If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 24 of 24
  1. #1
    husafreak's Avatar
    Join Date
    Dec 2004
    Livermore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Gyros 'N jets
    I am interested in trying a gyro on the steering of my Electra or future jet... I see Dreamworks has a JR370 which is expensive and an Eflight which is reasonable. But now that the heli guys have embraced Flybarless units you can pick up a great heli rudder gyro for peanuts. Seams like a no brainier to me, just a single axis gyro right? And if I go gyro do you recommend Rate mode or Heading Hold mode, again I imagine rate mode would be fine for short landing or takeoff runs. Any advice on how to set the gain? Thanks
  2. #2
    JackD's Avatar
    Join Date
    Feb 2002
    Berkeley, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: husafreak
    Eric,
    You need rate gyro, not hhold.
    If you are installing one on the nose gear, you might as well couple it with the rudder. Rudder gyros always help.
    In my electra I have a jr 270 and works perfectly.
    Another option is the 370A, which is only rate
    Regarding setting, put it initially on a knob and increase the rate until you start getting tail wagging. Then dial it down a bit
    You also might want to have a higher gyro rates with flaps down than flaps up, so it will be more effective at low speeds and more effective on the ground
    Good idea trying to find a used one given the fbl migration, just make sure it has a rate mode
    Had fun flying today, Doing a great job with the electra
    Jack Gerardo Diaz
    BVM Rep, Team Horizon, Team Jet Central
  3. #3
    DelGatoGrande's Avatar
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Best Regards George
    www.rcjet.gr \"props are for boats\"
  4. #4
    Join Date
    Aug 2004
    tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    DelGatoGrande,
    Are you mounting these at the center of rotation or can they be mounted a little closer to the front of the cockpit where there is a little more room? Also, do you have a recommmended starting point for the gain when used in steering mode only?
  5. #5
    Join Date
    Nov 2003
    Martinsville, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    With the emergence of the AS3X tech, I have to wonder if gyros will go south in the future? I know it wil be awhile but look what they are doing to calm the little park flyers and stuff down.
    Scratch it till it bleeds Convert it till it chokes
  6. #6
    flyinfool1's Avatar
    Join Date
    Jan 2002
    Cudahy, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Gyros can be located any where. Gyros measure rotation. Hopefully the entire aircraft will always be rotating at the same angular velocity.
    The only critical mounting considerations are that it be mounted with its sensing axis exactly aligned with the axis of the aircraft. that it is sensing. Meaning that if you are using it for rudder or steering, the vertical axis of the gyro must me vertical in the aircraft.
    The other consideration is vibration. Most gyros do not like vibration. If flight this is not an issue. while on the ground, a bumpy runway like a grass field may cause some vibration and result in some slight issues.
    As mentioned above. Start with a low gain on a dial or slider and work up till you get instability and then back off some.
    Jeff Borowski
    RAMS Club President
    www.ramsrcclub.com
  7. #7
    Join Date
    Mar 2004
    ATHENS, , GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: sailing1
    DelGatoGrande,
    You can mount it anywhere it doesnt matter .I place at the nose close to the steering servo so i wont use extension.
    I would never recommend a starting point since geometry can change the outcome.For example trailing link nose legs need more gain than direct.
    Mount it and move the nose left and right.Gently corections is what you should see even in hard changes.
    Best Regards George
  8. #8
    sysiek's Avatar
    Join Date
    Feb 2009
    Chicago , IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Hi after flying the jets for full day we go for gyro or two with friends ,I only witness problems with gyros including two totall loss crashes, and for that reason I using mine pilot talent ,at least for now.
  9. #9
    Join Date
    Nov 2007
    Sandy Springs, GA GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Here is use what I use on the rudder of tail dragers for take off and landing:
    http://www3.towerhobbies.com/cgi-bin...&I=LXCNFR&P=SM
    Bruce
    Bruce L. AMA# 54227
    Ultra Sport Brotherhood #15
  10. #10
    husafreak's Avatar
    Join Date
    Dec 2004
    Livermore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Thank guys, good to hear the simple and cheap GWS gyro can get the job done. Come to think of it I have one of those in my DLG. The JR370A is 165 bucks so I will look for a less expensive solution, maybe the 270 is less. The Futaba looks good too, cant argue the quality there. I will probably stick with nose gear only initially at least until I figure how it would affect the rudder during flight? It would be possible to have the flap switch turn off the gyro (zero gain) on retraction, Or put it on a knob like you Jack said and play with it to see. All heading Hold gyros are capable of Rate Mode too as far as I know, it is just a function of how you set the TX gain. And while I agree with sysiek that the edible gyros are the best ones, I am very skeptical of how a gyro could cause a total loss crash, they are simple and reliable and pretty transparent.
