JetCat P-300 RX, first one delivered!
YEEEEEES! finaly its here! - i cant belive its only 12 weeks since jetpower... (they said i should have in in 12 weeks)
just unpacked it...
i plan to fire it up tomorrow and post a video with the results.
heres the pics... the last one is in my FEJ F-16 1;5,5 where it should perform nicely.
RE: JetCat P-300 RX, first one delivered!
ORIGINAL: Peter Coers
Fits perfect in my future F16 B
Regards
Regards
all that money and no fod guard included, how much do you have to spend with jetcat to get the most important part to keep your engine from sucking in stones
ORIGINAL: bluescoobydoo
just got up...
a bit of data:
weight turbine and bracket: 2770g
weight turbine with all acc. ex. battery: 3030g
min rpm 33000 max 105000
max thrust 300N - 30,6 kg
a bit of data:
Hello Kasper,
Can you please confirm if Jetcat supplied the Festo Filter in the photo.
I have Just received the new P90I and although the filter is internal I do now it’s a Genuine Jetcat one.
I would be very surprised if Jetcat have supplied the Festo filter over there Genuine filter.
Thank you
Ivan
ORIGINAL: JustflyingI would be very surprised if Jetcat have supplied the Festo filter over there Genuine filter.
What you mention to be a "genuine" JC product can be bought in many hobby shops in Europe, also in different sizes. I could be wrong, but I'm not so sure it's a JC produced item.
Thomas
it was included yes... what you se in the pics is what was in the package...
i have started the p300 2 times now, flawlessly, so when the video is ready i will post a link here... (IM HAPPPY!)
heres the VID,,, the HD version should be ready shortly...
[youtube]http://www.youtube.com/watch?v=u42QrTqmYwg[/youtube]
My Feedback: (95)
I think you are a lot like me. As soon as I get something new and awesome, I have to immediately take it out of the package and try it out. I purchased my first turbine from a local guy years ago and he said he would help me get it set up on a test board the next day after work. By the time he called me, I had already set it up and ran it 3 times.
Very jealous.... one question though. I see JC still has the same kind of turbine mount. The first time I had my 200SX on a test stand, it started to slide forward in the mount. The kero plug is recessed so there was no hard point to stop it. I had to use a piece of a gasket to make it a bit sticky under the clamp and that finally fixed it. Have you noticed any shifting in the mount?
hey, no, i have flown it with a 160SE... this is a video with the maiden flight. i think i have about 40 flights with it until now.
i have changed quite a bit on this F16...
[youtube]http://www.youtube.com/watch?v=TN82zx6NbIo[/youtube]
