Reload this Page >
P20 Brain Fart
P20 Brain Fart
Old 02-16-2013, 09:05 AM
JimJones1
Banned
Default P20 Brain Fart
Had an odd thing happen with my P20 today:
Started ok (Gas Start) Took off fine. Then I throttled back and the turbine went to idle and then would not respond to the throttle at all. Landed ok
It responded to the trim to shut down.
Then it cooled down and was ok. Switched off and then went for a start. It started fine and the green light came on but it would not respond to the throttle
Stopped it and let it cool down. Then unplugged the ecu from power and then started again. This time it worked fine and responded to the throttle.
Any ideas or has any one else had this ?
Old 02-16-2013, 10:13 AM
warbirdfanatic
Default RE: P20 Brain Fart
No experience of a P20 but it sounds like a lead connection if you unplugged it and then it ran fine? Are the pin outs ok? I've seen quite a few damaged ecu's because the pins have pulled away from the PCB. Give the ECU a shake and listen for any rattles (signs of a cap coming loose or damaged)
What was the state of the battery? This could also be a symptom as batteries can wind up the ECU something rotten!
Old 02-16-2013, 01:26 PM
bidrseed2
Last summer, i started my gas start p20, it didn't sound particularly happy.
When it stabilised at idle, it sounded like it was in a locked in surge, and wouldnt respond to throttle commands.
I shut it down and tried again.
I spoke with Uncle Dave of motors and rotors, and he suggested changing the plug, they apparently have a hard life in the smaller engines.
Its been fine since.
Its and inexpensive thing that you could try and report back.
Old 02-16-2013, 11:46 PM
JimJones1
Banned
ORIGINAL: bidrseed2
Thanks for the feedback. Which plug are you refering to
Old 02-17-2013, 12:52 AM
BaldEagel
BaldEagel's Avatar
The only plug accessible to us mear mortals, the one on top of the turbine for the ignition.
Mike
Old 02-17-2013, 01:29 AM
Henke Torphammar
Henke Torphammar's Avatar
ORIGINAL: bidrseed2
If it starts it doesn't sound resonable the plug is out.
Old 02-17-2013, 01:31 AM
Henke Torphammar
ORIGINAL: JimJones1
The solenoids are very small and do jam from time to time. Try bypassing the fuel solenoid and see if it helps.
Old 02-17-2013, 01:33 AM
JimJones1
Banned
ORIGINAL: BaldEagel
Mike
There are loads of other plugs, The Power lead plug. The io Board, The plug to the valves, The pump to name but a few
Old 02-17-2013, 01:44 AM
BaldEagel
BaldEagel's Avatar
From Birseeds post the only conclusion would be the glow plug, but then again you have 16 turbines you must know more than most of us Dennis.
Mike
Old 02-17-2013, 02:24 AM
JimJones1
Banned
ORIGINAL: Henke Torphammar
ORIGINAL: JimJones1
Henke
Thanks for that suggestion but I dont think it was one of those that jammed as The turbine was still running it had just lost all throttle command on the main stick but did respond to the trim as it would shut down
The glow plug thing is I think a red herring as it just blew shortly after the last start once I got it runnign ok.
I think I may well just put this down to a scrambelled ECU for a short while
Thanks to those that offered some useful help
Old 02-17-2013, 02:27 AM
JimJones1
Banned
ORIGINAL: bidrseed2
Ah thanks for that Birdseed I see now that you meant the glow plug. I was thinking one of the electrical connection plugs to the various pieces of equipment. Looks like I had a brain fart as well
Old 02-18-2013, 01:49 PM
BaldEagel
BaldEagel's Avatar
ORIGINAL: BaldEagel
Mike
Old 02-18-2013, 01:57 PM
warbirdfanatic
It's quite common for a plug to be erratic, then again, if you had a solenoid lockout this would stop any fuel from going through but would still allow trim as it's just a command, if the fuel can't get through then the engine will go nowhere. I had a few plugs go on my jet joe and this was overcome by adjusting the glow power in the ecu settings. Best of luck getting it fixed mate, fingers crossed we'll get a summer in the UK this year!!!!
Old 02-18-2013, 02:39 PM
Dave Wilshere
Not glow plug in this case, but they do need to be a cooler (thicker element coil) for the P-20 which has a smaller chamber and higher internal temp at the plug.
There is odd P-20 software bugs, you not switched ECU's or pumps between turbines? Or new bought parts for install kits?
The P-20 more than any JetCat turbine needs the three items updated together to keep the harmony...
Dw
Old 02-18-2013, 10:58 PM
JimJones1.
Banned
ORIGINAL: Dave Wilshere
Dw
Dave
Thanks for the help. Yes I have swapped over some components after I had a pump and ECU failure which I sent back to Jetcat. The combo I have in this plane has however flown several times without problems. I will have to try it out again (perhaps today) to see how it goes
Thanks again