    Jack, after replacing the main gear tires and adjusting the toe in the Electra was definitely handling better on the runway but still it is more sensitive to corrections at high speed than any model I have ever owned, it almost always wants to veer one way or the other on touchdown roll out.
    FWIW I picked up a Spectrum RX with the ASX3 system at my LHS last week, couldn't resist! Should be fun to play with, starting small.
  11. #11
    flyinfool1's Avatar
    Join Date
    Jan 2002
    Cudahy, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: husafreak
    The Futaba GY240 Gyro is Heading Hold only. It does not have a "Rate" or "Normal mode. There may be others that I am not familiar with.
    Depending on the failure mode of the gyro and what control it was connected to. It is possible for a gyro to fail in a way that locks the servo hard over to one side. This is not a common thing. In 15 years in helies and who knows how many thousands of successful flights, and failures of various sorts that I have seen, I have only seen this once. The most common gyro failure that I have seen (short of setup error) is the mounting tape letting go and the gyro flopping around giving all kinds of bad instructions to the servo. Many heli fliers now put a velcro safety strap over the gyro to prevent this.
    Jeff Borowski
    RAMS Club President
    www.ramsrcclub.com
  12. #12
    DAN AVILLA's Avatar
    Join Date
    Dec 2001
    roseville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    I have used the 240 for years in jets. The avs switch turns the heading hold off.  Dan
  13. #13
    dbsonic's Avatar
    Join Date
    Oct 2005
    san jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    I just put a JR G270 on the Bandit for steering only. Seems to help but still playing/finding the gain setting. Has both rate and heading options, but I'm using it in rate mode.
    P-40 Brotherhood #112
  14. #14
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: flyinfool1
    The Futaba GY240 Gyro is Heading Hold only. It does not have a ''Rate'' or ''Normal mode. There may be others that I am not familiar with.
    It has a dip switch, it just doesn't have the second lead so it can be changed in flight.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  15. #15
    Join Date
    Feb 2002
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    I love the 240. There is a switch to put in normal mode. Makes braking and takeoff wonderful. Also heli guys are giving them away. The last one I got lightly used for $30
    Performs awesome.
    Kevin Thoele
    Texas Jets Group
  16. #16
    Join Date
    Aug 2004
    tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Is there any problem with running two Gyros in one plane? I want to set up a small 1/8 scale Tamjets F16 with a Futaba 352 gyro running in Elevon mode and GWS Pc-03 for the steering. Both will need to be in the front of the plane, probably with the GWS right in front of the Futaba 352 due to space limitations. If this setup will work out, I would then like to duplicate it in a larger F35. I don't really think the little F16 needs the help but it should make a good air frame for me to get used to the gyros.
  17. #17
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: kevinthoele
    Performs awesome.
    Supply and demand, now that we know the jet guys want them the price will go up!
    www.JaxRC.com
  18. #18
    flyinfool1's Avatar
    Join Date
    Jan 2002
    Cudahy, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: BarracudaHockey
    Thats kind of what I ment, Once airborn you can not turn off the Heading Hold or make changes to the gain. So if something is a bad setting you are stuck with it till you land.
    Jeff Borowski
    RAMS Club President
    www.ramsrcclub.com
  19. #19
    Join Date
    Feb 2002
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    It is only controlling the nose stering. I have never had any issues with this. Is does not matter airborne. Just make sure it is working in the correct direction and take off. No worries!!!!
    Kevin Thoele
    Texas Jets Group
  20. #20
    Join Date
    Dec 2001
    Lancaster, CA IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Sailing1, you can run more than one gyro in the model. No worries there. Both of my latest jets have 3 gyro's in place, one for elevator, rudder, and ailerons. Makes teh jet just grove like no other!!
    John Redman
  21. #21
    Join Date
    Feb 2010
    Las Pinas, PHILIPPINES
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Anyone tried the new Futabe 431 gyros? at 80 bucks each they're pretty reasonable...
  22. #22
    Join Date
    Jan 2004
    BeirutBeirut, LEBANON
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    ORIGINAL: John Redman
    Hi John,
    Could you please elaborate on the systems you are using on your jets as i was thinking of getting into this setup on my large F-15E mainly for more scale flying.
    Thanks in advance
    Regards,
  23. #23
    husafreak's Avatar
    Join Date
    Dec 2004
    Livermore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    Good call Rush! Tower Hobbies has both the 430 and 431 listed and available for the same price. Don't know what the diff is...
  24. #24
    Join Date
    Feb 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Gyros 'N jets
    I think the 430,431 gyros are just upgrades of their old 350,351,352 series.  I think the 431 is the 351 upgrade which allows for two aileron servos or rudder/steering combinations.  Can also be used for delta configurations.
    havnt seen any reports on their use...  though but i wouldnt expect any problems with Futaba.
    I have used the 351 on two jet (rate mode only) and i like them.  The 431 shouldn't disappoint....
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
