Which Powerbox for dual Futaba 7008 receivers?
RE: Which Powerbox for dual Futaba 7008 receivers?
ORIGINAL: mick15
You've lost me I don't understend from your diagram how you achieve 18 channels?
m
m
you can use 14 Channes "over" the PB and you can use "the rest" of the remaining 4 channels by using the RX itself.
BR Philip
ORIGINAL: schroedm
Hi Philip
Why not run ''Hohe'', ''Wolb'' and ''Quer'' in matched ports A, B and C? The PB sockets are all independent so I'm not sure you're increasing your risk of anything failing? Just using up channels and having to resort to PWM channels...
Hi Philip
I know, that is possible to "save" channels. I did not made it, because I need "only" 14. If you want to use crow with "Quer" (what I usually do) you have to split "Quer" and "Quer2" to seperate channels.
BR Philip
Hi Mick,
you are right, but I use the SBUS connection for the Powerbox. For these 14channels I do not need even 1 "normal" plug from the RX. So I have 18 channels (by using T-18 or FX32 only) from the TX minus 14 "over" SBUS and Powerbox. So I have a delt of 4 channesl. And for these 4 channels I will use the "normal" plug from the RX. I wrote it in picture (left RX).
BR Philip
BR Philip
It will be interesting to see if you get the reported fades with the 2x7008sb and powerbox that others are reporting. I may go with Fasst RXs with no telemetry.
#32
My Feedback: (18)
ORIGINAL: dbsonic
only that 7008 cant be used with analog servos in the FASSTest 12ch mode... I dont know which of Mode A,B,C or D is the 12ch mode...
Marty
