NEW PRODUCT IDEAS FOR 2013?
Reply
Old 01-02-2013, 04:40 PM
  #51
rorywquin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: NEW PRODUCT IDEAS FOR 2013?
http://intairco.net/
Also have a few nice jet fittings but postage to the UK / USA etc may make them too expensive. .
rorywquin is offline
Old 01-02-2013, 05:11 PM
  #52
David Searles
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a "Tips & Tricks" book compilation of your scale and custom build techniques with lots of pics and explanations of how you go about creating some of the master pieces I've seen you constructing over the years. I'd buy it for sure!
David S
David Searles is offline
Old 01-02-2013, 06:39 PM
  #53
FalconWings
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1. External AC generator that can be connect to the engine shaft fitted with an inverter/regulator to power up the RC system. Batteries would only be used for startup and backup. (Remember Genesys by Sullivan? Only required an engine spinning at 8000 RPM).
2. A fitting adapter at the compressor stage of the turbine connected to a pressure relief mechanical valve to provide constant air pressure to the air system. Even if you have a leak, your air system would still work.
3. A reasonable cost smokewinder system. Think a kero start type hot plug inside an AIM 120 body, big enough to generate the needed heat inside a hot chamber, with two lines fed in and routed inside the wing: one feeds fuel through a 4mm line to keep plug hot, the other is a 3mm that feeds in smoke fluid.
Not sure you can get it done this year, but it could keep you busy.
David
FalconWings is offline
Old 01-03-2013, 12:22 AM
  #54
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Marc,
Any chance to see the spring loaded hinges idea materialize somehow? or maybe you have reasons to believe that it would not operate properly?
Regards,
Dany
extra 300 is offline
Old 01-03-2013, 12:51 AM
  #55
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David I am flattered, not sure my techniques are really that ground breaking! - a book from you would be more beneficial to the RC community.
Falconwings the B300F has an internal converter but appreciate its not the ideal size turbine for everyone....
Not a sidewinder but I am working with a colleague to develop a really intense smoke fluid that hopefully will deliver thick dense smoke at 40% less volume than current fluids - less smoke fluid more smoke for longer
Dany its on the list for consideration, only issue with small items like this you need to make 1000's to really see a benefit and not sure there is that sort of demand - love to be proved wrong though.
Keep the ideas coming
marcs
marc s is offline
Old 01-03-2013, 01:22 AM
  #56
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: FalconWings
A friend of mine who was an engineer on full-size jet engines actually did that to provide air for the wheel brakes but it never worked. The output from the compressor stage is well below the sort of psi our retracts and brakes typically work with.
HarryC is offline
Old 01-03-2013, 01:26 AM
  #57
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know some turbine manufacturers have a pressure outlet (AMT?) which has been used to add positive pressure to fuel systems but also with the advent of electric gear and brakes I feel air has a limited role in RC jets/planes.
marcs
marc s is offline
Old 01-03-2013, 01:30 AM
  #58
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
marcs
[/quote]
Marc,
Appreciate your feedback and fully understand your concern. If it makes a difference, i would be willing to get 80/100 pcs for my little fleet...
Old 01-03-2013, 02:04 AM
  #59
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: HarryC
For brakes I could understand why. Under 70 psi you really don't do much. But if you can accumulate 30-35 psi during 6 minutes of flight time, it could be enough to lower the gear. Again, something lightweight as a backup.
Old 01-03-2013, 02:08 AM
  #60
FalconWings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
marcs
Hey that's not bad, similar concept. To make a good smokewinder a highly concentrated smoke oil would be ideal, specially if less heat is needed to make half a decent trail.
You are onto something great!
Old 01-03-2013, 02:11 AM
  #61
Robrow
Robrow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a small range of landing gear/trailing link struts (with compression rather than extension springs) to compliment the electric brakes/wheels for the many flyers on a budget these days?
Rob.
