Unstable RC jet dynamically controlled
FL
Hello Fellows,
Five years ago, I had the idea of making a RC Turbine Jet where an electronic system helps to flight it, as the modern jets do. In order to improve airplanes maneuverability, the CG is moving back so pitch control turn highly sensitive with lag, at low speed.
The first stage of this project is controlling pitch using canard, and vector nozzle for 3D maneuvers. Microcontrollers are 3 x boards Firmtronics Digimix 3 (with Atmel processors), and 1 x board designed my me, based on Microchip processor. Flight information comes from Airspeed (sensed by two Prandts pitot tubes specially made for this airplane) and three inertial JR gyros.
The airplane platform is a modified Sport Sukhoi 27 design by Peter Liebetrau. This model was led to Sukhoi 37 to use the canard feature.
Even it has few flights; the results have been considerably acceptable. For instance, because the heavy tails balance, it is very difficult to land just by hands, and it needs the canard electronic assistance to reach a good landing.
It is the beginning, more flights, adjustments and settings will take place………
Thanks to:
Greg Gallagher from Firmtronics (intricode.com), microcontroller board provider
Peter Liebetrau
Alberto Enriques (Modellbau USA)
Ken Anderson (42-Percent-Products.com)
Peter Ayache (altecare.com)
Microchip (http://www.microchip.com)
Best Regards,
Ricardo.
Thanks to:
Peter Liebetrau
Best Regards,
Ricardo.
RE: Unstable RC jet dynamically controlled
5 years ago this was a very new idea. However, 3 axis systems are now abundant so nothing new here. I understand you are using airspeed as an input to control canards. If you want to impress, lets see it land completely hands off.
Love the jet though, can these still be purchased?
FL
Essyou35,
Thanks for reading my post.
It is not my intention to get something or any place on the world. It is time to move forward with the technology and aerodynamic.
Scale 1:1 fighters as F16 to F22, Rafale, Su-30 to Su-37 need advanced computers onboard to help their pilot to control it, based on loop control systems and predictive software. It is not a secret that aerobatic planes have Flight CG behind the 25% of the wing cord or MAC. You can fly easily airplanes with CG behind 8% no problem, but 15% to 20% ??? On propeller airplane it is an interesting experience, but you have control because the propeller airwash ; on jets it is a unbelievable experience.
Canards on fighters airplanes were introduced not as lifting surface, but for two purposes: laminar layers control over fuselage/wing, and create aerodynamic balance effect as changing the surface geometry, changing the CG (more or less).
This model reported here , was made and modified specifically as bench test for this concept , all paid by myself and investing the most valuable thing in the life: "Time". The two prandtl pilots where builded by me specially for this plane; the circuit board that sense the two pitot pressures was designed, builded and programmed with complex statistic and logical routines by me; the other three boards were bought because they use a fast processor and the manufacturer provide it with basics routines and the hr is hyper good.
I know that great German companies as ACT and LF are making boards with gyros and accelerometers, and that is the way to go, and I hope in the future many jets be equipped with electronic devices that let fly jet completely unstable, giving a new safe dimension to our hobby.
Sorry by finishing the airplane after some years, it was almost ready 3 years ago but the job and electric helicopter fever put the project on hold.
Best Regards,
Rick.
Best Regards,
Rick.
FL
Hello Matt,
Nop. Both work as twins, the board checks both and use the information of the bigger air pressure value (or airspeed).
The system needs the airspeed to work, it is critical during the flight. if no airspeed is getting, the processor means as the airplane must go nose down; if the airplane increases the speed with canard on negative incidence.....you can imagine......
The software detect the failure and blink a led to advise the anomalie and says which is left or right.
To do what you want is not so difficult, you can use two pitot at very specific angles each one, and the microcontroler make the calculations using trigonometry. if you want to use one pitot, the main tube is thick enough to have a wide nozzle with both dynamic ports or holes.
ORIGINAL: RCpropo
Essyou35,
This model reported here , was made and modified specifically as bench test for this concept , all paid by myself and investing the most valuable thing in the life: ''Time''. The two prandtl pilots where builded by me specially for this plane; the circuit board that sense the two pitot pressures was designed, builded and programmed with complex statistic and logical routines by me; the other three boards were bought because they use a fast processor and the manufacturer provide it with basics routines and the hr is hyper good.
Best Regards,
Rick.
Essyou35,
Best Regards,
Rick.
No need to make excuses... This is what this forum became. Very hard to get any positive or constructive feedback here.
Awesome job. Better post it at rcjetaddiction.com It is a much more constructive and positive group of jet lovers.
See you there
Gerardo
My Feedback: (8)
Hey Rick,
Jack is right in every point of his post. Most of the guys here don't really understand what is going on here. Doing this with a foamie would be a joke and easily accomplished due to wing and cube loading differences on the airframe. Doing it with a heavily loaded model is an achievement.
Great job.
Great job.
Fascinating work Ricardo. So, the airplane is using airspeed as the input to the microprocessers for the canards? Do you intend to use angle of attack at some point?
Regards,
Gus
Regards,
Gus
FL
Mtnflyer14,
At the future, yes , I will experiment with AoA sensor and controllers, I have some ideas about it. But one step at the time. The system described here bring a easy picture, but it is not.
The appropriated AoA sensor for acrobatic airplane is the Vane type. 4 years ago there were not very small commercial magnetic potentiometers to sense angle (maybe today it is available), but more important factor is the Vane design because of a scale factor named Reinold number; but I am sure some guy will find the right small vane shape using an air tunnel.
As I wrote before, it is possible to make an AoA with two pitots for non acrobatic airplane or for landing purpose only. For acrobatic it is necessary 3 pitots at different angles and on the same spot (it is really ugly).........
