Feibao 1/9.5 Eurofighter Typhoon 2x Kolibri T25
RE: Feibao 1/9.5 Eurofighter Typhoon 2x Kolibri T25
ORIGINAL: marc s
Henke nice work as usual, wondered why you chose a dye for the epoxy and more specifically why pink?
marcs
marcs
ORIGINAL: marc s
Ah OK seems an honest enough explanation - looks kinda radio-active
The canards are beeing balanced with lead shots. I do not know if it's needed but it won't harm I guess.
#31
Landing gear and servos are in place. The parts do fit well. The linkages are a bit beefy, but I beleve it adds marginal weight and provides a good rigid setup to match my Futaba über servos
I do not know if I ever will disassembly the airplane but I added multiplex type of connectors if I decide to remove the wings in the future.
#32
I've started assembling the accessories that will be mounted in the nose. The bullet shaped aux bridge is quite heavy at 100grams, but as it doubles as holder for a numerous gizmos, includeing the canard servo I think the weight is not that bad. Also the weight is added way in front of the CG which is good.
I've choosen the Jeti range for supplying electricity. A SBEC capable of 6.2A continious controlled by a DSP 40 switch is all that's needed :-) I'm also installing a lighting system from HAB with insane brightness. The controller is also seen on the board and will be connected to the DSP 40 as well.
Two batteries are needed, a 3S 2500mAh for Rx, lighting and breaks and a very overkilled 2S 2500mAh for the two engines.
The new Lambert ECU that's just ready for production
#33
Lights are going in the Eurofighter. Hobbyking do sell excellent LED systems but I want to support my local dealer ;-)
I choose the small LED driver from HAB to handle wing tip lights green/red + 2 strobes and a landing light.
HAB offers these LEDs in a number of diffrent states. I choose to buy them solderd at HAB with heatsink and wires as it is a fiddly job to do and the LEDs easily breaks if it's done wrong.
The plastic armatures I make are called "Aerodomes" and are avilable in all sort of shapes and sizes. I choose the standard size and a curvature to fit the surfaces on my Eurofighter. 30mm for wingtips, 48mm for turtledeck and a flat one for the belly.
The LEDs solderd and ready to be glued in my Aerodomes. Large heatsink for solid light and small for strobes.
The LEDs + heatsink fits perfect in the custom Aerodome armatures
Thin CA glue fixes the LED-assembly to the plastic Aerodome, then fill up with thick glue to make it durable.
I prefer to sand the surface to hide the insides and make the light spread a little more.
Finnished Aerodomes :-)
Wingtips with the 30mm Aerodome
Turtledeck with 48mm Aerodome
Gotte love the Galaxy Note 2 with it's best pic option to capture the strobe ;-)
Alot of light well visible even on a sunny day. ...and this is noly 1LED per armature, they can carry three each(!)
#35
ORIGINAL: DelGatoGrande
nice draw of the aurofighter you got on your wall, where can we download it from?
thanx in advance
thanx in advance
#38
