that difficult to achieve and worth the effort to install it.
    John
    John Wright
  14. #14
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, it's not difficulty to use kre-start but in our it's not possible to use same kero-burner as on the market it's too big for us, make our owne burner it's time and money for buyers. So now we try to understand is it better to make engine fater with propan start and cheaper or take more time and put kero-burner
  15. #15
    Dr Honda's Avatar
    Join Date
    Apr 2005
    Latrobe, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    thx
    I can tell you right now that no one will buy a new companies turbine for that price. Wren just brought out their Jubilee for $1900... the Jet Munt VT-80 is $1900, and the Kingtech is $1800.
    If you want to have a chance in the USA market... your 80~90n turbine will need to have Kero start, and be less than $2000 USD. People will buy gas start engines... but they need to be even less.
    Just my 2 cents.
    Tony
  16. #16
    Dr Honda's Avatar
    Join Date
    Apr 2005
    Latrobe, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    Ok... That makes a difference.
    So... instead of keeping secrets... tell us EXACTLY what your company is going to bring to market... and we can give you REAL feedback. When you ask a cryptic question, with only half the info... then the answers you will get are not going to be real.
    But... I can tell you that most guys don't want to go back to air start... and honestly... there is no reason to do it. Regardless if you are going to build a turbo fan... you can still put a pod on the front.
    Tony
  17. #17
    RCISFUN's Avatar
    Join Date
    Apr 2002
    Erie, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    thx
    A commercially available Turbo Fan would be unique for sure, maybe enough to justify the higher price.
    However as mentioned already there are plenty of main stream companies with established records, service facilities, customer support, etc, that have a very good product for a lower price. This is a very niche market; if you want to be successful and be able to sell for a premium price then you have to bring something vastly different to the market, additionally it is imperative to have an established and reliable service / customer support network.
    Speaking for myself, I would not buy a product that I have to ship half way around the world for service.
    As for the Kero start vs. Propane start question I started with a propane start turbine and resisted the kero start offerings until I bought my Jet Central Cheetah, now I would not trade it!
    I summed up the specification you mentioned in a table, see attached:
    It would be real interesting to see a Turbine that produces 20 Lbs of thrust that only weighs 1.5 Lbs and consumes 2 oz. / min....
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Rich
    Jeti USA Flight Team - DS-16, Xtreme Arf, Fei Bao Jets, Jet Central: SE Rhino 200, Cheetah, & Super Eagle owner
  18. #18
    Robrow's Avatar
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Might be an idea to give us some pics/video if you have a working engine.
    Rob.
  19. #19
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thzfor your feed back but it's hard to make two thinks on engine because of it's very small - it's electric motor and kero-birner. That's why it's could start only by air from car air compressor and from propan. WE will present our engine later by company when we end test. Right now we need to understand is it possible to sell it with propan start or need to close this project and make different engine.
  20. #20
    Join Date
    Nov 2002
    louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    dont think propane start would be a negative attribute if engine is a good value and quality product. however the air start would present a difficulty. I believe that for a true fan engine modelers will overcome the difficulties to own and operate this engine.
    AMA427952
    Freddy Schneider
    I still fly fans and now a Shocker too
    Jet Central VT-100 Rabbit!!!!!!!
    Skymaster F15, kingtech 140 G
    And anything else I can get my hands on.
  21. #21
    grbaker's Avatar
    Join Date
    Dec 2001
    La Porte TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not sure what you mean by car air compressor. Can you explain a little? I don't mind propane start at all, but I really do not want to have to use a scuba tank.
    Gary Baker
  22. #22
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thx a lot everybody whom asnwer. Happy New Year. About air compressor for car - on a top of the engin will be plugin connection for your car air compressor to start rotate HP stage. We use this becase whole engine is very smal and if we would be use electric start it will be needs for gears with dimensions about just 3mm so we going to use air compressor start. It's not that hard for us to make our owne kero-burner and electric start but it's will take a lot of time and the end product will be cost much higher for buyers than now, that's why i try to get faadback about readyness of the marker for that kind engine.
  23. #23
    husafreak's Avatar
    Join Date
    Dec 2004
    Livermore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm new to jets but what I learned was kero or gas start is optional, doesn't matter, but I will use the kero start feature on my Cheetah. Air start is very old fashioned, but worth it if you get a great deal on a used engine. Turbo fan means new technology though, some will be willing to go back to air start just to have it. But if it is very expensive then I don't think it will sell well. I do think starting small is a good idea, people will try new technology in a less expensive airframe. Like a 100 or something. oh yeah, as a newby I am very surprised how many jets have short flight times, this a function of tank size more than anything, little engines at full power or big engines at low power both equal similar burn rates. I think the number one sales feature of a turbo fan would be low fuel consumption. if you can do that the demand would be pretty high.
  24. #24
    Robrow's Avatar
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: xmen3k
    Thx a lot everybody whom asnwer. Happy New Year.Β* About air compressor for car - on a top of the engin will be plugin connection for your car air compressor to start rotate HP stage.Β* We use this becase whole engine is very smal and if we would be use electric start it will be needs for gears with dimensions about just 3mm so we going to use air compressor start. It's not that hard for us to make our owne kero-burner and electric start but it's will take a lot of time and the end product will be cost much higher for buyers than now, that's why i try to get faadback about readyness of the marker for that kind engine.
    I don't think using a car (12v) air compressor would be an issue as most of us already use them for the landing gear. Also gas start no problem.
    Sounds like your prototype is a 2 shaft engine? Rotating HP stage with air is how we start the fullsize engines.
    Rob.
  25. #25
    Join Date
    Dec 2012
    Perm, RUSSIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes you are right engine is two shaft.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
