JR XG14
#177
Pit is from helicopter set ups, but ch 6 (aux 1)
I use ch 2 and 9 for ailerons and 6 and 7 for flaps. 3&8 for two elevators. That way gear in 5 and brakes in 9.
important thing is too go device select and inhibit all the channels after 5 before you start so you can use them in the wing type.
#178
Hello fellow programming experts
I have a new issue. I have a brand new hotliner with flaps. I have set up butterfly (break) but would like to have it on AUX3, (which is a left hand slider) rather than butterfly switch.
The settings give me few switch choices but none of the sliders. I'd loved to have it set up with 5%flaps half way and butterfly with full travel. Is that possible? Thanks
#179
For hot liner ( GLID) , Im using the throttle stick for flap in the brake menu ( you have to activate flight mode on a switch with the different name for the mode ; take off , speed etc...) I use the trainer switch ( spring) on the left for motor on / off You have to select that in the moto system :when you release the switch the motor is off. Try first with out prop!!
Very simple and in the brake menu you can program all the compensation you want ...
I hope this help a bit!
#180
Could someone please help me with a program question. I'm trying to start the timer with throttle. I've read some reviews and I can't even find the screens shown in the reviews. I'm pretty fluent in JR programming, but I'm stuck here. I'm in Acro mode.
Thanks, Steve
Thanks, Steve
#183
Thanks for the advice. I think I got it. Can I get rid of the beeping every 60 seconds? The nice thing is that the timer will activate even if you are in another screen. That way you can take off with a screen you want and do some "in the air" programming.
Steve
Steve
#184
Hi Guys,
Need some help here. I'm new to XBUS and the Power Box Power Expander SRS. I have the JR XG14 transmitter and I want to make use of it's many channels 1 - 12 or so. I am using the JR RG812BX receiver with XBUS.
I have bound the Tx and Rx no problem. I have set the XBUS setting to Mode A in the transmitter. I have connected the receiver XBUS port to the power expander SRS RX1 port. I power up the SRS and the receiver powers up as well. However all of the SRS output ports are dead. I get nothing from any port with any stick inputs. It's like I'm not getting any servo output coming through the XBUS port into the power expander. What am I doing wrong? Please help.
#186
Hi Dave,
Update: Yes, I found the USB interface cable in the pile of stuff that I acquired when I purchased the airplane with the power expander. I downloaded the software, updated the PB expander F/W and configured it for JR DMSS. It took quite a bit of buggering around but it now WORKS!!!! Thank you.
