2oz cloth
Reply
Old 01-05-2013, 05:25 AM
Joe Westrich
Joe Westrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2oz cloth
Ok, recently I just asked about Kevlar cloth and got a little education on it. I am now going to 2oz fiberglass, but I just had one more question. What would be the difference between single weave and double weave cloth? What would be the best for our RC application? I have fiberglassed a few airframes before, so I'm not new. I just want a better education.
Thanks!
Joe Westrich is offline
Old 01-05-2013, 05:37 AM
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 2oz cloth
Joe i have never used heavier tha 3/4 ounce cloth for finishing. Why 2ounce cloth?
Bob_B is offline
Old 01-05-2013, 05:53 AM
Joe Westrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
50+ lb jet with a P200
I use 3/4 on my 1/5 prop warbirds
I may go lighter than 2oz on the tail surfaces
Old 01-05-2013, 06:03 AM
thunderchief
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe, Check out this web site for cloth selection. They are out side of Dayton. If you use 2 oz I would consider vacuum bagging it.
Glenn
http://www.fibreglast.com/
thunderchief is offline
Old 01-05-2013, 06:07 AM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have never heare of single weave and double weave.. You typically have
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
Thayercraft.com has good info on glass, along with good prices
invertmast is offline
Old 01-05-2013, 06:37 AM
Robrow
Robrow's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think double=Twill where the warp fibres go over/under two of the weft, better drapability for getting into awkward corners and conforming to compound curves, etc. It has a front and back.
Rob.
Robrow is offline
Old 01-05-2013, 07:00 AM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh ok, i forgot about twill weave
Old 01-05-2013, 07:09 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have gotten better answers about cloth, resin and mold making on this thread
http://www.rcuniverse.com/forum/forumid_97/tt.htm
sidgates is offline
Old 01-05-2013, 06:52 PM
Joe Westrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: invertmast
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
That's kind of what I was looking at. Why the different formats and what applications would they be used for?
Old 01-05-2013, 06:55 PM
Joe Westrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: thunderchief
Glenn
A friend told me of that site too.
Is it manageable without vacuum bagging it. I don't have one.
Old 01-05-2013, 07:14 PM
thunderchief
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure, you can treat 2 oz cloth just like you would 3/4 oz or 1/2 oz cloth. When I lay up a mold my first layer is always a 2 oz layer of cloth because it is very easy to work with. It just takes more resin to fill the weave then 3/4 oz..
Glenn
Old 01-05-2013, 07:55 PM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Joe Westrich
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
Uni-directional is a fabric that has all of the glass strands going in one direction. This works well for needing strength in one direction only (spar caps for instance).
Tow is a non woven cord
Plain weave can be easy to work (conforms easier) with if it is loosely woven.. If its tightly woven (which is what I would suggest for glassing) it doesn't conform as well, but requires less filling of the weave. It also provides a consistent surface due to how it is woven.
4HS and 8HS is a bit stronger (less thread crimp) and offers greater conform-ability than plain woven fabric. I've never heard of anyone using this outside of a molded part.
Twill is kind of in between Plain and 4HS and 8HS in how it is woven. Typically when you see a "pretty" Carbon Fiber part, it is a twill weave carbon.
Old 01-05-2013, 08:57 PM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 2oz or 3.2oz crowfoot for my first layer in a mold. Below is a quote from WyoWindWorks on crowfoot.
Style 120 and 220 are good choices. The 120 will be slightly more flexible while the 220 is a little stronger. Either will work well.
Crowfoot is the same as a Harness Satin 4. The yarns go over 3, under 1, over 3, under 1, etc. This weave allows the fabric to be more conforming than a plain weave. It also allows the yarns to lay flatter. This is theoretically stronger since the frequency in the crimp of the fiber is reduced.
sidgates is offline
Old 01-05-2013, 10:19 PM
mr_matt
mr_matt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How would he vacuum bag? Isn't this going to cover the outside of a wood structure?
mr_matt is offline
Old 01-06-2013, 05:49 AM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You either vacuum bag with a foam core wing, or in a mold. Theres really no good way of vacuum bagging any other type of build structure
Old 01-06-2013, 06:51 AM
thunderchief
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right,, to vacuum bag it would have to be a foam wing. Vaccuum would probably damage a build up part
Glenn
Old 01-06-2013, 08:48 AM
sidgates
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't find any need to vacuum bag when doing one layer of cloth on a sheeted surface..
sidgates is offline
Old 01-06-2013, 09:12 AM
mr_matt
mr_matt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sidgates
Exactly
mr_matt is offline
Old 01-06-2013, 02:28 PM
invertmast
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sidgates
If you use some waxed mylar sheet (.014" thick) you can paint the mylars, the put a layer of wet out glass or carbon on the mylars. Then blot up the excess resin with a paper towel, then while wet you can vacuum bag this to a wing or tail surface. Once it cures, the mylars peel away leaving a painted part. This only works in simple surfaces though. Any compound curves makes it impossible to do.
Reply
Display Modes