Robrow is offline
Old 01-03-2013, 02:28 AM
  #62
Carsten Groen
Carsten Groen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
David I am flattered, not sure my techniques are really that ground breaking! .
Thats the very first time I have seen you being wrong Marc
Does the "request for new product ideas" also include electronic stuff (or just purely mechanical) ?
Carsten Groen is offline
Old 01-03-2013, 02:52 AM
  #63
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carsten so what do you want then......
Electronics is fine too as long as its not very complex.
marcs
marc s is offline
Old 01-03-2013, 07:25 AM
  #64
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Love the spring hinge idea, on any trike UC if not attached to the legs then each door would require at least two hinges, getting close to 10 hinges per airframe, most of us have at least two or three airframes that make about 30 for each of us plus some spares, would not take long to get the 1000 needed for manufacture.
Mike
BaldEagel is offline
Old 01-03-2013, 09:02 AM
  #65
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike, the numbers could creep up but here are a few questions - are people going to replace existing hinges (not sure they would) and would a spring device that could be added to a door to do the job be an interesting option?
marcs
marc s is offline
Old 01-03-2013, 09:28 AM
  #66
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
marcs
I'll get back to you on that, have a couple of ideas (development is already done, just need someone to produce and sell it )
Old 01-03-2013, 10:23 AM
  #67
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look forward to the info
marcs
marc s is offline
Old 01-03-2013, 12:30 PM
  #68
extra 300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
marcs
Absolute YES. The end result is what we would all be looking after!!
Regards,
Dany
Old 01-03-2013, 12:45 PM
  #69
jetmodeller
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Robrow
Rob.
Hi Rob check out spring air they do exactly what you are after regards Keith w
never did get those Rhino bits!!
jetmodeller is offline
Old 01-03-2013, 03:24 PM
  #70
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
marcs
Hmm a spring to add to an existing hinge would probably be even better, if only to help all those ailing rams and servo's out there.
Mike
EDIT: one suggestion how about a wrap around sleeve that allows us to position the air nipple where we want on retracts .
Mike
Old 01-03-2013, 11:45 PM
  #71
DominicM
DominicM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several systems for electric flight where remaining capacity can be seen on the ground so why not a telemetry based fuel level? or maybe onboard beacon indicating low level? With the fuel sloshing around in the tank would suspect you'd have to do it by analysing fuel flow rate into the engine to calculate what is left.
DominicM is offline
Old 01-04-2013, 02:40 AM
  #72
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Both already available, but the on board fuel system means cutting into your tank with the disadvantage's associated with making holes in a perfectly good tank, JetCat have a fuel flow/amount used on board, can't be too difficult to put a warning light or telemetry on this especially with the new wave of telemetry enabled Rx's available.
Mike
Old 01-04-2013, 04:27 AM
  #73
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is an idea from a PM'd suggestion and wanted to see what you guys felt about it.
I always hate doing hinging and horns on any build (closely followed by the canopy!) so the suggestion was a neat simple and easy to use alignment jig to help builders make 100% sure horns are placed and glued exactly in the right place on the chosen control surface.
I envisage a fully adjustable jig which will adjusted and set for one surface and then used on the other to give 100% accuracy. It will keep horn(s) in place while they set at the correct angle and in the right place.
Any good?
marcs
marc s is offline
Old 01-04-2013, 04:32 AM
  #74
Countryboy
Countryboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BaldEagel
Mike
Assembled spring loaded hinges would be nice, but really not that hard to make your own. Hadn't really looked at it, but I'm sure the concept could be applied to offset hinges as well.
First pic is the hinge and the second pic shows it in application.
ID:	1836641   Click image for larger version
ID:	1836642   Click image for larger version
Countryboy is offline
Old 01-04-2013, 09:09 AM
  #75
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: marc s
Any good?
marcs
That would be a welcome addition to my shop and while your at it how about a router and routing guide for the horns??
Bob_B is online now
Reply
Display Modes
