Hyperion 610i charger and balancing?
Reply
Old 01-05-2013, 11:11 PM
Dig it
Dig it's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hyperion 610i charger and balancing?
Hey, I have a Hyperion 610i and I'm wondering about balancing my Lipo's for my jet. I found this unit here.
http://www.rcdude.com/servlet/the-20...h-Plugs/Detail
I don't know if anybody has used this unit before, looking for some input. If this isn't the answer, perhaps suggest a charger to me that will do the job.
Dale
Dig it is offline
Old 01-06-2013, 01:18 AM
Justflying1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hyperion 610i charger and balancing?
Hello Dale,
All the lipos I have had all had a balance lead. If they do have a balance lead this should always be plugged into your charger so the battery can be balanced as its being charged.
As for the unit that you are showing you have to make sure that your balance plug on your battery will fit this unit. Different brand batteries will have different balance plugs so it’s a matter of getting the rite board to suit your plug.
Ivan
Justflying1 is offline
Old 01-06-2013, 05:19 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Exactly, find the balance tap on your battery and post a picture, I can tell you what board you need.
The 610 is a very good charger
BarracudaHockey is offline
Old 01-06-2013, 07:20 AM
lrb75
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a parallel charging board so that you can charge multiple similar batteries at the same time. they work just fine but a much more useful for high power (1000w) chargers. If you are looking to balance one battery at a time get one of these:
http://www.allerc.com/hyperion-multi...xh-p-3159.html
If you want to know what type of connector to get need to see it or give the battery brand.
lrb75 is offline
Old 01-06-2013, 07:33 AM
Dig it
Dig it's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah, I see. I have the batteries way up front of the jet where I can see them but can't get to the plugs. lol.
Ok, thanks fellas, quick answers to my simple questions as always.
Dale
Dig it is offline
Old 01-06-2013, 11:41 AM
Justflying1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dale,
you can get extension leads for the balance plugs. This way you would not have to move the batteries every time you want to charge them.
I will however say that considering Lipos can catch fire when charging I personally would not be charging them inside the plane. For this reason I only use life batteries where possible. One of my ECU does run a lipo which I remove for charging.
To save you some frustration from buying the wrong plug if you mention the brand of your battery as stated, someone on this forum will be able to help you tell you the exact plug to get.
Ivan
Reply
Display Modes
