GSF-150 gear failssafe problems??
Hi guys...... recently I've puchased an dreamworks laanding-gear failsafe and I've a strange problem.
I use it with UP3 valve and Jr8425 servo and Futaba T18 for guidance.......
I've set the servo with T18's ATV and subtrim and all landing gear works perfecttly, but when I plug the GSF-150 into receiver and servo...... the servo started glich........ why????
someones can help me??
thanks
thanks
RE: GSF-150 gear failssafe problems??
I read Todd's addendum on this device and followed the instructions. I am using a hitec 225mg servo on the bvm retract valve for my ultra bandit. I find the retract servo does twitch a bit. I am wondering if its safe to fly?
My Feedback: (76)
Guys I have tested the following sequencers:
JMP Sequencer
Bee Rc Sequencer (jet legend)
Assan Sequencer
Jet tronics Sequencer
It glitches on all of them, including doing the fix, I tested this on a Futaba RX setup as well as Spectrum same problems.
Here is the only time it works: If you have a setup without gear doors, Then it works fine ONLY with an electronic valve.
Basically the GSF-150 is a limited use unit; it has been discontinued, and if you have one, too bad for you.
JMP Sequencer
Assan Sequencer
My Feedback: (76)
I just got this unit from andy and I can double with rcpete said, it works perfect, plus has controls for the canopy!
however it is 200.00 but you don't need to buy a sequencer as it is built in.
I got mine from Andy Kane.
I have had strange thing happen after using my gsf-150 now for several months. My gear is cycling up and down on it's own during my flight. I finally put the gear down for fear of losing all my air. On the ground I still had 95 lbs of air left.
I am using a Jetronics valve for gear and my transmitter for the sequencer (Jeti).
I think it can only be one of two culprits. the Jetronics valve or the gsf-150.
Anyone had a problem like this? With all the talk about the gsf-150 problem I am highly suspicious of it.
Stan
Stan