Yes, it uses the airspeed and gyro sense to control canards. Airspeed also control sensitivity of Vector Nozzle, it releases you of additional switch flip after/before maneuvers.
My Feedback: (101)
wow, I guess my inquiry really shows just how stupid some of us are.....The point of my question is that was your 1st attempt at this using that model or did you experiment with a smaller more expendable model? My ignorance shows[:@] against the "The Big Bang Theory " crowd....
Back in 2003 I built an MP3 player for my car using a single board computer, my own software, using linux, powered the computer by the car using my own power supply etc. I had an 8gb hardrive and an LCD display run off the serial port.
Back in 2003 this was very innovative and mp3 players were expensive and 8gb of MP3 was unheard of. However, If I poseted this today, people would say it was a great innovation, but we have similar or much better thnings now.
Thats all I meant. I do recognize the achievement its just a bit dated is all. I see these types things all over.
Can you give you some more details, what PIC you used, code etc. How about some pictures of the hardware involved?
I have an arduino in my fej f-16 as my sequencer, so I do know the risks involved with putting your own unstested stuff in a jet. Another guy on here made a "flame out" indicator on a twin setup.
We are just seeing more and more of this now its really cool!
FL
Hello Ram-bro,
Your question is valid, and the explanation that Mr. Redman did is 100% right.
We are here to share experiences , it is the way to help or be an inspiring thrust for future developments.
Yes, long time ago I experimented a simple stabilizer system on a flat foam airplane, but what Redman says about wing load, inertial weight, airspeed capabilities, all are very different. On experimental models, there is a stage where you must take the risk and no look back.
Regards,
Ricardo.
Regards,
Ricardo.
Great job Ricardo... as usual !!
Great to see you are using your technology background to improve the hobby.
Give me a call, I will like to see your baby flying.
Say hello to dad and mom.
Jack
Jack
I really like the work you have done here!! Very Nice! I will be following with interest, please keep us up to date. But, I think it was a valid conversational question earlier to ask if you had experimented with foamies, and no, those experiments would not be "a joke" either! Your experiments are impressive though and have a lot of capacity to advance thought and methods.
I'm sure you have probably looked into how easy it is to measure AOA these days with pneumatic/electronics available. There are a lot of off the shelf technologies today for experimental aircraft ops, seems like everyone is flying AOA in light sport aircraft today and the prices are low. Just not as much hobby grade stuff to match prices and micro size equipment we require but adaptations are an interesting thing to ponder.
http://www.advanced-flight-systems.c...s/AOA/aoa.html
http://www.affordablepanels.com/aoa.htm
Do you know of any hobby grade AOA systems out there?
Are you using voice telemetry feedback to an earbud, etc?
QC, CANADA
Hey there Mr. Rc propo,,,I just got done writing a few rants on this other question a guy had on Balancing his new flying thingamgig,,on my way back to the "where do i spend all my kids college fund,,ie- junk for sale,,) I came across your queery,,How too question if i understood it correctly,,soory im a grade three graduate,,and you,,are CLEARLY an Electronical engineer,,but if youll entertain my idiocy for a moment,,i think i may be able to help you with your quest to find control of your project,,,its real real simple,,,,GET IN IT!!!!!! YOUR ASSS will TELL you CLEARLY what the plane is doing!!! with out ANY doubt!!! Im sorry but i just cant wrap my grade three educamatem mind around what you are doing,,but i can grasp WHY!!! I just cant see the point??? unless your trying to get hired by lockheed?? why,,,
Dont you like FLYING rc models?? you know,,with the 2 or (thisll kill you! there was a time when guys flew with 1 !!!!!! stick only!! 1 stick,,and a few ADJUSTMENTS,,buttt,,,) or your goal is to press a button,,the plane will leave mother earth,,perform a whole bunch of mathematically and geometrically perfect manouvers,,and then when youre bored of WATCHING,,return to earth safe and sound?? mission accomplished??
Egineers,,you are ALL too precise,,all too perfect,,,Yes,,you can enginamneer something to the 1,quadrillionth,,or tell me how long this bridge will last ,,assuming!! factor X!!! ,,,but,,you will never be able to factor,,my ass,,my ass,,tells me if something ENGINEERED works correctly or not,,,engineer a mathamatical ASS!!! and your golden,,till then?? cant you just try to ENJOY your models little innefiecencies?? you need to relax and ?? buy a Balsa USA WW1 kit,,,when you open the box,,,dont get nervous,,its just WOOD,,,,
ORIGINAL: warbirdmaniac
Hey there Mr. Rc propo,,,I just got done writing a few rants on this other question a guy had on Balancing his new flying thingamgig,,on my way back to the ''where do i spend all my kids college fund,,ie- junk for sale,,) I came across your queery,,How too question if i understood it correctly,,soory im a grade three graduate,,and you,,are CLEARLY an Electronical engineer,,but if youll entertain my idiocy for a moment,,i think i may be able to help you with your quest to find control of your project,,,its real real simple,,,,GET IN IT!!!!!! YOUR ASSS will TELL you CLEARLY what the plane is doing!!! with out ANY doubt!!! Im sorry but i just cant wrap my grade three educamatem mind around what you are doing,,but i can grasp WHY!!! I just cant see the point??? unless your trying to get hired by lockheed?? why,,,
PS: Ricardo is without a doubt one of the top pilots I've seen fly. I'm talking David S, Ali, Rob Lynch type of good (at pattern, jets, helis... anything you can throw at him). So no, he is not doing this cause he cant fly.
Those darn Trolls.......
All I can say is keep up the good work, it's not about making a jet automated here, it's too smooth out any potential errors as we all know that it's easy to get a bird in the air, the landing is the part we all have to be careful with!
CA
Clearly we need to harness his almighty wisdom, skill, and especially tact by making him a moderator.
