If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 21 of 21
  1. #1
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Repair ideas needed
    I've got an old bvm aggressor that needs a new vertical fin- it was pulverized in shipping
    It was balsa sheet sides with cf strips and a coupled of ribs in it
    Looking for ideas on making a new one
    Either built up- I have no plans,or carved from solid balsa, foam core sheeted?
    Final looks/finish aren't important - just need to have a functional vert fin
    Anybody want to suggest ideas or have an old fin that would work?
    Viper, Agg ,1,2,3,even a Maverick fin may work
    I can get root length/width dimensions to try and match up an old fin
    Thanks in advance!
    Jake
  2. #2
    Join Date
    Feb 2002
    KALISPELL, MT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Repair ideas needed
    Don't know if you tried but call Patty at the factory and see if they have one in the bone yard that maybe can be used, or at least get specs on making a new one. Just an idea.
    Kelly Rohrbach
    BVM REP
  3. #3
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Turbine Guy,
    Do you know which version of the BVMAggressor that you need a new fin for?
    The very early ones, based upon the Sport Shark, utilized a Magnabuilt construction process where multiple spars replaced conventional ribs. These were sheeted over with balsa that had CF strips applied to the inside surface. Also, this Aggressor version had a 1-piece wing. I know because I had one. The fin structure on the later versions (Aggressor II, etc) were more conventional with ribs, leading and trailing edges which were sheeted with balsa. The later wings were two-piece that were retained by CF blade spars.
    I do have a set of full size blueprint plans for the later Aggressor and can copy the fin section for you.I don't believe there is much difference in the sizes. I also have the original instructions for the early Aggressor. Please send me a PM with your best mailing address.
    Art ARRO
  4. #4
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Kelly
    Yes, first thing I did was try BVM - way out of production
    Even Hoping somebody has an old fin I can use
    Plans and manual would work too
  5. #5
    Join Date
    Jan 2002
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why not get an Electra Vertical Fin.
  6. #6
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is the root size/shape similar?
    Its been 3 weeks ,still waiting for Someone at BVM to call me back regarding finding a suitable fin
  7. #7
    Greg Wright's Avatar
    Join Date
    Sep 2008
    Illinois
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is the length and width of the root rib or the base.
    I can measure my Electra fin for you.
    Greg Wright
    Team Horizon Member/ Horizon Hobby/Spektrum/Hangar9/ E-Flite/Blade Heli's
  8. #8
    Vettster's Avatar
    Join Date
    Sep 2007
    Beeton, Ontario, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We might be able to offer a suggestion to repairing it..but would like to see photos first.
    My Scratch Build. Turbine powered WetJet http://www.rcuniverse.com/forum/seap...l#post12025108
    Club NO MAX! No boarder..No Limits..No POLITICS! NO "MAX"
  9. #9
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I plan to send Turbine Guy a drawing of the Aggressor fin along with the instruction manual. I've searched for the Aggressor II blueprints in my shop but have not yet located them. The drawing will be created off an old Aggressor I hulk which I have found. We've determined that it an Aggressor I from the description he provided via PM. Thanks all for the assistance in this.
    Art ARRO
  10. #10
    Join Date
    Jan 2013
    , , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Depending how big and thick it is it is actually quite easy to carve one out of a solid piect of balsa. I find that a file type sander is very good for this
  11. #11
    Join Date
    Dec 2001
    Oxford, MS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Which Aggressor is it? I have an Aggressor II taha I coudl take some measurements from.
    David Reid
    BVM Rep
  12. #12
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all
    Looks like its aggressor 1
    I think Arts drawing and manual will work for me
    Thank you all for the help!
    Jake
  13. #13
    Join Date
    Dec 2001
    Lancaster, CA IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jake,
    I have an original BVM Sport Shark with the F-20 fin still in the box.
