If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 12 of 12
  1. #1
    Robrow's Avatar
    Join Date
    Jan 2002
    Southport, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Flap servo options.
    I am looking for flap servo options and wondering what standard size ultra high torque options there are other than say JR 8711 or Savox SC1256TG? Also digital or anologue?
    Rob.
    UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU\'\'\'\'s UK
  2. #2
    Join Date
    Jun 2002
    Watford, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Flap servo options.
    Rob
    Std size servos in my mind are 19mm width servos like the 8411. the 8711 is wider at 20.5mm but at the new special price the 8711 wins every time. Always always Digital, they were designed with flaps in mind...
    Dave
    Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Airtech Germany, Jet Tronics.
  3. #3
    BaldEagel's Avatar
    Join Date
    Oct 2005
    Kent, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rob
    I know they are not popular as some seem to have issues with them, I have used the 5955TG's in petrol 3D airframes for years without issue so the 7955's should be better, spec below:
    Hitec's best servo just got better. Based on the powerhouse HS-5955TG servo the HS-7955TG has the added benefit of Hitec's G2 second generation programmable digital circuit. This new circuit has twice the resolution of our original circuit while adding programmable overload protection.
    The HS-7955TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 333oz./in. of torque at 6.0 volts, all this power is harnessed by incorporating the industries first Titanium gears for incredible wear resistance and two strong hardened steel gear pins and axial brass bushing in the servo case.
    Hitec HS-7955TG Features
    G2 Digital Circuit
    Coreless Motor
    Dual Ball Bearing Supported Output Shaft
    Titanium Gear Train (MK first gear)
    Programmable Features
    Dead Band Width
    Direction of Rotation
    Speed of Rotation (slower)
    End Points
    Neutral Points
    Fail Safe On/Off
    Fail Safe Point
    Resolution* (default is high resolution)
    Overload Protection* (default is off)
    *these features are only programmable with the HFP-20 field programmer
    Mike
    My Gast is Flabered.
    No matter what anyone say's 100% is the maximum you can get.
    If you see a deleted post, my Avatar say's it all.
  4. #4
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Co. Donegal, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A Hitec 5645 is a standard size hi torque metal geared digital servo and more that adequate for flaps on most jets, if for some reason you need more power use the 5755
    www.letterkennymodelflyingclub.com
    www.jmaireland.com
  5. #5
    Robrow's Avatar
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I need them for the flaps on my big Tutor, the manual recommends 8711's, just wondering if there were any others in the same league that people trust with their multi $$$$ jet? I'll have a look at the Hitec's.
    How much is the new special price Dave?
    Rob.
  6. #6
    Jamie C's Avatar
    Join Date
    Apr 2008
    Somerset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rob,
    Go with the JR, i know that others would argue to the contrary but i would not trust Hitec in my jets and at £80 for the 8711 it does not make sense to go for Hitec. Buy with confidence, fit and forget!
    Looking at what the 7955 is going for which is about 60 ish quid, the saving is not really worth it when you compare it to what you would have spent on the airframe and turbine.
  7. #7
    Join Date
    Feb 2002
    private, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Jamie C
    Rob,
    +1 I would not let hitec in any of my models never mind the jets, had endless trouble with them
  8. #8
    Join Date
    Jun 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rob
    £79.99.
    I wanted to jump in with my boat servo comment on Hitec, but held off...
    Dave
  9. #9
    Xairflyer's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am a big JR fan, but cant complain about Hitec 625,645,5625,5645 either have used them for years.
    I regard to torque/servo power most modellers dont understand what actually are the forces on the control surfaces, and how to properly install the arms/linkages so you are not making your 25kg servo about 5.
    Very few control, surfaces or the wooden blocks stuck to ply which servos are mounted in will take a load of 25kg (more than a 4" concrete block)
    www.jmaireland.com
  10. #10
    Meesh's Avatar
    Join Date
    Jan 2003
    Dracut, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hitec 645MG analog servos. Never had one fail.
    Bob
    If it's worth doing, it's worth doing it right.
    AMA 779352, JPO 1965
    Kingtech K-80, K-100, K-140
  11. #11
    Join Date
    Dec 2001
    Plymouth, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No need for monster servos. I use Hitec 645MG's with properly set up linkages on all my flaps.
  12. #12
    grbaker's Avatar
    Join Date
    Dec 2001
    La Porte TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hitec 5645s programmed for 180 degree operation on JMP T-33 (shown), YA F-18 twin, Turbinator XL (125%)
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1843240   Click image for larger version.
    Gary Baker
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
