Rcbee gear door sequencer
My Feedback: (23)
So the thing works ok 90% of the time. But..
It has this great function built in that ia supposed to keep the gear from collapsing when the Tx and Rx is powered on by remebering the last switch position. But this is only great if it would ACTUALLY WORK!
So, i can place the gear down and the doors open.
Then turn off the rx and tx
Once i turn the tx and rx back on, the gear and doors go up/close instantly. It doesnt matter if the switch is in the correct position or not it happens every time.
So, if the gear is left down and the gear switch on the Tx left in the down position and the model and tx power is cycled, the gear goes up and the doors close. When they should stay down! So every time i trn the model on i have to hold the nose up, then cycle the gear swith to up and back down.
I have tried rebinding the rx with the switch in both positions for up/down. I have tried reversing the gear channel and rebinding.
Nothing has worked, and im about to throw this piece of junk in the fireplace.
Any suggestions?
Any suggestions?
RE: Rcbee gear door sequencer
Your logic seems to be inverted.
Reverse both channel or invert hose on air valve and reverse your channel on the radio....
Now each time you power on, it will gear down!
My Feedback: (23)
ORIGINAL: leopaul
Then I will have to reverse the channel in the radio to put the "gear down" in my preferred switch position which will just start the entire process over again.
My Feedback: (23)
George,
It says it automatically detects the position and holds that position during power up. But for whatever reason, it wasnt doing that.
And now, just like me wife does me, its actually working correctly! So frustrating at times. So now that i have said its working right, it will probably starting being goofy again.