    Vertical fin for the Sport Shark (F-20 variant),Agg 1, and Agg 2 was the same mangalite construction method and part. Only difference between these were the magnalite built wings and stabs on the Agg 1 and the foam wings and stabs on the Agg 2. Slight variances on the fuse and wing from teh Sport Shark to the Agg's
    Wing retention system was the same from the original sportshark thru the Agg 2 and Viper. One piece wing with blade saprs.
    I can take meassurements of my fin as well as copy the root and tip rib for you.
    John Redman
  14. #14
    dbsonic's Avatar
    Join Date
    Oct 2005
    san jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    original viper vertical fin was foam sheeted and the rudder itself was solid balsa that you had to carve to shape. For mounting, a couple of embedded balsa hard points to take the vertical fin former mounts. Not hard to make.
    P-40 Brotherhood #112
  15. #15
    Join Date
    Dec 2001
    Lancaster, CA IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You are right. The more I think back the Agg 2 vertical was foam as well. [:@]
    BV left the Magnalite structures behind in the Viper and Agg2 series.
    John Redman
  16. #16
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    John,
    If you would trace the outline of your NIB Sport Shark fin and send it to Jake it would be most appreciated.
    I've searched my shop, top-to-bottom, right-to-left but could not find the Aggressor II blueprints. It really frustrates me, as I did locate the mailing tube and packing list that Patty sent to me a while ago. I've copied the Sport Shark instruction manual at Staples and will send this to Jake later this week.
    I'll also recreate a finusing a building technique and send Jake the directions. Themethod employs athin (1/16th)balsa sheet core with balsa leading and trailing edges attached. Balsa strips are geodeticallyglued to the core and edges. These strips are now sanded/shaped to an airfoil shape and the entire surface sheeted with 3/32nd balsa. . I've tried this on a Mirage fin and it is amazing strong and light.
    My only concern is the structural airworthiness of this older Aggressor airframe. I had a single bouncy landing on mine and the wing literally exploded on the very next flight, even after inspecting it for apparent damage.
    Art ARRO
  17. #17
    Join Date
    Dec 2001
    Lancaster, CA IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can do.
    John Redman
  18. #18
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi John
    Funny , I just came across an old pic of your scooby doo Bobcat that directly hit the powerlines at Woodland pulling a Hi-G turn!
    I remember the purple jetcat cover had a perfect indentation from the cable!
    Ahh, Magnalite, that was before my time!
    My 1st BVM build was the agg 3 ( plug in wings, sheeted foam surfaces)
    So it's balsa skins with CF strips laminated inside?
    Yes, if you could email me dimensions and maybe pics of the plan or manual ( just for vert fin)
    That would help me build one.
    Art , thank you for your assistance !
    Please let me know what I owe you
    Thanks !
    Jake
  19. #19
    mr_matt's Avatar
    Join Date
    Dec 2001
    Oak Park, CA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jake I would think this should be a simple sheeted foam affair very similar to how the agg III vertical was built and glued on. You just needed to cut a new foam core then copy the agg III plans. I had flyingfoam cut some stuff for me it was awesome work.
    Matt
  20. #20
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jake/Matt,
    Just for grins I fabricated an Aggressor I fin using my sheet balsa core and leading/trailing edges connected by geodetic balsa strips shaped to the root and tip ribs. The all-up weight of the fin, sheeted/sanded/ready for glassing was 36 grams. The solid balsa rudder was 12 grams, which totals for 48 grams (less than 2 oz) for the entire vertical surface without glassing. I doubt a solid surface could be built any lighter and, maybe, perhaps a sheeted foam core structure. My fin is amazingly strong and only took a partial evenings work with scrap balsa. Kindly let me know how you build your vertical fin and a weight of the surface before glassing. I'll glass mine as soon as the shop warms above 65F.
    Art ARRO
  21. #21
    Join Date
    Jan 2002
    PENRYN, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello to all that helped!
    Got some nicely drawn plans from Art and quickly built, glassed and just primed the vert stab!
    Thanks for everybody's help on this!
    Jake
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
